 Post subject: Seagate STAX1000600 1TB External - Bad MFT, next steps?
PostPosted: October 6th, 2025, 14:37
Hi, I got a personal STAX1000600 drive I'd like advice on how to proceed. It doesn't seem to be in a bad shape, both data and the drive, but this is my first time recovering from a bad MFT (I've only ever dealt with bad sectors) so I'm trying to be cautious and learn something new.
This is a long post due smart data but I hope I made it easy to skim.
Drive History
- It's a 1TB STAX1000600 USB drive with a single NTFS data partition, connected directly to a MOBO USB port, never removed from enclosure. It must be 10 years old give or take. I included the SMART at the end of this post. It says it's a ST1000LM024 HN-M101MBB.
- No clicking, head parking sounds or weird noises, no disconnection issues or sudden transfer speeds drops, it's rarely moved from its spot (when it is, it's always powered off). This year however was atypical, I had to move the entire PC three times already, so unplugged and re-plugged all cables.
- The computer is nearly as old as the drive but with a new, better quality PSU installed this year (CM V850). The old one wasn't defective, just an ageing lower quality bronze seal Corsair. Mentioning it because I'm about to go through the second RMA for a different drive. There's info about it at the end in case it's relevant.
- The drive file system got corrupted when transferring files both to and from it in alternating steps, sometimes in chunks, others just by pausing to/from transfers windows.
> This drive is rarely written to. It was nearly full, I was taking 200GB out of it and writing another 200GB. The last time I did such a large transfer was ~2 months ago, and haven't written this much to it in years, just read from it. It's always connected to the computer though.
> When nearing the transfer completion it just froze. When it was clear it wasn't a hiccup, OS under load or disconnection, with it still frozen minutes later, I unplugged the drive after trying to spindown it with hdparm (the command timed out). I tried to remount it and got the warning the fs was corrupted. I promplty disconnected it to prevent further damage (I'm not a pro but know this much :lol:) and started researching what to do next.
- When ready I imaged it with HDDSuperClone. Looks as good as one could hope:
#   Total LBA: 1953525164        LBA to read: 1953525164
#    Run time: 0:11:58:30        Remaining:   0:-11:-58:-30
#        Rate:          0 B/s    Recent: 0 B/s   Total: 23 MB/s
#   Skip size:       4096  Skips: 0  Slow: 0  Runs: 0  Resets: 0  Run size: 0
#    Position:          0        Status:  Analyzing
#    Finished: 1953525164 (1 areas 100.000000%)
#   Non-tried:          0 (0 areas 0.000000%)
# Non-trimmed:          0 (0 areas 0.000000%)
# Non-divided:          0 (0 areas 0.000000%)
# Non-scraped:          0 (0 areas 0.000000%)
#         Bad:          0 (0 areas 0.000000%)
- Testdisk reports MBR is good, MFT and mirror are bad. It suggests "None" as partition table.
- It mounts in DMDE without issues. Initially it finds only the data volume ($Volume 01 > External), after running a full scan (RAW+NFTS) it reports additional results. The the file structure seems correct for the External volume.
- Opening the extra volumes from the Full Scan tab shows files that were being copied from/to the drive sitting outside the $Root.
- There are two entries for the $MFT in $FSFragments. The rest are files that were being transferred and can be ignored.
Questions
- Anything else I can do about the MFT?
- DMDE transfer speed has been low when recovering files, and I don't mean file limits, it's the literal speed. Any tips? Is there something else I should do before recovering the files or is this just due hardware?
- When it froze could I have done anything differently to decrease the risk of corruption? Leave the drive alone for a longer time (over 5 min), remove immediately, something else?
- What could have possibly caused it? Looking at the dmesg the drive itself is still being recognized by the OS fine and afaik SMART doesn't suggest bad sectors.
- As far as a 10yo drive can be trusted, do you think it can be put back to work? Most data in it was already archival and redundant. The industry segment I work in has been bad enough lately I can't afford to just throw things out, and the economy isn't helping.
