ST2000LM007-1R8174 SBK2 Sectors Problem
September 19th, 2019, 10:38
ST2000LM007-1R8174 with firmware SBK2
All system files and modules are readable without problem
Some sectors reading fast some sectors very slow.
There are many many many sectors like this
24 1A 9C 92 6D 85 CE 6D 6F 93 4C D2 44 FC DC 3B
98 25 67 CF 3F 77 EA C1 C5 B7 19 F8 16 EE F9 6F
76 48 30 F5 C9 61 87 35 A3 DA 2A EE A0 D8 92 C3
CC 6C CD 9B 9B 53 A0 69 79 01 E4 94 72 D5 4F 37
AA 93 9E 81 25 4C 5D DD D7 25 B1 BA 1C C7 68 6B
00 B6 AB B7 F7 3E 76 31 AD 48 42 A3 AE B1 05 DF
DE DA 64 5C 81 28 13 65 0B 6F 1F 49 78 A2 3E 33
B4 01 36 42 53 25 CC D8 E1 93 28 7F 0A 9C DB 66
12 24 C3 68 FD 17 E9 0C BF B6 E5 65 D4 8E F4 DA
E8 48 9C 1E 8F 01 82 60 15 DD B6 0B 66 7B 90 0E
46 6F A9 04 59 F2 BF D4 F3 01 40 30 30 75 4D 62
1C 92 7A 2D EB EC 58 08 49 24 1D 26 C2 67 66 D6
FA B6 37 D3 B4 DE 75 7C 27 4B 2E CC 6F 50 03 0A
50 DD C0 F9 46 CB 2E D0 FD 6F FB F2 39 42 3C 7E
2E 00 92 EF 10 C5 CB 07 5B 92 B4 98 CB 3C D9 AD
84 24 AF 95 A2 B7 E4 7B 31 B9 41 81 95 2E F2 01
62 4B 78 BA 4C A0 81 AF 8F DD 12 B7 27 1B AF 75
38 6E 35 A0 1E 92 BA 03 65 00 2C 5D F1 15 48 A9
96 92 C6 56 A8 8C 57 77 C3 24 F9 43 83 07 65 1D
6C B9 93 7C 7A 79 73 AB 99 4B 8A 69 2D F0 1E 71
CA DD AC 62 04 6B 2C 1F 77 6E 47 1E FF E2 3B A5
A0 00 7E 0B D6 65 C9 72 CD 92 10 04 89 DC D4 18
7E 27 0B 31 60 56 E2 A6 AB B9 2D 2A 5B C9 F1 4C
D4 4B C4 27 32 40 9F 1A 01 DC FE D0 E4 BB AA A0
B2 6E 91 CD DF 32 B8 4E DF 00 88 C6 B6 B5 47 14
08 95 A2 F3 69 2F 55 A2 B5 27 45 EF 40 A6 60 48
E6 B9 7F 98 3B 19 0E 16 13 4A 16 95 12 90 1D BC
BC DC 08 8E C5 0B 2B 4A E9 6E 23 BB BC 82 36 10
1A 03 DA B4 97 05 C4 B9 47 95 FC A1 4E 7F D2 47
F0 27 97 5A 21 F6 E1 ED 1D B8 89 57 18 69 8F BB
4E 4A A0 40 F3 E0 9A 41 FB DC 5A 7C AA 5B A8 EF
24 71 7D 69 9D D2 B7 B5 51 03 14 62 74 54 45 43
attached one sector copy here
Sector.txt
(512 Bytes) Downloaded 953 times
Translator is not regenerated, HDD is trying when copying
Starting LBA of RW Request=000509AA90  Length=FFFFFFFF
ProcessRWError -Read-   at LBA 000509AA9F  Sense Code=43110081
What is this sector? No MCMT error
Re: ST2000LM007-1R8174 SBK2 Sectors Problem
September 20th, 2019, 12:27
Hi.
I think one head has this problem. Although Can you check whether all heads have this problem.
September 22nd, 2019, 22:40
Would it be OK to execute the following commands at Level T?
F"READ_SPARING_ENABLED",0,22
F"WRITE_SPARING_ENABLED",0,22
F"OFFLINE_SPARING_ENABLED",0,22
F"DAR_ENABLED",0,22
F"DISABLE_IDLE_ACTIVITY",1,22
F"BGMS_DISABLE_DATA_REFRESH",1,22
F"ABORT_PREFETCH",1,22
F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
November 23rd, 2019, 9:41
gps31 wrote:ST2000LM007-1R8174 with firmware SBK2
I have with a disk exact the same Problem. Do you found a solution?
