 Post subject: UNC ERROR , 50% OF DRIVE
PostPosted: December 22nd, 2025, 7:42
Hello ,
model - ST1000LM35-1RK172 ( A5 ROSEWOOD)
Problem : Drive Detected , able to read all modules
but cant Read Sectors after LBA 900,000,000 (UNC ERROR) (50 read and remaining 50%UNC error) , both head ok . did /7 & X
Suspect : Drive was given to some one also and Ran m0,6,2,,,,,22
so original 3_28 & 3_35 sysfile overwritten . Translator issue .
How to Restore original Translator 28 & 35 sysfile ?
File comment: 28 & 35 sysfile
28-35-sys-file-.rar [73.91 KiB]
Downloaded 147 times
 Post subject: Re: UNC ERROR , 50% OF DRIVE
PostPosted: December 22nd, 2025, 16:40
35 doesn't seem to be tampered.
what's the precise LBA you get the first error?
PostPosted: December 23rd, 2025, 3:31
It would be nice to translate the last good LBA and the first bad LBA using this HDD (/A, A>F...). Because I'm not so good at math, accounting for cache, and so on... :)
PostPosted: December 23rd, 2025, 4:18
Thank you Pepe for Reply .
Here is observation :
LBA 0 to 573545871 Sector Read perfectly , NO error
LBA 573545872 - UNC Error starts till end of LBA
(573545872)10 = (222F9D90)16
Last LBA (1953525168)10 = (74706DB0)16
I think need to change 3_28 sysfile , Please help.
Warm Regards,
Alex
PostPosted: December 24th, 2025, 1:20
Thank you .
"the last good LBA and the first bad LBA using this HDD (/A, A>F...)."
I am waiting for Pepe's Reply , because he knows exactly what offset in 3_28 sysfile need to change .
Or if he can give modified 3_28 sysfile to Upload .
Warm Regards,
Alex
PostPosted: December 24th, 2025, 3:32
Hello ,
Here is NGList details
F3 T>V40
Nonresident GList 8 entries returned
Total entries available: 8
PBA Len Flags Phy Cyl Hd PhySctr SFI
5574B8 1 0 39CB 1 BE 8E2DD
4D9F67C C 0 1BA80 1 64 70673
7FAAB5F 1 0 2DB0E 1 F1 1480
8CF5100 1 0 3289C 1 3F B62C0
A0A40D1 122 0 3B0D1 1 0 3C387
B459D1F 10A 0 446FE 1 0 BBE46
E3E9063 C4 0 5D9D6 1 0 12534
ED607A0 12 0 25DA 0 24 15B2C0
Warm Regards,
Alex
PostPosted: December 27th, 2025, 19:19
hello,
checked your 28, it has no traces of that lba, so apparently not added as a false entry.
these are the surrounding defects:
Lba           Shift
434ed25   210EB
43DA04C   2126E
44F5C0D   213EF
48EECD5   2156D
4B8E0C1   2156E
4b8e20b   2156f
you should be able to find these in V1 list, you could attach it to confirm...
NRG also looks normal, no added entries seen.
it is pretty unlikely that defects were removed from 28, so this thing requires further analysis
pls also attach ctrl-L log.
PostPosted: December 28th, 2025, 17:20
If you have no data to recover I suggest using Seatools and zero wipe the disk and it if a SMART short test works fine. The long test is also a good idea but it can take several hours.
PostPosted: January 6th, 2026, 1:40
Terminal Reports - V40 & CTRL ^L and V1
Full Report file Attached .
