 Post subject: ST10000NM0156 - Unable to disable security?
PostPosted: March 14th, 2026, 10:05
Hey there,
I recently got multiple ST10000NM0156 (Exos X10, 10TB) drives. I routinely 'secure erase' any used drives I get before I put them into use again, so I put all the drives in my Synology to simply invoke a Secure Erase (the NAS uses hdparm to set the user password to "synology" and issues a --security-erase). All but one of the drives accepted and successfully completed the Secure Erase - one of them immediately failed to accept the Secure Erase.
The drive is now in a state where security is enabled and it refuses to disable security in any way known to me.
To be safe, I used hdparm to set both user and master passwords to "pass", and both work fine to unlock the drive with hdparm --security-unlock.
hdparm immediately fails to: --security-disable, --security-erase, all with "Input/output error". I also tried to issue a --sanitize-overwrite command to no avail.
After all the various things I tried, I can still use the drive completely normally after unlocking it, works absolutely fine, SMART parameters are also fine. After a power cycle, the drive is locked again of course. There must be a way to completely disable security again so it becomes usable without unlocking it first?
I have no idea what went wrong here and feel like I am missing a simple point which prevents this drive from accepting any command that would disable security again.
I can set user and master passwords to anything I like, and they then work fine to unlock the drive - but not to disable security or invoke another Secure Erase which would also disable security once finished.
Output of hdparm -I:
ATA device, with non-removable media
   Model Number:       ST10000NM0156-2AA111
   Serial Number:      ZA28xxxx
   Firmware Revision:  SS03
   Transport:          Serial, ATA8-AST, SATA 1.0a, SATA II Extensions, SATA Rev 2.5, SATA Rev 2.6, SATA Rev 3.0
Standards:
   Used: unknown (minor revision code 0x006d)
   Supported: 10 9 8 7 6 5
   Likely used: 10
Configuration:
   Logical      max   current
   cylinders   16383   16383
   heads      16   16
   sectors/track   63   63
   CHS current addressable sectors:    16514064
   LBA    user addressable sectors:   268435455
   LBA48  user addressable sectors: 19532873728
   Logical  Sector size:                   512 bytes
   Physical Sector size:                  4096 bytes
   Logical Sector-0 offset:                  0 bytes
   device size with M = 1024*1024:     9537536 MBytes
   device size with M = 1000*1000:    10000831 MBytes (10000 GB)
   cache/buffer size  = unknown
   Form Factor: 3.5 inch
   Nominal Media Rotation Rate: 7200
Capabilities:
   LBA, IORDY(can be disabled)
   Queue depth: 32
   Standby timer values: spec'd by Standard, no device specific minimum
   R/W multiple sector transfer: Max = 16   Current = 16
   Recommended acoustic management value: 254, current value: 0
   DMA: mdma0 mdma1 mdma2 udma0 udma1 udma2 udma3 udma4 *udma5 udma6
        Cycle time: min=120ns recommended=120ns
   PIO: pio0 pio1 pio2 pio3 pio4
        Cycle time: no flow control=120ns  IORDY flow control=120ns
Commands/features:
   Enabled   Supported:
      *   SMART feature set
      *   Security Mode feature set
      *   Power Management feature set
      *   Write cache
      *   Look-ahead
      *   WRITE_BUFFER command
      *   READ_BUFFER command
      *   DOWNLOAD_MICROCODE
          Power-Up In Standby feature set
      *   SET_FEATURES required to spinup after power up
          SET_MAX security extension
      *   48-bit Address feature set
      *   Mandatory FLUSH_CACHE
      *   FLUSH_CACHE_EXT
      *   SMART error logging
      *   SMART self-test
      *   Media Card Pass-Through
      *   General Purpose Logging feature set
      *   WRITE_{DMA|MULTIPLE}_FUA_EXT
      *   64-bit World wide name
      *   IDLE_IMMEDIATE with UNLOAD
          Write-Read-Verify feature set
      *   WRITE_UNCORRECTABLE_EXT command
      *   {READ,WRITE}_DMA_EXT_GPL commands
      *   Segmented DOWNLOAD_MICROCODE
          unknown 119[6]
          unknown 119[7]
          unknown 119[8]
      *   Gen1 signaling speed (1.5Gb/s)
      *   Gen2 signaling speed (3.0Gb/s)
      *   Gen3 signaling speed (6.0Gb/s)
      *   Native Command Queueing (NCQ)
      *   Phy event counters
      *   Idle-Unload when NCQ is active
      *   READ_LOG_DMA_EXT equivalent to READ_LOG_EXT
      *   DMA Setup Auto-Activate optimization
          Device-initiated interface power management
      *   Software settings preservation
          unknown 78[7]
          unknown 78[11]
      *   SMART Command Transport (SCT) feature set
      *   SCT Write Same (AC2)
      *   SCT Error Recovery Control (AC3)
      *   SCT Features Control (AC4)
      *   SCT Data Tables (AC5)
          unknown 206[7]
          unknown 206[12] (vendor specific)
          unknown 206[13] (vendor specific)
          unknown 206[14] (vendor specific)
      *   SANITIZE_ANTIFREEZE_LOCK_EXT command
      *   SANITIZE feature set
      *   OVERWRITE_EXT command
      *   reserved 69[3]
Security:
   Master password revision code = 5
      supported
      enabled
   not   locked
   not   frozen
   not   expired: security count
      supported: enhanced erase
   Security level high
   872min for SECURITY ERASE UNIT. 872min for ENHANCED SECURITY ERASE UNIT.
