Hitachi imaged 60%, now no ID, heads OK, possible SA issue?
January 10th, 2026, 7:06
Hi everyone,
I’m working on a Hitachi HTS545025B9A300 (250GB).
Originally Head 0 was dead and Head 1 was working, and the drive could identify in MRT and read by H1. After a head swap, both H0 and H1 were working, and I managed to image about 60% of the drive. After that, the drive failed again: Now neither H0 nor H1 can read and the drive does not identify. Drive spins normally, heads move twice, then goes to READY.
To rule out heads, I moved the head stack back to the donor drive, and both heads work fine there, so the heads and preamp appear to be OK.
I backed up all resources while the drive was still identifying.
At the moment, when checking modules, I only get this output, which looks corrupted (see attached screenshot).
Has anyone seen this behavior before on Hitachi drives?
Any advice would be appreciated.
Thanks in advance.
Re: Hitachi imaged 60%, now no ID, heads OK, possible SA iss
January 10th, 2026, 7:11
NV-RAM seem to be got corrupt.
If you did backup the fw resourse when it was ok, you might try to rewrite it from backup.
January 10th, 2026, 8:40
michael chiklis wrote:NV-RAM seem to be got corrupt.
Thanks for replying.
I tried rewriting the NV-RAM from my backup, but the behavior is still the same — the drive cannot be identified.
January 10th, 2026, 9:04
Sometimes with Hitachi drives you need to wait few minutes before entering in the fw utility.
1. Repower the drive
2. If it goes ready, wait about 3 or 4 minutes. Don't give any commands.
3. Now enter in fw utility, it should stay ready without giving any errors and fw modules should be accessible.
This works for me when g-list has a lot of entries.
If i try to enter in fw utility without waiting, it returns me error and drive stops responding.
I found this by working on a HTS541010A7E630 hdd!
January 10th, 2026, 16:33
HTS541010A7E630 is an arm based drive while the OP's drive is pre-arm, there are quite some differences. My 2 cents go to SA corruption due to non-native heads, if the heads prove to be OK back in the donor...
January 10th, 2026, 17:27
pepe wrote:HTS541010A7E630 is an arm based drive while the OP's drive is pre-arm, there are quite some differences. My 2 cents go to SA corruption due to non-native heads, if the heads prove to be OK back in the donor...
Oh, you're right. His drive isn't ARM type :)
Since he has already backed up SA modules, can he load them in ram and continue to clone surface?
January 10th, 2026, 17:35
Maybe, but there are modules that must be read from surface.
January 11th, 2026, 1:45
Thanks everyone for the replies.
Just to be sure it's not head issue related, I purchased another donor drive and performed another head swap, but the behavior is still the same.
I also tried rewriting the NV-RAM from backup, with no change.
Below is the report from the SA Structural Testing:
Selected family......................... : HTS5450xxB9
Model by ID............................. :
ROM ID.................................. : 0àø#
NV-RAM ID............................... : C64G
RESF version............................ :
NV-RAM parameters
NV-RAM report
Loaded.................................. : Yes
Checksum................................ : OK
mu-code................................. : C64G
FW Ver code............................. : 10001
Head map................................ : 0 1 255 255
FW boot flag............................ : 0x01
SA top cyl delimiters (by heads)........ : 0x2A18A; 0x2A18A; 0x0000; 0x0000
Used module table
Report on module RESF, "Main module table"
ABA..................................... : 7FE20000
Length (sectors)........................ : 2
Identified.............................. : Yes
mu-code................................. : C64J
FW Ver code............................. : 00000000
ID : Copy : Importn.: ABA : ABA : Size : Read : Size : Address in : Read : Hdr : Description
: : : :(original): (sect): (sect): (byte): RAM : : :
RSVD : 0 : B : 7FD20000 : 7FD20000 : 3 : 3 : 1536 : 00000000 : Yes : Ok : SA marker
RSVD : 1 : B : 7FD21000 : 7FD20000 : 3 : 3 : 1536 : 00000000 : Yes : Ok : SA marker
RSVD : F : B : 7FD00003 : 7FD20000 : 3 : 0 : 1536 : 00000000 : No : : SA marker
RESF : 0 : B : 7FE20000 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : 1 : B : 7FE21000 : 7FE20000 : 2 : 0 : 0 : 000FFFFF : No : : Main module table
RESF : F : B : 7FE00003 : 7FE20000 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RAM0 : 0 : B : 7FE20002 : 7FE20002 : 165 : 165 : 0 : 00058800 : Yes : Ok : Code module
RAM0 : 1 : B : 7FE21002 : 7FE20002 : 165 : 0 : 0 : 00058800 : No : : Code module
RAM0 : F : B : 7FE00005 : 7FE20002 : 165 : 0 : 0 : 00058800 : No : : Code module