F3 T>V40
F3 T> CTRL ^L
CheopsLiteM.1.0.SATA.Rosewood.Mule.Servo376.Rap30.AP1.4K + SMR
Product FamilyId: A5, MemberId: 03
HDA SN: WDEESYF9, RPM: 5456, Wedges: 178, Heads: 2, OrigHeads: 4, Lbas: 00000EEF769F, PreampType: 82 02
Bits/Symbol: C, Symbols/UserSector: 0, Symbols/SystemSector: 0
PCBA SN: 0000K7506DAR, Controller: CHEOPSLITEM_1_0_SATA(1310), Channel: Unknown, PowerAsic: KONA Rev A443, BufferBytes: 8000000
SF ID: EF 14, SF Part Size: 400, Flash Used: 400
Package Version: RO08B6.SDM1.C46D05.SDM2 , Package P/N: 100817541, Package Global ID: 00306432,
Package Build Date: 03/06/2017, Package Build Time: 02:02:28, Package CFW Version: RO08.SDM1.01206603.00306432,
Package SFW1 Version: 6B68, Package SFW2 Version: ----, Package SFW3 Version: ----, Package SFW4 Version: ----
Controller FW Rev: 03060202, CustomerRel: SDM2, Changelist: 01206603, ProdType: RO08.SDM1, Date: 03/06/2017, Time: 020228, UserId: 00306432
Servo FW Rev: 6B68
TCG IV Version: 30.05
Package BPN: 7
RAP FW Implementation Key: 1E, Format Rev: 0208, Contents Rev: 53 05 01 00
Active BFW Container: 0
4K Sys Area: 1
Features:
- Quadradic Equation AFH enabled
- VBAR with adjustable zone boundaries enabled
- Volume Based Sparing enabled
- IOEDC enabled
- IOECC enabled
- DERP Read Retries enabled v. 5.0.03.0000000000000003
- LTTC-UDR2 disabled
- SuperParity 4.1 enabled OTF OC enabled
TotalSuperBlks TotalValidSuperBlks
000C7A90 000C7A90
- UMP Zone Group 0004 to 0007
TotalSuperBlks ValidSuperBlks
000044A4 000044A4
- Humidity Sensor disabled
- Media Cache Partition enabled
- Media Cache enabled
- Background Reli Activity Critical Event Logging disabled
- Low Current Spin Up Feature disabled
- Torn Write Protection enabled
- Zone Remap enabled[PLBA:00000000 Len:008B5CFB Offset:0E00ACCC][PLBA:008B5CFB Len:0E00ACCC Offset:FF74A305][PLBA:0E8C09C7 Len:00636CD8 Offset:00000000][PLBA:0EEF769F Len:00000001 Offset:00000000]
- AGB enabled
- SubRelease:0
- Critical Event Log v. 1
- Live Sensor enabled
- FAFH 36.1 uninitialized (deferred)
- EWP:0
- DRAM Mirror:0
F3 T>V1
Head 0: entries 141 slips 204101
Head 1: entries 170 slips 2AFA7
Total Entries 2B1 Total Slips 22F0A8
WARNING!!! LBA remapping is enabled. User LBAs below are Physical LBAs.