- If yes, any tips on how prepare it? Imaging already fully read it without issues, so format, fill it back, surface scan to see if anything changed, then keep an eye on it? I've also been thinking of using something as btrfs now Windows is no longer my daily driver to be able to test data integrity for extra peace of mind and take advantage of compression but I don't know if it could make recovering from issues like the MFT harder.
SMART -a
smartctl 7.5 2025-04-30 r5714 [x86_64-linux-6.16.3-1-default] (SUSE RPM)
Copyright (C) 2002-25, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Samsung SpinPoint M8 (AF)
Device Model:     ST1000LM024 HN-M101MBB
LU WWN Device Id: 5 0004cf 4010e7e63
Firmware Version: 2AR10002
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database 7.5/5706
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.0, 3.0 Gb/s (current: 3.0 Gb/s)
Local Time is:    Sun Oct  5 16:35:10 2025 -03
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (13500) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        ( 225) minutes.
SCT capabilities:              (0x003f) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   100   100   051    Pre-fail  Always       -       1
  2 Throughput_Performance  0x0026   055   055   000    Old_age   Always       -       12292
  3 Spin_Up_Time            0x0023   086   086   025    Pre-fail  Always       -       4458
  4 Start_Stop_Count        0x0032   066   066   000    Old_age   Always       -       35221
  5 Reallocated_Sector_Ct   0x0033   252   252   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   252   252   051    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0024   252   252   015    Old_age   Offline      -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       47342
10 Spin_Retry_Count        0x0032   252   252   051    Old_age   Always       -       0
11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       195
12 Power_Cycle_Count       0x0032   098   098   000    Old_age   Always       -       2750
191 G-Sense_Error_Rate      0x0022   100   100   000    Old_age   Always       -       3
192 Power-Off_Retract_Count 0x0022   252   252   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0002   052   039   000    Old_age   Always       -       40 (Min/Max 17/61)
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       0
196 Reallocated_Event_Count 0x0032   252   252   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   252   252   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   252   252   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0036   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x002a   100   100   000    Old_age   Always       -       15445
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       195
225 Load_Cycle_Count        0x0032   026   026   000    Old_age   Always       -       751875
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%     47312         -
# 2  Short offline       Completed without error       00%     47296         -
# 3  Short offline       Completed without error       00%     47280         -
# 4  Short offline       Completed without error       00%     47266         -
# 5  Short offline       Completed without error       00%     47251         -
# 6  Short offline       Completed without error       00%     47236         -
# 7  Short offline       Completed without error       00%     47222         -
# 8  Short offline       Completed without error       00%     47205         -
# 9  Short offline       Completed without error       00%     47189         -
#10  Short offline       Completed without error       00%     47166         -
#11  Short offline       Completed without error       00%     47152         -
#12  Short offline       Completed without error       00%     47137         -
#13  Short offline       Completed without error       00%     47122         -
#14  Short offline       Completed without error       00%     47109         -
#15  Short offline       Completed without error       00%     47093         -
#16  Short offline       Completed without error       00%     47077         -
#17  Short offline       Completed without error       00%     47064         -
#18  Short offline       Completed without error       00%     47040         -
#19  Short offline       Completed without error       00%     47027         -
#20  Short offline       Completed without error       00%     47013         -
#21  Short offline       Completed without error       00%     47001         -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Completed [00% left] (0-65535)
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
The above only provides legacy SMART information - try 'smartctl -x' for more
That Raw_Read_Error_Rate has been 1 since forever, I'm under the impression the G-Sense_Error_Rate increased by 1, and that Multi_Zone_Error_Rate also increased by lot. The OS runs short self-tests by itself, and I manually ran a long one 2 months ago, which took the expected time but logged as from LBA 0 to 0.