OVR0 : 0 : B : 7FE200A7 : 7FE200A7 : 18 : 18 : 0 : 0006D200 : Yes : Ok : Overlay module
OVR0 : 1 : B : 7FE210A7 : 7FE200A7 : 18 : 0 : 0 : 0006D200 : No : : Overlay module
OVR0 : F : B : 7FE000AA : 7FE200A7 : 18 : 18 : 0 : 0006D200 : Yes : Ok : Overlay module
RESF : 0 : B : 7FE200B9 : 7FE200B9 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
RESF : 1 : B : 7FE210B9 : 7FE200B9 : 2 : 0 : 0 : 000FFFFF : No : : Main module table
RESF : F : B : 7FE000BC : 7FE200B9 : 2 : 2 : 0 : 000FFFFF : Yes : Ok : Main module table
PTCH : 0 : B : 7FE200BB : 7FE200BB : 3 : 3 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
PTCH : 1 : B : 7FE210BB : 7FE200BB : 3 : 0 : 0 : 000FFFFF : No : : Microcode connections table module
PTCH : F : B : 7FE000BE : 7FE200BB : 3 : 3 : 0 : 000FFFFF : Yes : Ok : Microcode connections table module
CNS1 : 0 : B : 7FE200BE : 7FE200BE : 1 : 1 : 456 : 00035BCE : Yes : Ok : HDD logical configuration module
CNS1 : 1 : B : 7FE210BE : 7FE200BE : 1 : 1 : 456 : 00035BCE : Yes : Ok : HDD logical configuration module
CNS1 : F : B : 7FE000C1 : 7FE200BE : 1 : 1 : 456 : 00035BCE : Yes : Ok : HDD logical configuration module
RWCN : 0 : B : 7FE200BF : 7FE200BF : 1 : 0 : 248 : 00035DCE : No : :
RWCN : 1 : B : 7FE210BF : 7FE200BF : 1 : 0 : 248 : 00035DCE : No : :
RWCN : F : B : 7FE000C2 : 7FE200BF : 1 : 1 : 248 : 00035DCE : Yes : Ok :
ZONE : 0 : Ad : 7FE200C0 : 7FE200C0 : 17 : 17 : 8182 : 00033800 : Yes : Ok : Zone allocation table module
ZONE : 1 : Ad : 7FE210C0 : 7FE200C0 : 17 : 0 : 8182 : 00033800 : No : : Zone allocation table module
ZONE : F : Ad : 7FE000C3 : 7FE200C0 : 17 : 17 : 8182 : 00033800 : Yes : Ok : Zone allocation table module
PTRT : 0 : B : 7FE200D1 : 7FE200D1 : 2 : 2 : 1568 : 00003FE0 : Yes : Ok :
PTRT : 1 : B : 7FE210D1 : 7FE200D1 : 2 : 0 : 1568 : 00003FE0 : No : :
PTRT : F : B : 7FE000D4 : 7FE200D1 : 2 : 2 : 1568 : 00003FE0 : Yes : Ok :
SMRT : 0 : B : 7FE200D3 : 7FE200D3 : 1 : 1 : 0 : 000FFFFF : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210D3 : 7FE200D3 : 1 : 0 : 0 : 000FFFFF : No : : S.M.A.R.T. module
SMRT : F : B : 7FE000D6 : 7FE200D3 : 1 : 1 : 0 : 000FFFFF : Yes : Ok : S.M.A.R.T. module
SRVP : 0 : Ad : 7FE200D4 : 7FE200D4 : 2 : 2 : 1014 : 00036410 : Yes : Ok : Module contains cylinder defects table
SRVP : 1 : Ad : 7FE210D4 : 7FE200D4 : 2 : 0 : 1014 : 00036410 : No : : Module contains cylinder defects table
SRVP : F : Ad : 7FE000D7 : 7FE200D4 : 2 : 2 : 1014 : 00036410 : Yes : Ok : Module contains cylinder defects table
SRVM : 0 : : 7FE200D6 : 7FE200D6 : 7 : 7 : 3584 : 00032A00 : Yes : Ok :
SRVM : 1 : : 7FE210D6 : 7FE200D6 : 7 : 0 : 3584 : 00032A00 : No : :
SRVM : F : : 7FE000D9 : 7FE200D6 : 7 : 7 : 3584 : 00032A00 : Yes : Ok :
CHNL : 0 : B : 7FE200DD : 7FE200DD : 21 : 0 : 9880 : 00030000 : No : : Data adapter module
CHNL : 1 : B : 7FE210DD : 7FE200DD : 21 : 0 : 9880 : 00030000 : No : : Data adapter module
CHNL : F : B : 7FE000E0 : 7FE200DD : 21 : 21 : 9880 : 00030000 : Yes : Ok : Data adapter module
IDNT : 0 : B : 7FE200F2 : 7FE200F2 : 2 : 2 : 184 : 00035A46 : Yes : Ok : HDD ID data module
IDNT : 1 : B : 7FE210F2 : 7FE200F2 : 2 : 2 : 184 : 00035A46 : Yes : Ok : HDD ID data module
IDNT : F : B : 7FE000F5 : 7FE200F2 : 2 : 2 : 184 : 00035A46 : Yes : Ok : HDD ID data module
SN00 : 0 : B : 7FE200F3 : 7FE200F3 : 1 : 1 : 20 : 00035A5A : Yes : Ok : Module contains HDD SN
SN00 : 1 : B : 7FE210F3 : 7FE200F3 : 1 : 0 : 20 : 00035A5A : No : : Module contains HDD SN
SN00 : F : B : 7FE000F6 : 7FE200F3 : 1 : 1 : 20 : 00035A5A : Yes : Ok : Module contains HDD SN
MISC : 0 : B : 7FE200F4 : 7FE200F4 : 1 : 1 : 28 : 00035B24 : Yes : Ok :
MISC : 1 : B : 7FE210F4 : 7FE200F4 : 1 : 0 : 28 : 00035B24 : No : :
MISC : F : B : 7FE000F7 : 7FE200F4 : 1 : 1 : 28 : 00035B24 : Yes : Ok :
ICES : 0 : B : 7FE200F5 : 7FE200F5 : 1 : 0 : 74 : 00035B48 : No : : Security information module
ICES : 1 : B : 7FE210F5 : 7FE200F5 : 1 : 0 : 74 : 00035B48 : No : : Security information module
ICES : F : B : 7FE000F8 : 7FE200F5 : 1 : 1 : 74 : 00035B48 : Yes : Ok : Security information module
MLBA : 0 : B : 7FE200F6 : 7FE200F6 : 1 : 1 : 10 : 00035B14 : Yes : Ok : HDD logical configuration module
MLBA : 1 : B : 7FE210F6 : 7FE200F6 : 1 : 0 : 10 : 00035B14 : No : : HDD logical configuration module
MLBA : F : B : 7FE000F9 : 7FE200F6 : 1 : 1 : 10 : 00035B14 : Yes : Ok : HDD logical configuration module
QMCN : 0 : B : 7FE200F7 : 7FE200F7 : 4 : 4 : 2048 : 00038A00 : Yes : Ok :
QMCN : 1 : B : 7FE210F7 : 7FE200F7 : 4 : 0 : 2048 : 00038A00 : No : :
QMCN : F : B : 7FE000FA : 7FE200F7 : 4 : 4 : 2048 : 00038A00 : Yes : Ok :
SMRT : 0 : B : 7FE200FB : 7FE200FB : 1 : 1 : 466 : 00035ECE : Yes : Ok : S.M.A.R.T. module
SMRT : 1 : B : 7FE210FB : 7FE200FB : 1 : 0 : 466 : 00035ECE : No : : S.M.A.R.T. module
