Hi all,
I have a question concerning my drive, I try to sum it up shot:
I wanted to secure "delete" data on my Toshiba MG09ACA 18TB. I googled a bit and used:
hdparm --user-master u --security-set-pass NULL /dev/sdf hdparm --user-master m --security-set-pass NULL /dev/sdf
and then I used --sanitize-crypto-scramble. Somehow (can't say really) process got interrupted.
Since then the drive is LOCKED but not FROZEN. But I can't unlock the drive using the password I set and know. I did some research and found out, that with some drives (firmware issue?) it is not good to use NULL as password.
Looks like Parted Magic had same issues 10 years ago and changed the process to set a real password.
Question is now, is there still a way to rescue the drive?
Kind regards, Skullmonkey