Logical Unit WWN Device Identifier: 5000c500b2b6f807
   NAA      : 5
   IEEE OUI   : 000c50
   Unique ID   : 0b2b6f807
Checksum: correct
Output of hdparm --sanitize-status /dev/sdb:
Issuing SANITIZE_STATUS command
SANITIZE failed: Input/output error
SANITIZE device error reason: Last Sanitize Command completed unsuccessfully
Drive in SD3 Sanitize Operation Failed state
The drive does have a PSID printed on the label, but when I put the disk in a Windows machine, the Seagate toolkit seems to not recognize the drive, neither in a locked state, nor in the unlocked state, so Seagate's "revert to factory" instructions did not work for me so far.
Is there anything else I can try? Any other commands or tools I can try? Is it possible to disable security via the serial terminal/console? I really like to put this drive back to use, but with Security enabled it is difficult to reuse it in a NAS...
I didn't treat the drive any different than lots of other drives, and the other Exos X10 took the secure erase fine...
Thanks a lot for your kind help!
 Post subject: Re: ST10000NM0156 - Unable to disable security?
PostPosted: March 14th, 2026, 12:15
I just noticed another detail: The problematic drive does have firmware version SS03 according to hdparm. All other drives (which took the secure erase just fine) have version SS05.
The label on all drives says "SS03". So I guess that all drives except this one have had a firmware update in the past.
Is there any hope that a firmware update might resolve this issue? I'd be willing to try it as a last ditch effort, either fully bricking the drive or maybe fixing the issue.
I have trouble finding this update, and the Seagate site is not helpful in telling me that there is no update for this drive.
Thanks for your kind help!
PostPosted: March 31st, 2026, 15:17
Usually firmware updates deal with internal issues not usually noticeable by users. The ST10000NM0156 is an SED model typically not seen widely in data centers. I have a diverse collection of hard disks and I have saved a lot of spec PDFs too so I can quickly look at specific models for specs. Workload ratings are another area I watch.
I suggest the disks that are sanitized can be sold or used. I use Seatools to wipe disks as this allows disks to clean up bad blocks etc.
PostPosted: April 1st, 2026, 6:33
The problem can be solved as follows:
1. Connect the drive to the computer.
2. Open SeaChest and check the drive's "PD" number:
SeaChest_Erase_x64_windows --scan
3. Perform a quick erase specifying the PSID:
SeaChest_Erase_x64_windows -d PD1 --performQuickestErase --psid 32-digitPSID --confirm this-will-erase-data --revertSP
"PD1" = your PD number (change this to the number that the scan outputs)
"32-digitPSID" = the PSID of the drive must be specified here.
4. Wait for the command (this may take 1-2 minutes)
5. Disconnect the drive
6. Connect the drive
7. Open Victoria for Windows
8. Go to "Service" -> "Security Operations"
Password type: "User"
Security level: "High"
input Password: Enter any password of your choice here.
Press: "Lock Drive"
9. Disconnect the drive
10. Connect the drive
11. Open Victoria for Windows
12. Go to "Service" -> "Security Operations"
input Password: Enter the password you just entered.
Press: "Unlock Drive"
After that, the drive should no longer lock itself.
Users browsing this forum: No registered users and 78 guests