SMRT : F : B : 7FE000FE : 7FE200FB : 1 : 1 : 466 : 00035ECE : Yes : Ok : S.M.A.R.T. module
PNID : 0 : D : 7FE200FC : 7FE200FC : 2 : 0 : 0 : 00FFFFFF : No : : Contains information from label on PCB
PNID : 1 : D : 7FE210FC : 7FE200FC : 2 : 0 : 0 : 00FFFFFF : No : : Contains information from label on PCB
PNID : F : D : 7FE000FF : 7FE200FC : 2 : 2 : 0 : 00FFFFFF : Yes : Ok : Contains information from label on PCB
SMRA : 0 : : 7FE200FE : 7FE200FE : 1 : 1 : 352 : 00038094 : Yes : Ok :
SMRA : 1 : : 7FE210FE : 7FE200FE : 1 : 0 : 352 : 00038094 : No : :
SMRA : F : : 7FE00101 : 7FE200FE : 1 : 1 : 352 : 00038094 : Yes : Ok :
ABLP : 0 : B : 7FE200FF : 7FE200FF : 1 : 1 : 104 : 00036D54 : Yes : Ok :
ABLP : 1 : B : 7FE210FF : 7FE200FF : 1 : 0 : 104 : 00036D54 : No : :
ABLP : F : B : 7FE00102 : 7FE200FF : 1 : 1 : 104 : 00036D54 : Yes : Ok :
ABLD : 0 : : 7FE20100 : 7FE20100 : 1 : 1 : 144 : 00036CC4 : Yes : Ok :
ABLD : 1 : : 7FE21100 : 7FE20100 : 1 : 0 : 144 : 00036CC4 : No : :
ABLD : F : : 7FE00103 : 7FE20100 : 1 : 1 : 144 : 00036CC4 : Yes : Ok :
SSTL : 0 : B : 7FE20101 : 7FE20101 : 2 : 0 : 0 : 000FFFFF : No : :
SSTL : 1 : B : 7FE21101 : 7FE20101 : 2 : 0 : 0 : 000FFFFF : No : :
SSTL : F : B : 7FE00104 : 7FE20101 : 2 : 2 : 0 : 000FFFFF : Yes : Ok :
SERL : 0 : B : 7FE20103 : 7FE20103 : 2 : 2 : 1024 : 0002FC00 : Yes : Ok : S.M.A.R.T. error log module
SERL : 1 : B : 7FE21103 : 7FE20103 : 2 : 0 : 1024 : 0002FC00 : No : : S.M.A.R.T. error log module
SERL : F : B : 7FE00106 : 7FE20103 : 2 : 2 : 1024 : 0002FC00 : Yes : Ok : S.M.A.R.T. error log module
SSST : 0 : B : 7FE20105 : 7FE20105 : 1 : 1 : 512 : 00006C00 : Yes : Ok :
SSST : 1 : B : 7FE21105 : 7FE20105 : 1 : 0 : 512 : 00006C00 : No : :
SSST : F : B : 7FE00108 : 7FE20105 : 1 : 1 : 512 : 00006C00 : Yes : Ok :
SKPO : 0 : : 7FE20106 : 7FE20106 : 1 : 1 : 144 : 00036B6C : Yes : No :
SKPO : 1 : : 7FE21106 : 7FE20106 : 1 : 0 : 144 : 00036B6C : No : :
SKPO : F : : 7FE00109 : 7FE20106 : 1 : 1 : 144 : 00036B6C : Yes : No :
DCOT : 0 : B : 7FE20107 : 7FE20107 : 1 : 1 : 22 : 00035A30 : Yes : Ok :
DCOT : 1 : B : 7FE21107 : 7FE20107 : 1 : 0 : 22 : 00035A30 : No : :
DCOT : F : B : 7FE0010A : 7FE20107 : 1 : 1 : 22 : 00035A30 : Yes : Ok :
SRIF : 0 : B : 7FE20108 : 7FE20108 : 1 : 1 : 4 : 00036B68 : Yes : Ok : Self Test start management module
SRIF : 1 : B : 7FE21108 : 7FE20108 : 1 : 0 : 4 : 00036B68 : No : : Self Test start management module
SRIF : F : B : 7FE0010B : 7FE20108 : 1 : 1 : 4 : 00036B68 : Yes : Ok : Self Test start management module
BULK : 0 : : 7FE20109 : 7FE20109 : 1 : 1 : 176 : 00036BFC : Yes : Ok :
BULK : 1 : : 7FE21109 : 7FE20109 : 1 : 0 : 176 : 00036BFC : No : :
BULK : F : : 7FE0010C : 7FE20109 : 1 : 1 : 176 : 00036BFC : Yes : Ok :
ALTT : 0 : : 7FE2010A : 7FE2010A : 1 : 1 : 512 : 00005A00 : Yes : Ok :
ALTT : 1 : : 7FE2110A : 7FE2010A : 1 : 0 : 512 : 00005A00 : No : :
ALTT : F : : 7FE0010D : 7FE2010A : 1 : 1 : 512 : 00005A00 : Yes : Ok :
DBGC : 0 : : 7FE2010B : 7FE2010B : 1 : 1 : 78 : 00039F0C : Yes : Ok :
DBGC : 1 : : 7FE2110B : 7FE2010B : 1 : 0 : 78 : 00039F0C : No : :
DBGC : F : : 7FE0010E : 7FE2010B : 1 : 1 : 78 : 00039F0C : Yes : Ok :
OFDT : 0 : : 7FE2010C : 7FE2010C : 1 : 1 : 0 : 000FFFFF : Yes : Ok :
OFDT : 1 : : 7FE2110C : 7FE2010C : 1 : 0 : 0 : 000FFFFF : No : :
OFDT : F : : 7FE0010F : 7FE2010C : 1 : 1 : 0 : 000FFFFF : Yes : Ok :
RDMT : 0 : Ad : 7FE40000 : 7FE40000 : 80 : 80 : 0 : 000A3800 : Yes : Ok : G-List module
RDMT : 1 : Ad : 7FE41000 : 7FE40000 : 80 : 80 : 0 : 000A3800 : Yes : Ok : G-List module
RDMT : F : Ad : 7FE01000 : 7FE40000 : 80 : 0 : 0 : 000A3800 : No : : G-List module
RELI : 0 : B : 7FE40050 : 7FE40050 : 1 : 1 : 0 : 000AD800 : Yes : Ok :
RELI : 1 : B : 7FE41050 : 7FE40050 : 1 : 1 : 0 : 000AD800 : Yes : Ok :
RELI : F : B : 7FE01050 : 7FE40050 : 1 : 0 : 0 : 000AD800 : No : :
PSHT : 0 : Ad : 7FE40051 : 7FE40051 : 630 : 630 : 0 : 000ADA00 : Yes : Ok : P-List module
PSHT : 1 : Ad : 7FE41051 : 7FE40051 : 630 : 0 : 0 : 000ADA00 : No : : P-List module
PSHT : F : Ad : 7FE01051 : 7FE40051 : 630 : 0 : 0 : 000ADA00 : No : : P-List module
OVR1 : 0 : B : 7FE50000 : 7FE50000 : 72 : 72 : 0 : 000FFFFF : Yes : Ok : Code overlay module
OVR1 : 1 : B : 7FE51000 : 7FE50000 : 72 : 72 : 0 : 000FFFFF : Yes : Ok : Code overlay module
SPRE : 0 : B : 7FE50048 : 7FE50048 : 54 : 54 : 0 : 000FFFFF : Yes : Ok :
SPRE : 1 : B : 7FE51048 : 7FE50048 : 54 : 54 : 0 : 000FFFFF : Yes : Ok :
PESD : : D : 7FE60000 : 7FE60000 : 128 : 128 : 0 : 000FFFFF : Yes : Ok : PES data log
MFGP : : Dr : 7FE61000 : 7FE61000 : 1 : 1 : 0 : 000FFFFF : Yes : Ok : Self Test parameters module
SRST : : C : 7FE70000 : 7FE70000 : 128 : 128 : 0 : 000FFFFF : Yes : Ok : Self Test report moudle
