 Post subject: ST1500LM LED:0x000000BD FAddr:0x0000780F
PostPosted: June 7th, 2025, 12:35
Can anyone help me with this case!
I have a Seagate
Model : ST1500LM012-1R817G
Serial : WDZGWVE8
Firmware : SBK2
Capacity : 1.5 TB (2 930 277 168)
It spins well and have no clicking sound
After Tech unlock i got this error
Tech Key...
Requesting FW Pkg ver ........ RT0898.SDM2.CC4679.SBK2
Detecting SA Phys Sct Size...
Result.................................. : 4096
Detecting UA Phys Sct Size...
Detecting Max Head number...
Phys. heads............................. : 4
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C001000 - 0x0001FFFF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC       : disabled
MC Size  : 0x0
[color=#FF0000]MC MCMT Ver is unavailable!!![/color]
Collecting Sys Files information...
  ID        Len
   0         40  Reserved Defect Table (SA defect table)
   1          8  Drive Information File (DIF)
   2         16  Performance Parameter File (PPF)
   3       7800  Primary Defect File (P-List)
   5          8  Manufacturing Information File (MIF)
   8       4800
   B       1000
   C     122880  Serial Port Test Results File (Self Scan Log)
   D        160
   E        432  Data Integrity Check (DIC), HEAD 0
   F        224  DIC Dummy File
  13          8  Disc Registry File (settings, security, etc)
  15        128  BGMS File (Directed Offline Scan)
  16          8
  17         40
  19         32  Log File
  1A         40  Log File
  1B          8  Log File
  1C         16
  1D        128  Physical Overlay File 0
  1E        128  Physical Overlay File 1
  20        384  Physical Overlay File 3
  21        256  Physical Overlay File 4
  22         80  Drive Self Test (DST), Head 0
  23         80  Drive Self Test (DST), Head 1
  24         80  Drive Self Test (DST), Head 2
  25         80  Drive Self Test (DST), Head 3
  2A         16  Saved Mode Pages (HDD settings)
  2B       1896  R/W Operating Parameters (translator, etc)
  2C        432  Data Integrity Check (DIC), HEAD 1
  2D        432  Data Integrity Check (DIC), HEAD 2
  2E        432  Data Integrity Check (DIC), HEAD 3
  33       4576
  34        640  Packed CONGEN XML definition
  3A          8
  3D       3072  Disc firmware container 1
  3E       3072  Disc firmware container 2
  3F       4576  SED parameters
  40         16  SED parameters
  41       2184  SED parameters
  42       4096  ST Ovl
  43       5128  Defect list report file
  44     2121520  BIG file
  45     1664000  BIG file
  46     240856  BIG file
  47     173800  BIG file
  48        592  BIG file
  49        232  BIG file
  4A      42040  BIG file
  4B       4352
  4F       8192
  50      15816  MCMT
  52          8
  58      12800
  5C       2048
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
  ID     MemOffs        Len
   0    80200000     230400  Read Adaptive Parameters File (RAP)
   1    80239400        512  Controller Adaptive Parameters File (CAP)
   4      114F00       8192  Servo Adaptive Parameter File (SAP)
   A      45EE5C       1024  Seek Profile
  13    80253910       2448  Dependent Zone Table for User Area
  14    802592A8         32  Dependent Zone Table for System Area
  15           0    1048576  Flash ROM
  1D    80200020       5000  VBAR Configuration File
  1E    802028A8       9680  Zone Format Parameters File
  26    8024CA60      28336
  27    8024C940        288
RAM:
  ID     MemOffs        Len
   2    802013A8       4832  Zone Table
   6     15366A0      81940  Servo Flaw Table
  16    80200000         32  Drive Configuration Table
  17    802061A8       4848  Temperature Control Configuration
  1F    8052CCC0      19584  RW working user preamp table
  20    80531940        128  RW working system preamp table
  22    81191000     692224
  25    8123A000     315392
  26    8024CA60      28336
  27    8024C940        288
  28    8113E000     327680
  39    80D35C00    2228224
  3E    80255E28      13440
  3F    802592C8        480
Collecting DT Infos completed
System Files I/O method detection... ATA(direct)
Reading autotuning buffer...............   Ok
Buff Root FAT searching  in RAM.........   Ok
Searching module table in RAM... .......   Ok
Searching DT table(RAM, WR) in RAM......   Ok
Searching DT table(RAM, RD) in RAM......   Ok
Searching volume 0 file table in RAM....   Ok
Searching volume 1/2 file table in RAM...   Ok
Searching volume 3 file table in RAM....   Ok
Searching volume 4/5 file table in RAM...   Ok
Request for volume 9/A file allocation table in RAM   Ok
Searching SMP RAM FID in RAM............   Ok
Searching Non Resident G-List FID in RAM   Ok
Searching CFW OVL FID in RAM............   Ok
Search for DBA Base in RAM..............   Ok
Search for RW Sys File DBA in RAM.......   Ok
Search for MCMT RAM FD in RAM...........   Ok
QB
Rst 0x80M
T:0x0002 0x02448A82Srv DETCR init 0x0000
FTU
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
(MC POR Duration): 00000000BC
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
PrgFv0008qv0008qv0008qv0008q
Starting LBA of RW Request=0015E6F027  Length=000004EC
ProcessRWError -Write-  at LBA 0015E6F06D  Sense Code=44090081v0008qv0008qOut:
Wedge Alting
Starting LBA: 0015E6F06D Realloc Len: 00000002
[WA=02] [WA=01] !
vv0008q
Common path start quit now ProcessRC: 00000000,00000000SkipLen: 00000000ReadContinuous: 03E3F164,00000336UnrecovSectorCount:003E,0325NumUDEs: 0000003E,000000FB,00000325Passed: 00000080,00000148,000002E3Out:
PrgF
Many Thanks!
 Post subject: Re: ST1500LM LED:0x000000BD FAddr:0x0000780F
PostPosted: June 10th, 2025, 0:23
check if you have data access
Zero Alpha: zeroalpha.com.au
PostPosted: June 10th, 2025, 2:33
Sadly nope. Drive goes to BSY on every action
PostPosted: June 10th, 2025, 9:12
Upload ROM
PostPosted: June 10th, 2025, 23:39
I know this problem. I can solve it remotely.
Users browsing this forum: Hohgua and 241 guests
