 Post subject: Request : BoardView for WD PCB 2060-800041-003 REV P1
PostPosted: June 10th, 2025, 12:57
Hello everyone,
I'm looking for a BoardView or schematic file for a Western Digital PCB with the following part number:
The board is from a WD USB external hard drive, and I'm trying to either repair it or convert it to SATA to recover data. If anyone has the .brd, .bv, or any related diagram, I would greatly appreciate your help.
Thanks in advance!
 Post subject: Re: Request : BoardView for WD PCB 2060-800041-003 REV P1
PostPosted: June 10th, 2025, 16:09
:lol: If you find it, share it. You can send it to me in PM.
https://forum.hddguru.com/viewtopic.php?f=1&t=42203
https://www.google.com/search?q=PCB+206 ... 03+to+SATA
If the symptom is no power, the usual cause is dry solder joints at the zero-ohm resistor adjacent to the USB connector. Reflow the solder and you should be OK.
PostPosted: July 10th, 2025, 10:47
I just made an account to say thanks! I suspected a power issue but finally took a second look with my new microscope and sure enough, that's the issue! Reflowed the solder and it works, no board swap needed. :D
PostPosted: November 25th, 2025, 17:33
Many thanks, good catch, same problem here ! 8)
Users browsing this forum: Google [Bot] and 103 guests