FLOG : : B : 7FE80000 : 7FE80000 : 128 : 128 : 0 : 000FFFFF : Yes : Ok :
DUMP : : D : 7FE90000 : 7FE90000 : 376 : 376 : 0 : 000FFFFF : Yes : Ok : Self Test log
RESF : : B : CA143643 : CA143643 : 0 : 0 : 0 : 00000000 : No : : Main module table
RESF : : B : 7FE0FFFF : 7FE0FFFF : 32738 : 0 : 15 : FFFF0002 : No : : Main module table
â : : : 7FE6D200 : 7FE6D200 : 0 : 0 : 18003 : 45520001 : No : :
ÿÿ¹ : : : 7FE27FE2 : 7FE27FE2 : 65535 : 0 : 1 : 0000000F : No : :
PTCH : : B : 809BFFFF : 809BFFFF : 32738 : 0 : 15 : FFFF0003 : No : : Microcode connections table module
Î[ : : : 7FE101C8 : 7FE101C8 : 22354 : 0 : 191 : 00004E43 : No : :
â : : : 7FE35DCE : 7FE35DCE : 248 : 0 : 17742 : 4F5A0001 : No : :
 : : : 7FF17FE2 : 7FF17FE2 : 14336 : 0 : 0 : 1FF60003 : No : :
PTRT : : B : 80B10000 : 80B10000 : 32738 : 0 : 0 : 3FE00002 : No : :
 : : : D4324D53 : D4324D53 : 65535 : 0 : 1 : 7FE200D3 : No : :
ÿÿ : : : 8FE00000 : 8FE00000 : 21075 : 0 : 212 : 00005056 : No : :
â : : : 7FE36410 : 7FE36410 : 1014 : 0 : 19798 : 52530001 : No : :
 : : : 7FE77FE2 : 7FE77FE2 : 10752 : 0 : 0 : 0E000003 : No : :
CHNL : : B : 80BD0003 : 80BD0003 : 32738 : 0 : 3 : 00000015 : No : : Data adapter module
˜& : : : D42E4449 : D42E4449 : 0 : 0 : 1 : 7FE200F2 : No : :
FZ : : : 7FE100B8 : 7FE100B8 : 20051 : 0 : 243 : 00003030 : No : :
â : : : 7FE35A5A : 7FE35A5A : 20 : 0 : 17235 : 494D0000 : No : :
 : : : 7FE17FE2 : 7FE17FE2 : 23332 : 0 : 4353 : 001C0003 : No : :
ICES : : B : 80D50000 : 80D50000 : 32738 : 0 : 3 : 5B480001 : No : : Security information module
J : : : C1224C4D : C1224C4D : 0 : 0 : 1 : 7FE200F6 : No : :
[ : : : 90E1000A : 90E1000A : 19793 : 0 : 247 : 00034E43 : No : :
â : : : 7FE38A00 : 7FE38A00 : 2048 : 0 : 21586 : 4D531001 : No : :
 : : : 7FE17FE2 : 7FE17FE2 : 24270 : 0 : 4097 : 01D20003 : No : :
PNID : : D : 80DCFFFF : 80DCFFFF : 32738 : 0 : 255 : FFFF0002 : No : : Contains information from label on PCB
”€ : : : 7FE10160 : 7FE10160 : 16961 : 0 : 255 : 0000504C : No : :
â : : : 7FE36D54 : 7FE36D54 : 104 : 0 : 17484 : 42410001 : No : :
 : : : 7FE17FE2 : 7FE17FE2 : 27844 : 0 : 4353 : 00900003 : No : :
SSTL : : B : 80E1FFFF : 80E1FFFF : 32738 : 0 : 15 : FFFF0002 : No : :
Modules checking completed
Information about copy 0
Report on module RSVD, "SA marker"
ABA..................................... : 7FD20000
Length (sectors)........................ : 3
Module not loaded! ID = RAM0 Copy 0; Code module
Error : Module is not loaded! (RAM0, Code module)
Report on module OVR1, "Code overly module"
ABA..................................... : 7FE50000
Length (sectors)........................ : 72
FW Ver code............................. : 286BBAC4
Report on module IDNT, "HDD ID data module"
ABA..................................... : 7FE200F2
Firmware................................ : PB2O
Model................................... : Hitachi HTS545025B9A300
Serial.................................. : PBN200DSEJLRYL
Report on module CNSL, "HDD logical configuration module"
ABA..................................... : 7FE200BE
Length (sectors)........................ : 1
AutoReassign............................ : ON
Maximal LBA............................. : 488397168
Report on module MLBA, "HDD logical configuration module"
ABA..................................... : 7FE200F6
Capacity................................ : 1
Maximal LBA............................. : 0
Report on module ZONE, "Zone allocation table module"
ABA..................................... : 7FE200C0
Length (sectors)........................ : 17
Head count.............................. : 2
Full capacity........................... : 495464496
ABA sub-zones count..................... : 495464496
ABA sub-zones cyl, step by heads........ : 495464496
ZONE # Init. Cyl End Cyl Head SPT
0 : 00000 : 08363 : 0 : 5703
: 00000 : 08363 : 1 : 5703
1 : 08364 : 15907 : 0 : 6542
: 08364 : 15907 : 1 : 6542
2 : 15908 : 21811 : 0 : 24295
: 15908 : 21811 : 1 : 24295
3 : 21812 : 26157 : 0 : 6545
: 21812 : 26157 : 1 : 6545
4 : 26158 : 30503 : 0 : 42887
: 26158 : 30503 : 1 : 42887
5 : 30504 : 38293 : 0 : 6548
: 30504 : 38293 : 1 : 6548
6 : 38294 : 46985 : 0 : 60239
: 38294 : 46985 : 1 : 60239
7 : 46986 : 52151 : 0 : 6551
: 46986 : 52151 : 1 : 6551
8 : 52152 : 57317 : 0 : 13295
: 52152 : 57317 : 1 : 13295
9 : 57318 : 61663 : 0 : 6555
: 57318 : 61663 : 1 : 6555
10 : 61664 : 03917 : 0 : 31887
: 61664 : 03917 : 1 : 31887
11 : 03918 : 10723 : 0 : 6558
: 03918 : 10723 : 1 : 6558
12 : 10724 : 16955 : 0 : 50479
: 10724 : 16955 : 1 : 50479
13 : 16956 : 21383 : 0 : 6561
: 16956 : 21383 : 1 : 6561
14 : 21384 : 25729 : 0 : 3535
: 21384 : 25729 : 1 : 3535
15 : 25730 : 34913 : 0 : 6565
: 25730 : 34913 : 1 : 6565
16 : 34914 : 40489 : 0 : 22127
: 34914 : 40489 : 1 : 22127