User Slip Defect List
log log log phys phys
LBA span cumm cyl hd sctr zn cyl sctr SFI PBA
0 0 0 0 0 0 0 0 0 6 0
51DC0 2 2 318 0 118 0 318 11A 12B0E5 52A22
51F42 3 5 319 0 F5 0 319 F8 12B21F 52BAB
520C4 2 7 31A 0 D3 0 31A D5 12A614 52D33
10D054 1A7 1AE A2E 0 0 0 A2E 0 1450FE 10FABA
37C065 1AB 359 123E 0 0 0 303E 0 30E77 38488E
4502B6 1905 1C5E 102C 1 0 0 2FD0 0 2195E 45B3E8
548F74 1F5E 3BBC 1A27 1 0 0 39CB 0 13C956 5573FA
549032 1 3BBD 1A27 1 BE 0 39CB BF 8F00A 5574B9
6F7243 848 4405 1A45 0 0 3 3845 0 1480C 708186
B53BB9 18E 4593 3554 0 0 3 5354 0 120D51 B6A562
BD4305 18E 4721 3A7F 0 0 3 587F 0 8F8AB BEB892
1A9675F 1 4722 7FA7 0 61 3 9DA7 62 25045 1AC0B7D
1A968DA 1 4723 7FA8 0 40 3 9DA8 41 251D4 1AC0CFB
1A96A55 1 4724 7FA9 0 1F 3 9DA9 20 2537A 1AC0E79
1C7DB94 19C 48C0 928A 0 0 C B08A 0 DB506 1CAA716
2090A2C 19B 4A5B A377 0 0 C C177 0 19525 20C2B4B
20E4BE1 1 4A5C A6BD 0 53 C C4BD 54 2F666 211738D
20E4D5A 1 4A5D A6BE 0 32 C C4BE 33 2F615 2117509
20E4ED3 1 4A5E A6BF 0 11 C C4BF 12 2F5C4 2117685
21E0703 EE0D 1386B B128 0 0 C CF28 0 F6931 2223194
24094AD 1 1386C BD5E 1 29 F DD02 2A 3BDA6 244ED15
240960C 1 1386D BD5F 1 A F DD03 B 3BA39 244EE77
24098EC 2 1386F BD60 1 16C F DD04 16E 3C139 244F15B
2409A4B 1 13870 BD61 1 14E F DD05 14F 3BD8A 244F2BD
2409BAA 1 13871 BD62 1 12F F DD06 130 3BA1D 244F41F
2B0145B D530 20DA1 E229 1 0 F 101CD 0 1E0AD 2B5D436
2DA8B1F 1 20DA2 EFE4 0 6A F 10DE4 6B 925DB 2E0814F
2DA8C8F 1 20DA3 EFE5 0 4A 12 10DE5 4B 92825 2E082C2
2DA8DFF 1 20DA4 EFE6 0 2A 12 10DE6 2B 92AAD 2E08435
2DD88AB 191 20F35 F1CE 0 0 12 10FCE 0 5A12C 2E38442
319C3E4 1 20F36 FE99 0 17F 12 11C99 180 EEA1D 3200FAE
319C553 1 20F37 FE9A 0 15F 12 11C9A 160 EEB9F 3201120
319C6C2 1 20F38 FE9B 0 13F 12 11C9B 140 EECDB 3201292
31CC9ED 1 20F39 1008A 0 7B 12 11E8A 7C F0C60 323199C
31CCB5B 1 20F3A 1008B 0 5B 12 11E8B 5C F0C60 3231B0D
31CCCC9 1 20F3B 1008C 0 3B 14 11E8C 3C F0C60 3231C7E
328A7B7 2 20F3D 100AB 1 74 14 1204F 76 D19D9 32F06C2
328A90E 2 20F3F 100AC 1 56 14 12050 58 D1B7D 32F081D
328AA64 3 20F42 100AD 1 37 14 12051 3A D1D21 32F0978
328ABBA 2 20F44 100AE 1 19 14 12052 1B D1198 32F0AD2
328AE8B 2 20F46 100B0 1 0 14 12054 0 EC7F0 32F0DA9
32C62A2 1 20F47 10337 1 56 14 122DB 57 BEB3E 332C6CF
