 Post subject: Firmware update NetApp disks
PostPosted: June 9th, 2026, 11:27
Hi guys
I hope I can find some help here with the Gurus ;-)
I have a bunch of NetApp 8TB NL-SAS disks from WD, HGST and Seagate.
Disks from NetApp are typically 520bps which isn't a problem to convert to 512.
But I would also like to patch the firmware, so that it doesn't show "X318" as the SCSI INQ.
This was possible on the WD disks which are now reporting: HGST HUS728T8TAL5204
But for some reason this is harder to do with the HGST and Seagate drives...
The HGST PN is: HUH721008AL5204
The Seagate PN is: ST8000NM0075
What I have done in order to "fix" the WD disk, is to download the NetApp (ONTAP) disk firmware file, and download the same for the NetApp E-Series, they share some disk PN and this is one of them.
The E-Series uses 512bps and disks report their original SCSI INQ while the ONTAP FW reports NETAPP X318.....
The ONTAP firmware file is "clean" and I am update the disks with this file, no problem.
The E-Series firmware file has a header which you need to peel off... I did this comparing it to the ONTAP firmware... and as mentioned, this worked fine with the WD disks...
But no dice on the others...
Does anyone have a clue as to verify the FW file? Maybe there is a checksum that I need to update?
Or.. the drives are "vendor locked", but how can I be sure that this is the case?
I have tried with "sg_write_buffer" and "openSeaChest_Firmware" tools...
Hints are very welcome...
 Post subject: Re: Firmware update NetApp disks
PostPosted: June 10th, 2026, 5:48
A little update... I managed to get HUH721008AL5204 working.. that is X318_HLBRE08TA07 -> HUH721008AL5204
But X318_SMKPE08TA07 I think is a Seagate disk which there was never released a new firmware version (from NetApp)...
Users browsing this forum: Google [Bot] and 61 guests