17 : 40490 : 45983 : 0 : 6568
: 40490 : 45983 : 1 : 6568
18 : 45984 : 50329 : 0 : 40719
: 45984 : 50329 : 1 : 40719
19 : 50330 : 53773 : 0 : 6571
: 50330 : 53773 : 1 : 6571
20 : 53774 : 61481 : 0 : 59311
: 53774 : 61481 : 1 : 59311
21 : 61482 : 03161 : 0 : 6574
: 61482 : 03161 : 1 : 6574
22 : 03162 : 07835 : 0 : 11047
: 03162 : 07835 : 1 : 11047
23 : 07836 : 13411 : 0 : 6578
: 07836 : 13411 : 1 : 6578
Report on module RDMT, "G-List module"
ABA..................................... : 7FE40000
Length (sectors)........................ : 80
Header
Defects count........................... : 238
Grown................................... :
Data:
Candidate............................... :
Total hidden (cand.).................... : 238
Total hidden (grown).................... : 238
Information about copy 1
ABA..................................... : 7FD21000
Module not loaded! ID = RESF Copy 1; Main module table
Error : Module is not loaded! (RESF, Main module table)
Module not loaded! ID = RAM0 Copy 1; Code module
ABA..................................... : 7FE51000
ABA..................................... : 7FE210F2
ABA..................................... : 7FE210BE
Module not loaded! ID = MLBA Copy 1; HDD logical configuration module
Error : Module is not loaded! (MLBA, HDD logical configuration module)
Module not loaded! ID = ZONE Copy 1; Zone allocation table module
Error : Module is not loaded! (ZONE, Zone allocation table module)
ABA..................................... : 7FE41000
Header
Data:
Information about factory copy
Module not loaded! ID = RSVD Copy F; SA marker
Error : Module is not loaded! (RSVD, SA marker)
ABA..................................... : 7FE00003
mu-code................................. : CYAG
Module not loaded! ID = RAM0 Copy F; Code module
Module not loaded! ID = OVR1 Copy F; Code overly module
Error : Module is not loaded! (OVR1, Code overly module)
ABA..................................... : 7FE000F5
Firmware................................ : PB2Q
Model................................... : Hitachi HTS545025B9SA00
ABA..................................... : 7FE000C1
ABA..................................... : 7FE000F9
Module not loaded! ID = ZONE Copy F; Zone allocation table module
Module not loaded! ID = RDMT Copy F; G-List module
Error : Module is not loaded! (RDMT, G-List module)
Information about common modules (Open+Spec)
Module not loaded! ID = PIDM; Module contains information from label on PCB
Error : Module is not loaded! (PIDM, Module contains information from label on PCB)
Report on module MFGP, "Self Test parameters module"
ABA..................................... : 7FE61000
Level................................... :
Heads................................... :
Zones................................... :
Cylinders............................... :
RPM..................................... :
SID`s................................... :
Bytes in ECC............................ :
SRVM cyl base........................... :
Zone # Init. Cyl SPT Last LBA
0 -1 -1 -1
1 -1 -1 -1
2 -1 -1 -1
3 -1 -1 -1
4 -1 -1 -1
5 -1 -1 -1
6 -1 -1 -1
7 -1 -1 -1
8 -1 -1 -1
9 -1 -1 -1
10 -1 -1 -1
11 -1 -1 -1
12 -1 -1 -1
13 -1 -1 -1
14 -1 -1 -1
15 -1 -1 -1
16 -1 -1 -1
17 -1 -1 -1
18 -1 -1 -1
19 -1 -1 -1
20 -1 -1 -1
21 -1 -1 -1
22 -1 -1 -1
23 -1 -1 -1
24 -1 -1 -1
25 -1 -1 -1
26 -1 -1 -1
27 -1 -1 -1
28 -1 -1 -1
29 -1 -1 -1
30 -1 -1 -1
31 -1 -1 -1
32 -1 -1 -1
33 -1 -1 -1
January 11th, 2026, 23:56
I checked the SA modules again and noticed that RDMT copy 0 and copy 1, as well as PSHT copy 0, are accessible and readable.
However, PSHT copy 1 cannot be accessed or read, which suggests that Head 1 cannot read PSHT copy 1.
I tried rewriting PSHT copy 1 from backup. MRT reports the write as successful, but after resetting the drive and attempting to read it again, it still returns a read error.
Could this unreadable PSHT copy 1 be the reason the drive cannot identify?
Is there any way to temporarily bypass or relocate this module to allow identification and recover the remaining data?
Any advice is appreciated.
January 12th, 2026, 0:37
Could you upload your RESF module? I have no idea what needs to be done, but I could at least analyse RESF and identify some free space in the SA for you.
January 12th, 2026, 0:47
fzabkar wrote:Could you upload your RESF module? I have no idea what needs to be done, but I could at least analyse RESF and identify some free space in the SA for you.
Here is the RESF copy 0. RESF Copy 1 is not accessible, reads error.
RESF.rar
(639 Bytes) Downloaded 168 times
January 12th, 2026, 12:13
It seems that your module list contains modules that aren't in the RESF module table. Therefore I am unable to reliably determine the free areas. Sorry.