32C63FA 1 20F48 10338 1 38 14 122DC 39 BECE2 332C82A
32C6552 1 20F49 10339 1 1A 14 122DD 1B BEE86 332C985
32C6824 1 20F4A 1033B 1 0 14 122DF 0 DA4DE 332CC5C
32C697B 1 20F4B 1033B 1 157 14 122DF 158 BEA18 332CDB4
3331E7C 1 20F4C 107D0 1 16 14 12774 17 6DE28 3398BE0
333214E 1 20F4D 107D1 1 172 14 12775 173 6E543 3398EB5
33322A5 2 20F4F 107D2 1 153 14 12776 155 6E6E7 3399010
33323FC 1 20F50 107D3 1 135 14 12777 136 6DB5E 339916A
3332554 1 20F51 107D4 1 117 14 12778 118 6DD02 33992C5
34241C8 18D 210DE 1099E 0 0 14 1279E 0 1195BC 348C524
407AFAC 2 210E0 15018 0 46 14 16E18 48 B4F1C 40F3B46
407B10F 3 210E3 15019 0 26 1A 16E19 29 B51C7 40F3CAE
407B272 2 210E5 1501A 0 7 1A 16E1A 9 B4742 40F3E15
434EA62 2 210E7 159A7 0 15C 1A 177A7 15E 8A3F 43CB405
434EBC3 3 210EA 159A8 0 13C 1A 177A8 13F 8AEC 43CB56B
434ED24 2 210EC 159A9 0 11D 1B 177A9 11F 7E6B 43CB6D0
43DA04B 183 2126F 15F6C 0 0 1B 17D6C 0 13807E 4457700
44F5C0C 181 213F0 16B36 0 0 1B 18936 0 F5F69 4574BD6
48EECD4 17E 2156E 175D1 0 0 1B 193D1 0 109C70 4973696
4B8E0C0 1 2156F 1896B 1 108 1B 1A90F 109 ADEF3 4C16361
4B8E20A 1 21570 1896C 1 EB 1E 1A910 EC ADD92 4C164AE
4B8E354 1 21571 1896D 1 CE 1E 1A911 CF ADC06 4C165FB
4B8E49E 1 21572 1896E 1 B1 1E 1A912 B2 ADAA0 4C16748
4B8E5E8 1 21573 1896F 1 94 1E 1A913 95 AD93F 4C16895
4C51678 2 21575 1921D 1 101 1E 1B1C1 103 346DC 4CDAA83
4C517BF 2 21577 1921E 1 E4 1E 1B1C2 E6 3435F 4CDABCE
4C51907 1 21578 1921F 1 C8 1E 1B1C3 C9 33FB3 4CDAD19
4C51A4F 1 21579 19220 1 AB 1E 1B1C4 AC 33C36 4CDAE64
4C51B97 2 2157B 19221 1 8E 1F 1B1C5 90 345E6 4CDAFB0
4C51CDE 2 2157D 19222 1 71 1F 1B1C6 73 3427C 4CDB0FB
4C51E26 1 2157E 19223 1 55 1F 1B1C7 56 33EBD 4CDB246
4C51F6E 1 2157F 19224 1 38 1F 1B1C8 39 33B53 4CDB391
4C520B6 2 21581 19225 1 1B 1F 1B1C9 1D 34503 4CDB4DD
4C52364 1 21582 19227 1 0 1F 1B1CB 0 4BC65 4CDB790
4C524AE 1 21583 19227 1 14A 1F 1B1CB 14B 33C6B 4CDB8DB
4C525F6 2 21585 19228 1 12D 1F 1B1CC 12F 3461B 4CDBA27
4C5273D 2 21587 19229 1 110 1F 1B1CD 112 3429E 4CDBB72
4C52885 1 21588 1922A 1 F4 1F 1B1CE F5 33EF2 4CDBCBD
4C529CD 1 21589 1922B 1 D7 1F 1B1CF D8 33B75 4CDBE08
4C52B15 2 2158B 1922C 1 BA 1F 1B1D0 BC 34538 4CDBF54
4C52C5C 2 2158D 1922D 1 9D 1F 1B1D1 9F 341BB 4CDC09F
4C52DA4 1 2158E 1922E 1 81 1F 1B1D2 82 33E0F 4CDC1EA
