 Post subject: Donor Compatibility for WD20SMRM-59A4S (Thailand, Dec 2022)
PostPosted: September 21st, 2025, 4:25
Hi everyone
I have a WD20SMRM-59A4S, made in Thailand, December 2022, that needs a head swap. Unfortunately, I haven’t been able to find the exact same model locally, but I do have access to the following potential donor drives:
WD20SDRW-11VUUS0 Thailand Oct 2019
WD20SDRW-34VUUS0 Thailand Sep 2022
WD20SMZW-11JW8S0 Malaysia Dec 2018
WD20SDRM-59A4DS1 Thailand Feb 2020
Would any of these be compatible for a head swap?
 Post subject: Re: Donor Compatibility for WD20SMRM-59A4S (Thailand, Dec 20
PostPosted: September 28th, 2025, 4:28
How exactly does the drive behave when turned on?
PostPosted: October 1st, 2025, 8:36
What is the DCM code of the patient, and then post the DCM codes and date of the donors you can get.
PostPosted: October 9th, 2025, 10:49
Hi, VUU should work. I have used VUU on these drives before without issues.
Remember, take your time. Be persistent. If you have doubts stop. Check, then proceed again.
PostPosted: October 18th, 2025, 19:21
:good:
Users browsing this forum: Google [Bot] and 59 guests