Edit: The RSVD module may contain the extra modules. Could you upload that?
I wonder if your writing problem is related to microjogs. AIUI, a microjog is the distance between the read and write elements in the head. If you use the patient's microjogs to write with a donor head, then the data will be written slightly off-track. Could this disparity be sufficiently great to make the written data unreadable?
Offset(h) 00   02   04   06   08   0A   0C   0E   10   12
00000000  5245 5346 FFFF 0000 E27F 0200 FFFF 0F00 0000 0100  RESFÿÿ..â...ÿÿ......
00000014  5241 4D30 FFFF 0200 E27F A500 0088 0500 0000 0100  RAM0ÿÿ..â.¥..ˆ......
00000028  4F56 5230 FFFF A700 E27F 1200 00D2 0600 0000 0100  OVR0ÿÿ§.â....Ò......
0000003C  5245 5346 FFFF B900 E27F 0200 FFFF 0F00 0000 0100  RESFÿÿ¹.â...ÿÿ......
00000050  5054 4348 FFFF BB00 E27F 0300 FFFF 0F00 0000 0100  PTCHÿÿ».â...ÿÿ......
00000064  434E 5331 0000 BE00 E27F 0100 CE5B 0300 C801 0100  CNS1..¾.â...Î[..È...
00000078  5257 434E 0000 BF00 E27F 0100 CE5D 0300 F800 0100  RWCN..¿.â...Î]..ø...
0000008C  5A4F 4E45 0300 C000 E27F 1100 0038 0300 F61F 0000  ZONE..À.â....8..ö...
000000A0  5054 5254 0000 D100 E27F 0200 E03F 0000 2006 0000  PTRT..Ñ.â...à?.. ...
000000B4  534D 5254 FFFF D300 E27F 0100 FFFF 0F00 0000 0010  SMRTÿÿÓ.â...ÿÿ......
000000C8  5352 5650 0000 D400 E27F 0200 1064 0300 F603 0100  SRVP..Ô.â....d..ö...
000000DC  5352 564D 0300 D600 E27F 0700 002A 0300 000E 0000  SRVM..Ö.â....*......
000000F0  4348 4E4C 0300 DD00 E27F 1500 0000 0300 9826 0000  CHNL..Ý.â.......˜&..
00000104  4944 4E54 0000 F200 E27F 0100 465A 0300 B800 0100  IDNT..ò.â...FZ..¸...
00000118  534E 3030 0000 F300 E27F 0100 5A5A 0300 1400 0000  SN00..ó.â...ZZ......
0000012C  4D49 5343 0300 F400 E27F 0100 245B 0300 1C00 0111  MISC..ô.â...$[......
00000140  4943 4553 0000 F500 E27F 0100 485B 0300 4A00 0111  ICES..õ.â...H[..J...
00000154  4D4C 4241 0000 F600 E27F 0100 145B 0300 0A00 0111  MLBA..ö.â....[......
00000168  514D 434E 0300 F700 E27F 0400 008A 0300 0008 0110  QMCN..÷.â....Š......
0000017C  534D 5254 0300 FB00 E27F 0100 CE5E 0300 D201 0110  SMRT..û.â...Î^..Ò...
00000190  504E 4944 FFFF FC00 E27F 0200 FFFF FF00 0000 0211  PNIDÿÿü.â...ÿÿÿ.....
000001A4  534D 5241 0300 FE00 E27F 0100 9480 0300 6001 0100  SMRA..þ.â...”€..`...
000001B8  4142 4C50 0000 FF00 E27F 0100 546D 0300 6800 0100  ABLP..ÿ.â...Tm..h...
000001CC  4142 4C44 0300 0001 E27F 0100 C46C 0300 9000 0111  ABLD....â...Äl......
000001E0  5353 544C FFFF 0101 E27F 0200 FFFF 0F00 0000 0110  SSTLÿÿ..â...ÿÿ......
000001F4  5345 524C 0400 0301 E27F 0200 00FC 0200 0004 0110  SERL....â....ü......
00000208  5353 5354 0400 0501 E27F 0100 006C 0000 0002 0110  SSST....â....l......
0000021C  534B 504F 0400 0601 E27F 0100 6C6B 0300 9000 0110  SKPO....â...lk......
00000230  4443 4F54 0000 0701 E27F 0100 305A 0300 1600 0110  DCOT....â...0Z......
00000244  5352 4946 0000 0801 E27F 0100 686B 0300 0400 0010  SRIF....â...hk......
00000258  4255 4C4B 0000 0901 E27F 0100 FC6B 0300 B000 0111  BULK....â...ük..°...
0000026C  414C 5454 0300 0A01 E27F 0100 005A 0000 0002 0000  ALTT....â....Z......
00000280  4442 4743 0300 0B01 E27F 0100 0C9F 0300 4E00 0100  DBGC....â....Ÿ..N...
00000294  4F46 4454 FFFF 0C01 E27F 0100 FFFF 0F00 0000 0100  OFDTÿÿ..â...ÿÿ......
000002A8  5244 4D54 FFFF 0000 E47F 5000 0038 0A00 0000 0000  RDMTÿÿ..ä.P..8......
000002BC  5245 4C49 FFFF 5000 E47F 0100 00D8 0A00 0000 0000  RELIÿÿP.ä....Ø......
000002D0  5053 4854 FFFF 5100 E47F 7602 00DA 0A00 0000 0000  PSHTÿÿQ.ä.v..Ú......
000002E4  4F56 5231 FFFF 0000 E57F 4800 FFFF 0F00 0000 0100  OVR1ÿÿ..å.H.ÿÿ......
000002F8  5350 5245 FFFF 4800 E57F 3600 FFFF 0F00 0000 0010  SPREÿÿH.å.6.ÿÿ......
0000030C  5045 5344 FFFF 0000 E67F 8000 FFFF 0F00 0000 0010  PESDÿÿ..æ.€.ÿÿ......
00000320  4D46 4750 FFFF 0010 E67F 0100 FFFF 0F00 0000 0010  MFGPÿÿ..æ...ÿÿ......
00000334  5352 5354 FFFF 0000 E77F 8000 FFFF 0F00 0000 0010  SRSTÿÿ..ç.€.ÿÿ......
00000348  464C 4F47 FFFF 0000 E87F 8000 FFFF 0F00 0000 0010  FLOGÿÿ..è.€.ÿÿ......