End of SMART -x
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP/SMART Log 0x04) not supported
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0003  4            0  R_ERR response for device-to-host data FIS
0x0004  4            0  R_ERR response for host-to-device data FIS
0x0005  4            0  R_ERR response for non-data FIS
0x0006  4            0  R_ERR response for device-to-host non-data FIS
0x0007  4            0  R_ERR response for host-to-device non-data FIS
0x0008  4            0  Device-to-host non-data FIS retries
0x0009  4            2  Transition from drive PhyRdy to drive PhyNRdy
0x000a  4            0  Device-to-host register FISes sent due to a COMRESET
0x000b  4            0  CRC errors within host-to-device FIS
0x000d  4            0  Non-CRC errors within host-to-device FIS
0x000f  4            0  R_ERR response for host-to-device data FIS, CRC
0x0010  4            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  4            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  4            0  R_ERR response for host-to-device non-data FIS, non-CRC
0x8e00  4            0  Vendor specific
0x8e01  4            0  Vendor specific
0x8e02  4            0  Vendor specific
0x8e03  4            0  Vendor specific
0x8e04  4            0  Vendor specific
0x8e05  4            0  Vendor specific
0x8e06  4            0  Vendor specific
0x8e07  4            0  Vendor specific
0x8e08  4            0  Vendor specific
0x8e09  4            0  Vendor specific
0x8e0a  4            0  Vendor specific
0x8e0b  4            0  Vendor specific
0x8e0c  4            0  Vendor specific
0x8e0d  4            0  Vendor specific
0x8e0e  4            0  Vendor specific
0x8e0f  4            0  Vendor specific
0x8e10  4            0  Vendor specific
0x8e11  4            0  Vendor specific
Extra info: The other problematic drives
- The first one was a 5TB external Seagate. Sudden death in a month of usage. I didn't like the way it died out of the blue so got a refund and went with a different model. I didn't have the habit of testing drives before using them, just quick formatted and started using this one.
- Second one is a 4TB WD. Started getting pending sector count nearly one year in. I didn't know at the time but it's SMR. Replaced under warranty for another identical drive (got no say in it and all storage, which was already expensive, doubled in price since I first bought it). I replaced the PSU in the meantime, before this drive started to degrade.
- Before even thinking of using the replacement I ran badblocks with three patterns then started to fill it with large but not critical data at first just in case it decided to keel over. Once bitten twice shy! One month in the smart is okay, but the drive started to randomly not show up upon boot. Sometimes it also refuses to mount on the first try if you plug it on an already booted OS. Once it's mounted it's fine, even when putting the system to sleep and back presumably because it doesn't spin down in this state. I'll RMA it once I solve the 1TB drive issue.
The common factor is the computer. I'm not surprised the old 1TB drive choked on the transfer, but the new ones having issues one after another, it's spooky. I wonder if bad ports or something could be causing issues or if I just ran out of good luck, considering it's a sad SMR model and everything.
Thanks in advance!
 Post subject: Re: Seagate STAX1000600 1TB External - Bad MFT, next steps?
PostPosted: October 6th, 2025, 20:55
Double posting to answer one of my own questions because I can't edit:
It's the hardware. Recovering to a different drive goes substantially faster, in the order of hours. It could be the drives speed difference alone, but I suspect because you're not accessing the data directly you're effectively hammering the drive twice if you recover to the same one containing the image: To read image then write the recovered files. It only got so much bandwidth to deal with both operations at once.
And a correction: Sleep does spindown my drives. I forgot I recently fixed a configuration hiccup.
PostPosted: October 6th, 2025, 22:27
It's strange that you have a boot sector at LBA 0, and it's strange that the capacity of the image is 4 sectors short of a full 1TB drive. Perhaps those missing 4 sectors contain the backup NTFS boot sector. Or maybe the Seagate enclosure's firmware grabs those last 4 sectors for its own use?
PostPosted: October 7th, 2025, 9:04
Yeah, it's strange. As the owner I should know what exactly the disk looked like before it got corrupted, but if I formatted it it was a very long time ago and I had no reason to peek at it from any software that would show LBAs since then.
The only related information I managed to dig up in a search is that some Seagates have a small offset at the start. Someone trying to install Linux on a drive of potentially the same model got:
the partition /dev/sda1 assigned to / starts at an offset of 3584 bytes from the minimum alignment for this disk, which may lead to very poor performance.
The poster only shared the consumer-facing name and capacity of his drive, not the model, but the date is about right.
PostPosted: October 7th, 2025, 15:09
Like?
Users browsing this forum: Google [Bot], Majestic-12 [Bot], MindMergepk and 70 guests
