 Post subject: HDDScan scan results
PostPosted: August 6th, 2025, 14:05
I used HDDScan to scan a new 20TB WD Gold drive and a 1 year old 16TB WD Gold drive, but it seems like there is very limited knowledge about what to look for, except for clusters of slow reads?
I tried chatgpt and Google AIStudio, both of them seem to think that my results are unacceptable, but they can't provide any source for their tolerances.
On the new 20TB drive I have 2 red blocks above 500 ms and 133 orange blocks (150-500 ms). I know it means that it's probably running error correction routines and eventually is able to read the blocks. But how much is too much?
On the 16TB drive I didn't run a full test, but had more than 70.000 green blocks, 170+ orange blocks and a couple of red blocks before stopping the test and starting to copy the data from the drive. I did see large clusters of green blocks on this drive, sometimes with some orange blocks in them.
Hope somebody can bring some clarity to this :)
 Post subject: Re: HDDScan scan results
PostPosted: August 6th, 2025, 14:56
First, look at SMART.
Scanning HDD mounted in the system is a waste of time. :)
Well, at least from a bootable flash drive. And better not to mount it in the system. If your red blocks have LBA variables at each scan - this is OS interference.
And on the old HDD, recording was not always optimal (vibrations, temperature, etc.).
PostPosted: August 6th, 2025, 15:39
Show us the SMART attributes with Victoria.
https://hdd.by/?download=1&kccpid=916&kcccount=https://hdd.by/Victoria/Victoria537.zip
There should be older English versions, too.
https://hdd.by/victoria/
PostPosted: August 6th, 2025, 16:12
Ok, thank you, I'll try that :) Busy now, but I'll look at it.
Users browsing this forum: Google [Bot] and 80 guests