0000035C  4455 4D50 FFFF 0000 E97F 7801 FFFF 0F00 0000 0010  DUMPÿÿ..é.x.ÿÿ......
00000370  454E 442E 0000 0000 0000 0000 0000 0000 0000 0000  END.................
January 12th, 2026, 12:56
These are the modules sorted by ABA:
RSVD :   F  :      B   : 7FD00003 : 7FD20000 :      3  :       0 :     1536 :  00000000  :   No :       : SA marker     <--- BAD
SKPO :   F  :          : 7FE00109 : 7FE20106 :      1  :       1 :      144 :  00036B6C  :  Yes :    No :      <--- BAD
RDMT :   F  :     Ad   : 7FE01000 : 7FE40000 :     80  :       0 :        0 :  000A3800  :   No :       : G-List module     <--- BAD
RELI :   F  :      B   : 7FE01050 : 7FE40050 :      1  :       0 :        0 :  000AD800  :   No :       :      <--- BAD
PSHT :   F  :     Ad   : 7FE01051 : 7FE40051 :    630  :       0 :        0 :  000ADA00  :   No :       : P-List module     <--- BAD
xxxx :      :          : 7FE10160 : 7FE10160 :    16961  :       0 :      255 :  0000504C  :   No :       :
xxxx :      :          : 7FE101C8 : 7FE101C8 :    22354  :       0 :      191 :  00004E43  :   No :       :
xxxx :      :          : 7FE17FE2 : 7FE17FE2 :    23332  :       0 :     4353 :  001C0003  :   No :       :
xxxx :      :          : 7FE17FE2 : 7FE17FE2 :    24270  :       0 :     4097 :  01D20003  :   No :       :
xxxx :      :          : 7FE17FE2 : 7FE17FE2 :    27844  :       0 :     4353 :  00900003  :   No :       :
RWCN :   0  :      B   : 7FE200BF : 7FE200BF :      1  :       0 :      248 :  00035DCE  :   No :       :      <--- BAD
CHNL :   0  :      B   : 7FE200DD : 7FE200DD :     21  :       0 :     9880 :  00030000  :   No :       : Data adapter module     <--- BAD
ICES :   0  :      B   : 7FE200F5 : 7FE200F5 :      1  :       0 :       74 :  00035B48  :   No :       : Security information module     <--- BAD
PNID :   0  :      D   : 7FE200FC : 7FE200FC :      2  :       0 :        0 :  00FFFFFF  :   No :       : Contains information from label on PCB     <--- BAD
RESF :   1  :      B   : 7FE21000 : 7FE20000 :      2  :       0 :        0 :  000FFFFF  :   No :       : Main module table     <--- BAD
RAM0 :   1  :      B   : 7FE21002 : 7FE20002 :    165  :       0 :        0 :  00058800  :   No :       : Code module     <--- BAD
OVR0 :   1  :      B   : 7FE210A7 : 7FE200A7 :     18  :       0 :        0 :  0006D200  :   No :       : Overlay module     <--- BAD
RESF :   1  :      B   : 7FE210B9 : 7FE200B9 :      2  :       0 :        0 :  000FFFFF  :   No :       : Main module table     <--- BAD
PTCH :   1  :      B   : 7FE210BB : 7FE200BB :      3  :       0 :        0 :  000FFFFF  :   No :       : Microcode connections table module     <--- BAD
RWCN :   1  :      B   : 7FE210BF : 7FE200BF :      1  :       0 :      248 :  00035DCE  :   No :       :      <--- BAD
ZONE :   1  :     Ad   : 7FE210C0 : 7FE200C0 :     17  :       0 :     8182 :  00033800  :   No :       : Zone allocation table module     <--- BAD
PTRT :   1  :      B   : 7FE210D1 : 7FE200D1 :      2  :       0 :     1568 :  00003FE0  :   No :       :      <--- BAD
SMRT :   1  :      B   : 7FE210D3 : 7FE200D3 :      1  :       0 :        0 :  000FFFFF  :   No :       : S.M.A.R.T. module     <--- BAD
SRVP :   1  :     Ad   : 7FE210D4 : 7FE200D4 :      2  :       0 :     1014 :  00036410  :   No :       : Module contains cylinder defects table     <--- BAD
SRVM :   1  :          : 7FE210D6 : 7FE200D6 :      7  :       0 :     3584 :  00032A00  :   No :       :      <--- BAD
CHNL :   1  :      B   : 7FE210DD : 7FE200DD :     21  :       0 :     9880 :  00030000  :   No :       : Data adapter module     <--- BAD
SN00 :   1  :      B   : 7FE210F3 : 7FE200F3 :      1  :       0 :       20 :  00035A5A  :   No :       : Module contains HDD SN     <--- BAD
MISC :   1  :      B   : 7FE210F4 : 7FE200F4 :      1  :       0 :       28 :  00035B24  :   No :       :      <--- BAD
ICES :   1  :      B   : 7FE210F5 : 7FE200F5 :      1  :       0 :       74 :  00035B48  :   No :       : Security information module     <--- BAD
MLBA :   1  :      B   : 7FE210F6 : 7FE200F6 :      1  :       0 :       10 :  00035B14  :   No :       : HDD logical configuration module     <--- BAD
QMCN :   1  :      B   : 7FE210F7 : 7FE200F7 :      4  :       0 :     2048 :  00038A00  :   No :       :      <--- BAD
SMRT :   1  :      B   : 7FE210FB : 7FE200FB :      1  :       0 :      466 :  00035ECE  :   No :       : S.M.A.R.T. module     <--- BAD
PNID :   1  :      D   : 7FE210FC : 7FE200FC :      2  :       0 :        0 :  00FFFFFF  :   No :       : Contains information from label on PCB     <--- BAD
SMRA :   1  :          : 7FE210FE : 7FE200FE :      1  :       0 :      352 :  00038094  :   No :       :      <--- BAD
ABLP :   1  :      B   : 7FE210FF : 7FE200FF :      1  :       0 :      104 :  00036D54  :   No :       :      <--- BAD
ABLD :   1  :          : 7FE21100 : 7FE20100 :      1  :       0 :      144 :  00036CC4  :   No :       :      <--- BAD
SSTL :   1  :      B   : 7FE21101 : 7FE20101 :      2  :       0 :        0 :  000FFFFF  :   No :       :      <--- BAD
SERL :   1  :      B   : 7FE21103 : 7FE20103 :      2  :       0 :     1024 :  0002FC00  :   No :       : S.M.A.R.T. error log module     <--- BAD
SSST :   1  :      B   : 7FE21105 : 7FE20105 :      1  :       0 :      512 :  00006C00  :   No :       :      <--- BAD
DCOT :   1  :      B   : 7FE21107 : 7FE20107 :      1  :       0 :       22 :  00035A30  :   No :       :      <--- BAD
SRIF :   1  :      B   : 7FE21108 : 7FE20108 :      1  :       0 :        4 :  00036B68  :   No :       : Self Test start management module     <--- BAD
BULK :   1  :          : 7FE21109 : 7FE20109 :      1  :       0 :      176 :  00036BFC  :   No :       :      <--- BAD