4C52EEC 1 2158F 1922F 1 64 1F 1B1D3 65 33A92 4CDC335
4C53034 2 21591 19230 1 47 1F 1B1D4 49 34442 4CDC481
4C5317B 2 21593 19231 1 2A 1F 1B1D5 2C 34096 4CDC5CC
4C532C3 1 21594 19232 1 E 1F 1B1D6 F 33D19 4CDC717
4C53573 2 21596 19233 1 159 1F 1B1D7 15B 3455A 4CDC9CB
4C536BA 2 21598 19234 1 13C 1F 1B1D8 13E 341F0 4CDCB16
4C53802 1 21599 19235 1 120 1F 1B1D9 121 33E31 4CDCC61
4C5394A 1 2159A 19236 1 103 1F 1B1DA 104 33AC7 4CDCDAC
4C53A92 2 2159C 19237 1 E6 1F 1B1DB E8 34477 4CDCEF8
4C53BD9 2 2159E 19238 1 C9 1F 1B1DC CB 340CB 4CDD043
4C53D21 1 2159F 19239 1 AD 1F 1B1DD AE 33D4E 4CDD18E
4C53E69 1 215A0 1923A 1 90 1F 1B1DE 91 339D1 4CDD2D9
4C53FB1 2 215A2 1923B 1 73 1F 1B1DF 75 34394 4CDD425
4C540F8 2 215A4 1923C 1 56 1F 1B1E0 58 33FD5 4CDD570
4C54240 1 215A5 1923D 1 3A 1F 1B1E1 3B 33C6B 4CDD6BB
4C54388 2 215A7 1923E 1 1D 1F 1B1E2 1F 3461B 4CDD807
4C544CF 2 215A9 1923F 1 0 1F 1B1E3 2 3429E 4CDD952
4C5477F 1 215AA 19240 1 14C 1F 1B1E4 14D 33D83 4CDDC05
4C548C7 1 215AB 19241 1 12F 1F 1B1E5 130 33A06 4CDDD50
4C54A0F 2 215AD 19242 1 112 1F 1B1E6 114 343B6 4CDDE9C
4C54B56 2 215AF 19243 1 F5 1F 1B1E7 F7 3400A 4CDDFE7
4C54C9E 1 215B0 19244 1 D9 1F 1B1E8 DA 33C8D 4CDE132
4C54DE6 1 215B1 19245 1 BC 1F 1B1E9 BD 33923 4CDE27D
4C54F2E 2 215B3 19246 1 9F 1F 1B1EA A1 342D3 4CDE3C9
4C55075 2 215B5 19247 1 82 1F 1B1EB 84 33F27 4CDE514
4CCDA53 1 215B6 197AB 1 8A 1F 1B74F 8B 594B9 4D579BB
4CCDB9B 2 215B8 197AC 1 6D 1F 1B750 6F 59E3A 4D57B07
4CCDCE3 1 215B9 197AD 1 51 1F 1B751 52 59ABD 4D57C52
4CCDE2B 1 215BA 197AE 1 34 1F 1B752 35 59753 4D57D9D
4CCDF73 1 215BB 197AF 1 17 1F 1B753 18 593D6 4D57EE8
4D150AD C 215C7 19ADC 1 64 1F 1BA80 70 7A48F 4D9F688
4ED7B3D 17A 21741 19964 0 0 1F 1B764 0 1200DA 4F64980
4F54EEF 17A 218BB 19EB2 0 0 1F 1BCB2 0 54EB2 4FE2948
4F6362E 1 218BC 19F4E 0 10B 1F 1BD4E 10C 84F8C 4FF11C0
4F63787 1 218BD 19F4F 0 ED 1F 1BD4F EE 851E4 4FF131C
4F638E0 1 218BE 19F50 0 CF 1F 1BD50 D0 8543C 4FF1478
50CE490 178 21A36 1AEC1 0 0 1F 1CCC1 0 563A6 515E082
5313E11 2 21A38 1B11C 0 ED 21 1CF1C EF 36B4 53A6E13
5313F67 3 21A3B 1B11D 0 CE 21 1CF1D D1 381C 53A6F6E
53140BD 2 21A3D 1B11E 0 B0 21 1CF1E B2 2C55 53A70C8
5390E17 177 21BB4 1B673 0 0 21 1D473 0 8AEBE 5424A43
57954AC 176 21D2A 1C9E7 0 0 23 1E7E7 0 C7AE6 582ED3E
