ST1000DM003 "SNOOOZZZZZZEEE Retry" Error...Help...
August 23rd, 2025, 6:17
Hello there,
I have ST1000DM003 Sata hard disk. it hasn't any clicking sound. it has SNOOOZZZZZZEEE Retry error. Ididn't do anything. I backed up important sysfile. when backed up copy 0 files give diag error. copy 1 smoothly copied. i attach as attachment. i also use congen command only. below is V40 and ctrl+x command data which i recieve in terminal.
Boot 0x40M�
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005[LBA=0x000042F9]N01010C10o0o0o0o0o0o0o0o0[LBA=0x000042F9]NO1111[LBA=0x00028F1D]N01010C10o0o0o0o0o0o0o0o0[LBA=0x00028F1D]NO1111
Trans.
Spin Up
SpinOK
TCC:0022
(P) SATA Reset
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>V4
Reassigned Sectors List Enabled
Entries: 0000, Alts: 0000, Removed: 002B,
Pending: 0000 Host Pending: 0000
Idx LBA PBA LLLCHS of LBA Wdg PLPCHS of PBA SFI Hours Msecs Status BBM Mask
F3 T>
ATA 15 Cmds
Ts(ms) dT(ms) Op Cnt LBA
0 99999999 00 0000 000000000000
0 0 00 0000 000000000000
109157 109157 EF 0000 000000000000
RW 32 Cmds
Ts(ms) dT(ms) xT(ms) Type Option Mode St EC Info
104506 99999999 8 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000188 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
104515 9 283 02 011101 000000 2 43110081 XFR RD USR LBA B 00000000018C L 000000000038 BO 24000E74 VL E89C.0E20
104798 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 00000000018C L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
104806 8 283 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000190 L 000000000034 BO 24000E74 VL E89C.0E20
105090 284 7 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000190 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
105098 8 283 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000194 L 000000000030 BO 24000E74 VL E89C.0E20
105381 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000194 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
105390 9 283 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000198 L 00000000002C BO 24000E74 VL E89C.0E20
105673 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 000000000198 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
105682 9 283 02 011101 000000 2 43110081 XFR RD USR LBA B 00000000019C L 000000000028 BO 24000E74 VL E89C.0E20
105965 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 00000000019C L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
105973 8 284 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001A0 L 000000000024 BO 24000E74 VL E89C.0E20
106257 284 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001A0 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
106265 8 500 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001A4 L 000000000020 BO 24000E74 VL E89C.0E20
106765 500 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001A5 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
106774 9 283 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001A8 L 00000000001C BO 24000E74 VL E89C.0E20
107057 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001A8 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
107066 9 499 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001AC L 000000000018 BO 24000E74 VL E89C.0E20
107566 500 7 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001AD L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
107574 8 283 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001B0 L 000000000014 BO 24000E74 VL E89C.0E20
107857 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001B0 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
107866 9 283 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001B4 L 000000000010 BO 24000E74 VL E89C.0E20
108149 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001B4 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
108158 9 283 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001B8 L 00000000000C BO 24000E74 VL E89C.0E20
108441 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001B8 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
108449 8 284 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001BC L 000000000008 BO 24000E74 VL E89C.0E20
108733 284 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001BC L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
108741 8 283 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001C0 L 000000000004 BO 24000E74 VL E89C.0E20
109024 283 8 02 011101 000000 2 43110081 XFR RD USR LBA B 0000000001C0 L 000000000001 BO 24000234 BES 022DE80.022E29F.022DE80
109111 87 12 02 028101 000000 1 00000080 XFR WR USR LBA B 000000000000 L 0000000001C4 BO 24000E74 VL F89C.0E20
109123 12 21 02 028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
109144 21 8 02 028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
ASCII Diag mode
F3 T>
Original.rar
(186.97 KiB) Downloaded 91 times
Re: ST1000DM003 "SNOOOZZZZZZEEE Retry" Error...Help...
August 23rd, 2025, 6:23
H0 is weak. You can play with FH or replace the MHA.
August 23rd, 2025, 6:26
Dear pepe sir,
any other solution except head replacement?
August 23rd, 2025, 7:52
play with FH
August 23rd, 2025, 8:36
dear pepe sir,
can you please edit 93 file which i attach with this post. serch other forum and all indicate this method will work. i have no expensive tools like mrt and pc 3000. please...
August 23rd, 2025, 8:41
pepe sir can you please tell which sys file is currupted for this problem?
August 23rd, 2025, 8:57
Please read my prev posts. It is a hw problem, likely no issue with sysfiles (yet). No magic fw fix, it has to be mitigated properly. You need to find somebody with proper tools and knowledge to solve this. Sorry. There are members here from India, only Amarbir comes to my mind ATM, but i recall there were quite a few others as well.
August 23rd, 2025, 8:59
ok pepe sir,
thank you
August 24th, 2025, 4:13
Nobody here to help?
Can somebody edit 0x93 file as attach here?
Original.rar
(186.97 KiB) Downloaded 68 times
August 25th, 2025, 9:55
You've been told already, fixing 93 won't help you.