ALTT :   1  :          : 7FE2110A : 7FE2010A :      1  :       0 :      512 :  00005A00  :   No :       :      <--- BAD
DBGC :   1  :          : 7FE2110B : 7FE2010B :      1  :       0 :       78 :  00039F0C  :   No :       :      <--- BAD
OFDT :   1  :          : 7FE2110C : 7FE2010C :      1  :       0 :        0 :  000FFFFF  :   No :       :      <--- BAD
xxxx :      :          : 7FE27FE2 : 7FE27FE2 :    65535  :       0 :        1 :  0000000F  :   No :       :
xxxx :      :          : 7FE35A5A : 7FE35A5A :     20  :       0 :    17235 :  494D0000  :   No :       :
xxxx :      :          : 7FE35DCE : 7FE35DCE :    248  :       0 :    17742 :  4F5A0001  :   No :       :
xxxx :      :          : 7FE36410 : 7FE36410 :    1014  :       0 :    19798 :  52530001  :   No :       :
xxxx :      :          : 7FE36D54 : 7FE36D54 :    104  :       0 :    17484 :  42410001  :   No :       :
xxxx :      :          : 7FE38A00 : 7FE38A00 :    2048  :       0 :    21586 :  4D531001  :   No :       :
xxxx :      :          : 7FE6D200 : 7FE6D200 :      0  :       0 :    18003 :  45520001  :   No :       :
xxxx :      :          : 7FE77FE2 : 7FE77FE2 :    10752  :       0 :        0 :  0E000003  :   No :       :
xxxx :      :          : 7FF17FE2 : 7FF17FE2 :    14336  :       0 :        0 :  1FF60003  :   No :       :
SSTL :      :      B   : 80E1FFFF : 80E1FFFF :    32738  :       0 :       15 :  FFFF0002  :   No :       :      <--- BAD
xxxx :      :          : 8FE00000 : 8FE00000 :    21075  :       0 :      212 :  00005056  :   No :       :
xxxx :      :          : 90E1000A : 90E1000A :    19793  :       0 :      247 :  00034E43  :   No :       :
xxxx :      :          : D42E4449 : D42E4449 :      0  :       0 :        1 :  7FE200F2  :   No :       :
xxxx :      :          : D4324D53 : D4324D53 :    65535  :       0 :        1 :  7FE200D3  :   No :       :
January 12th, 2026, 13:12
The extent of the first module is 0x7FE27FE2 + 65535 = 0x7FE37FE1.
The next module begins at ABA 0x7FE35A5A. This means that the first module overlaps the second, which suggests that something isn't right. However, these could be "junk" modules that don't really exist.
January 12th, 2026, 20:14
fzabkar wrote:It seems that your module list contains modules that aren't in the RESF module table. Therefore I am unable to reliably determine the free areas. Sorry.
Thanks for taking the time to look at it and the explanation, that makes sense.
Here is RSVD copy 1
Yes, I also noticed that there are several modules with strange characters / unreadable IDs in the module list (screenshot attached). These modules were not present when I originally backed up all resources while the drive was identifying. They seem to have appeared later at some stage during the recovery attempts.
RSVD.rar
(143 Bytes) Downloaded 176 times
January 12th, 2026, 20:56
I was hoping that RSVD might contain another table of modules, eg the Factory copy, but clearly that's not the case. I would need to examine a full resource dump, before and after, to learn something about this firmware architecture. There has to be another table somewhere, possibly even in the ROM.
PC3K's list of modules, when sorted, has numerous holes in the ABA areas. If you were to write your PSHT module to one of these holes, you would then need to edit every table so that they all point to the module's new location in the SA.
January 12th, 2026, 21:49
I'm extremely confused. Do Copy 0 and Copy 1 refer to modules on head #0 and #1, respectively? If so, then where is the Factory copy located?
If each head has Factory Copy, Copy 0 and Copy 1, then why bother with Copy 1 if Copy 0 is readable?
How can we tell if ABA 0x7FE210F2 is on head 0 or 1? Or is it on both?
January 12th, 2026, 21:50
fzabkar wrote:I was hoping that RSVD might contain another table of modules, eg the Factory copy, but clearly that's not the case. I would need to examine a full resource dump, before and after, to learn something about this firmware architecture. There has to be another table somewhere, possibly even in the ROM.
I’ve backed up the full resources before and after the issue occurred. I noticed that now many modules from copy 1 are missing that were present before the failure I know analysing this is quite a lot of work, so I’m just uploading them here in case anyone would like to take a look.
Thanks for your help and insights — I really appreciate it.
SABackup After.rar
(832.26 KiB) Downloaded 201 times
SABackup Before.rar
(497.87 KiB) Downloaded 182 times
January 13th, 2026, 0:53
ABA(Factory) = ABA(original) - 0x20000 + 3
ABA(Copy 0) = ABA(original)
ABA(Copy 1) = ABA(original) + 0x1000
All 4 copies of RESF in Copy 0 and Copy 1 are identical. The two copies in the Factory Copy are identical, but they differ slightly from Copy 0 and Copy 1. Also, the factory copy is a different version.
Do the results indicate that the SA is divided into areas of size 0x1000 (= 4096) sectors? It appears that we start with head 0, read 0x1000 sectors, then switch to head 1, read another 0x1000 sectors, then switch to head 0 and repeat.
January 13th, 2026, 3:06
fzabkar wrote: All 4 copies of RESF in Copy 0 and Copy 1 are identical. The two copies in the Factory Copy are identical, but they differ slightly from Copy 0 and Copy 1. Also, the factory copy is a different version.
Yes. Based on comparing the ABA locations of the same modules across Copy 0 and Copy 1, there is a consistent +0x1000 (4096 sector) offset, which indicates that the SA is divided into 0x1000-sector areas
Thanks for your detailed analysis and help — much appreciated.
