May 13th, 2026, 8:02
Hello HDDGuru community,
I need a big big favor please
Am in the process of recovering a USB Toshiba portable HDD - the 25Q80EWT ROM is valid but USB bridge FW is not.
Need 25X20CL dump from working Toshiba MQ04UBD200 G0090A PCB.
My chip is blank (all 0xFF). Marvell 88i1017-NDB2.
It would be awesome if anyone could please clip and dump their 25X20CL?
Thank you very much! cheers
-Kyle
May 13th, 2026, 8:41
You could instead just convert it to SATA PCB G4311A. You only need to swap the ROM over.
May 13th, 2026, 11:06
skinbob wrote:You could instead just convert it to SATA PCB G4311A. You only need to swap the ROM over.
Hello skinbob, thanks for the quick reply.
yeah, I know but I'll have to order the part from specific website and wait quite some time.. ideally we need to fix the drive by tomorrow evening. That's a challenge.
having that 25X20CL dump would be awesome.. at least to try..
Thx
May 13th, 2026, 13:22
Here you go...
- Attachments
- MQ04UBD200_25X20CL_ASM1153.rar
- (21.98 KiB) Downloaded 938 times
May 15th, 2026, 9:13
Thanks for the dump. I've tried to flash it back.. unfortunately chip is dead.. I'll have to order the donor PCB.
Pretty sure it will be ok with a PCB swap.
Finger crossed.
May 15th, 2026, 10:30
which chip is dead? the 25x20? or the bridge?