PS.: I saw at least Head 1 and Head 2 read this pattern sometimes. I didn't see if on Head 0 and Head 3 yet but I will keep an eye on it.
PPS.: Head 1 and Head 2 also read some other data so that pattern just occours just in some areas of the disk...
November 23rd, 2019, 10:28
These rosewoods known for media degradation hence why its slow in certain areas.
November 23rd, 2019, 14:58
cpm1993 wrote:These rosewoods known for media degradation hence why its slow in certain areas.
Ok but why this pattern and always the same one - sounds not so logic to me.
PS.: I saw now Head 0 also read in some sectors that pattern.
November 23rd, 2019, 17:58
Could this be the default fill pattern when the drive is shipped? Do these sectors belong to any files, or are they free clusters? Do they occur in groups of 8 (= 1 physical sector or one 4KB cluster)?
Some of WD's external SMR drives support TRIM. Could this be a TRIM issue??? Were these external drives?
November 24th, 2019, 4:39
fzabkar wrote:Could this be the default fill pattern when the drive is shipped?
... Theoretically but in the end i have sectors full with 0x00 so i guess that is not the case or some Programm produce this Kind of patttern.
fzabkar wrote:Do these sectors belong to any files, or are they free clusters? Do they occur in groups of 8 (= 1 physical sector or one 4KB cluster)?
... They seem to group in clusters of 8 - anyway that drive is a 4K sector drive (EF). I wrote a Python-Script to test that and it returns always a multiple of 8 except 2 times but that can by caused by my script just checking the first 6 hex-values of each 512B chunk.
I will let the imaging finnish and then I will have a look at the result - is there a function in UFS-Explorer or r-Studio which tell me if a specific sector belongs to a file or not? Or does MRT allow to check that?
fzabkar wrote:Some of WD's external SMR drives support TRIM. Could this be a TRIM issue??? Were these external drives?
... I don't think so because that is a Seagate drive.
November 24th, 2019, 5:05
maddin wrote:- is there a function in UFS-Explorer or r-Studio which tell me if a specific sector belongs to a file or not? Or does MRT allow to check that?
I know DMDE can do it.
November 24th, 2019, 18:59
winhex as well...
November 26th, 2019, 10:12
https://forum.hddguru.com/viewtopic.php?f=1&t=38650
Some one already messed with MC and/or trans.
November 26th, 2019, 10:22
unknown wrote:https://forum.hddguru.com/viewtopic.php?f=1&t=38650
I have 99,82% imaged (hope today in the night i will have all done) and till now ca. 0,1% of the drive contain that Sector. After reaching 100% i will try to check which files are affected.
November 27th, 2019, 19:14
... Now I checked 4 of that Secors (searched from Sector 3.8, 3.7, 3.6 and 3.5 billion upwards) which have that pattern. WinHex tell me that they belong to 4 different files - 3 of them with the extention .mix and one .wmv-file!
But it was very strange that all sectors with that pattern read very slow (4 KB/s) and i have a bit less then 0.1% or 1.75GB full with that pattern. So there must be something with that. All other areas where reading much faster and it's far to often on the disk to be just some random piece of data.
November 27th, 2019, 23:16
Do those sectors (on your patient) read differently in your tool and in Windows? Is your tool doing something to change the normal outcome?
February 12th, 2026, 12:12
Have anyone found a solution for this after 5 years.
It is mainly on SMR Seagate (Rosewood) drives
Here is the answer form Acelabs TS
February 13th, 2026, 5:49
The only solution I have found is to play with AFH values or a new set of heads, but even then some sectors still read the same so its not guaranteed. But new heads and AFH values have helped me to read more than I could with original settings and heads.
February 13th, 2026, 11:06
I suggest getting a new hard disk as new models are lower cost / TB and helium disks are more reliable than consumer class disks.
TRIM is seen on SSD is misleading on shingled disks. Disk optimizers also come up real slow wirth shingled disks.
The ST2000LM007-1R8174 is 2TB and low cost SATA SSD can take over. While SSD prices have risen, 4TB and 8TB hard disks in a third part USB enclosure are an option.
February 13th, 2026, 19:34
gameboybin wrote:Have anyone found a solution for this after 5 years.
MRT has a video blog on this subject. They just play with AFH.
https://www.youtube.com/watch?v=5lKvzmVMBM4
