ST12000NM005GFirmware update
May 31st, 2026, 14:44
Hello everyone, I would like to ask how to convert Dell fwh firmware files into lod files.
EAL6.zip
(1.41 MiB) Downloaded 2348 times
Re: ST12000NM005GFirmware update
May 31st, 2026, 15:27
Delete DEL header.
EAL6.zip
(1.43 MiB) Downloaded 1957 times
May 31st, 2026, 17:46
SWM wrote:Delete DEL header.
Does it matter that your edit effectively results in the digital signature (at the end of .fwh) now falling outside the range of the .LOD file?
Offset(h) 00       04       08       0C
00000100  E71A0E59 01000200 00000000 00001900
00000110  00000000 00000000 00000000 00000000
00000120  00000000 00A02400 00000000 00000000
                   size of payload = 0x24A000
00000130  00000000 00000000 00000000 0000CBEB
00000140  00000000 00000000 00000000 00000700
00000150  40010000 00000000 00000000 00000000
00000160  00000000 009E2400 00000000 00000000
                   size of payload = 0x249E00
00000170  00000000 00000000 00000000 00009560
June 1st, 2026, 1:03
Dear Mr. SWM, how do you do? I have deleted the DEL header according to your method, but I still can't update the firmware. Is this due to a lack of verification? Could you please check it for me? The lod file I generated is as follows.
EAL6 Modified.zip
(1.41 MiB) Downloaded 2084 times
June 1st, 2026, 11:25
I would strip off the first 0x100 bytes. That said, I wouldn't use Dell firmware on a standard retail drive or any non-Dell drive. A firmware update typically targets only a few of the many firmware modules, so you may introduce compatibility problems with existing modules.