5822D20 176 21EA0 1CFF6 0 0 23 1EDF6 0 7AC16 58BD346
58C5598 176 22016 1D6EB 0 0 23 1F4EB 0 99DA6 5960B1E
58CE926 176 2218C 1D751 0 0 23 1F551 0 C4686 596A0EE
58E7DD4 176 22302 1D867 0 0 24 1F667 0 FC0E6 598393E
590FF2E 176 22478 1DA1F 0 0 24 1F81F 0 11CCA6 59ABF7E
591BD1A 2EC 22764 1DAA3 0 0 24 1F8A3 0 8CC26 59B815E
59CDD2B 5 22769 1D969 1 F9 24 1F90D FE 11259F 5A6B15E
59CDE65 C 22775 1D96A 1 D9 24 1F90E E5 114F7E 5A6B2A6
59CDFA0 5 2277A 1D96B 1 C1 24 1F90F C6 112A55 5A6B3E8
5A673E0 1 2277B 1E068 1 23 24 2000C 24 4146C 5B05623
5A67522 1 2277C 1E069 1 7 24 2000D 8 416C7 5B05768
5A677C5 1 2277D 1E06A 1 14C 24 2000E 14D 4166C 5B05A0E
5A67907 1 2277E 1E06B 1 130 24 2000F 131 418C7 5B05B53
5A67A49 1 2277F 1E06C 1 114 24 20010 115 41B22 5B05C98
5CCD573 1 22780 1EBBD 0 139 24 209BD 13A DD70F 5D6EE6B
5CCD6B8 1 22781 1EBBE 0 11C 26 209BE 11D DD139 5D6EFB3
5CCD7FE 1 22782 1EBBF 0 100 26 209BF 101 DD895 5D6F0FC
5CD9232 163 228E5 1EC47 0 0 26 20A47 0 104C13 5D7ADA3
5D2447B 1207 23AEC 1EFB7 0 0 26 20DB7 0 1C46B 5DC78D3
5E57E63 1 23AED 1F421 1 C4 26 213C5 C5 4089F 5EFCEDE
5E57F97 1 23AEE 1F422 1 A9 26 213C6 AA 4089F 5EFD015
5E580CB 1 23AEF 1F423 1 8E 26 213C7 8F 4089F 5EFD14C
5E581FF 1 23AF0 1F424 1 73 26 213C8 74 4089F 5EFD283
5E58333 1 23AF1 1F425 1 58 26 213C9 59 4089F 5EFD3BA
5E6E14A FC0 24AB1 1F53C 1 0 26 214E0 0 3FE48 5F143BF
5FB46A9 2 24AB3 1F7EC 0 12F 26 215EC 131 82C98 605C77E
5FB47F7 1 24AB4 1F7ED 0 112 26 215ED 113 8231B 605C8CF
5FB4946 1 24AB5 1F7EE 0 F5 26 215EE F6 8270B 605CA21
5FF15B0 1 24AB6 1FA98 0 FE 26 21898 FF 10777B 6099BE0
5FF16FE 1 24AB7 1FA99 0 E0 27 21899 E1 106DFE 6099D31
5FF184D 1 24AB8 1FA9A 0 C3 27 2189A C4 1071B2 6099E83
60CDE0B 1 24AB9 2044E 0 DA 27 2224E DB 26511 61777AA
60CDF57 1 24ABA 2044F 0 BD 27 2224F BE 2664D 61778F9
60CE0A3 1 24ABB 20450 0 A0 27 22250 A1 26755 6177A48
6106798 D148 31C03 20763 0 0 27 22563 0 8FE0F 61BD8AB
62F479A 1 31C04 21260 1 29 27 23204 2A 24266 63AE5F2
62F48D4 1 31C05 21261 1 D 27 23205 E 23C5C 63AE72F
62F4B68 1 31C06 21262 1 14B 28 23206 14C 24210 63AE9C6
62F4CA2 1 31C07 21263 1 12F 28 23207 130 23C06 63AEB03
62F4DDD 1 31C08 21264 1 114 28 23208 115 242E7 63AEC41
6529DF9 2 31C0A 215D1 0 3A 28 233D1 3C 37DC6 65E709B
6529F42 3 31C0D 215D2 0 1D 28 233D2 20 38996 65E71E9
652A08B 2 31C0F 215D3 0 1 28 233D3 3 38835 65E7336
653DC2F 1 31C10 216B3 0 A7 29 234B3 A8 9A81E 65FB09B
653DD79 1 31C11 216B4 0 8A 29 234B4 8B 9A6BD 65FB1E8
653DEC3 1 31C12 216B5 0 6D 29 234B5 6E 9A55C 65FB335
665648D 1 31C13 2232C 0 134 29 2412C 135 C77D6 67151EE
66565D6 1 31C14 2232D 0 117 29 2412D 118 C756B 671533A
665671F 2 31C16 2232E 0 FA 29 2412E FC C802C 6715487
6722E22 2 31C18 228CB 1 3 29 2486F 5 10F617 67E2E20
67230AF 2 31C1A 228CC 1 13E 2A 24870 140 10F9BC 67E30B1
67231E5 2 31C1C 228CD 1 122 2A 24871 124 10F081 67E31EB
672331C 2 31C1E 228CE 1 107 2A 24872 109 10F438 67E3326
6723453 2 31C20 228CF 1 EC 2A 24873 EE 10F7EF 67E3461
690655C 165 31D85 22B86 0 0 2B 24986 0 73190 69C943B
692F52F 2 31D87 22D5C 0 65 2B 24B5C 67 33DA5 69F27BC
692F675 3 31D8A 22D5D 0 48 2B 24B5D 4B 34687 69F2907
692F7BB 2 31D8C 22D5E 0 2C 2B 24B5E 2E 34238 69F2A51
6942775 2 31D8E 22E37 0 14B 2B 24C37 14D 55849 6A05BBF
69428BB 3 31D91 22E38 0 12E 2B 24C38 131 5612A 6A05D0A
6942A01 2 31D93 22E39 0 112 2B 24C39 114 55C97 6A05E54
6AF1754 1 31D94 24196 0 52 2B 25F96 53 4C533 6BB7262
6AF189A 1 31D95 24197 0 36 2B 25F97 37 4CBA5 6BB73AB
6AF19DF 1 31D96 24198 0 19 2B 25F98 1A 4C533 6BB74F3
6AFF296 1 31D97 24234 0 7D 2C 26034 7E 1228A7 6BC4EE3
6AFF3DC 1 31D98 24235 0 61 2C 26035 62 122F65 6BC502C
6AFF521 1 31D99 24236 0 44 2C 26036 45 1228A7 6BC5174
6BBA703 1 31D9A 24097 1 37 2C 2603B 38 3A1C5 6C81493
6BBA837 1 31D9B 24098 1 1C 2C 2603C 1D 3A1C5 6C815CA
6BBA96B 1 31D9C 24099 1 1 2C 2603D 2 3A1C5 6C81701
6BBABF1 1 31D9D 2409A 1 138 2C 2603E 139 39C59 6C8198A
6BBAD25 1 31D9E 2409B 1 11D 2C 2603F 11E 39C59 6C81AC1
6BD7009 2 31DA0 241F3 1 82 2C 26197 84 37765 6C9E057
6BD713C 2 31DA2 241F4 1 67 2C 26198 69 37765 6C9E18E
6BD726F 2 31DA4 241F5 1 4C 2C 26199 4E 37765 6C9E2C5
6BD73A2 2 31DA6 241F6 1 31 2C 2619A 33 37765 6C9E3FC
6BD74D5 2 31DA8 241F7 1 16 2C 2619B 18 37765 6C9E533
6C6EDA2 2 31DAA 2492E 1 B5 2C 268D2 B7 9E6D 6D36C70
6C6EED5 2 31DAC 2492F 1 9A 2C 268D3 9C 9E6D 6D36DA7
6C6F008 2 31DAE 24930 1 7F 2C 268D4 81 9E6D 6D36EDE
6C6F13B 2 31DB0 24931 1 64 2C 268D5 66 9E6D 6D37015
seagate-1tb-report.txt [63.1 KiB]
Downloaded 74 times
Users browsing this forum: Google [Bot] and 61 guests
