 Post subject: wd80efax 68lhpn0 spinning but not recogniserd
PostPosted: October 3rd, 2026, 22:54
[/img]Hello,
I have 2 wd80efax 68lhpn0 that were used in a WD NAS that failed.
I disk is fine but the 2nd one is not recognised in BIOS/Windows (motor spins and heads seems fine)
I am suspecting a FW issue and was wondering if I could get more info through TTL ? (hopefully to confirm a diagnostic..)
I am looking for TX/RX pads on this board 001-0A90561 , i found very little info on the web..
As I have an identical drive that works fine, I wanted to know if there is a way to repair it myself without using PC3000
Thanks in advance!
Maurizio
 Post subject: Re: wd80efax 68lhpn0 spinning but not recogniserd
PostPosted: October 4th, 2026, 18:54
There is no serial for WD / HGST drives (well there is, but not in the way you want to use it for diagnostics).
I would suggest trying to see if it ID's on another computer.
If there is no ID it suggests firmware is not being loaded. So the real question becomes why is firmware not being loaded / processed?
Regrettably I'm not too sure what you would be able to diagnose without the proper (paid) tools.
PostPosted: October 4th, 2026, 19:11
Thanks for your reply!
yes I tried on linux but since it is not even detected in the MB BIOS (that detects the 2nd identical drive) there is no big doubt.. (I tried also in a synology nas..)
I was pretty sure I would need the help of a professional.. but I tried anyway :)
the question are :
what kind of repair service do I need? do I need to send the whole drive or only the pcb?
can you advice me who can do it? for less than the disk price :) ?
Thanks again !
PostPosted: October 4th, 2026, 22:35
It's not likely it's the PCB; but it's possible. The fact the drive turns on and spins suggests the PCB is fine. As a pure guess I would say a firmware, or heads (reading) issue is at play. Firmware is located on the platters.
Regrettably I don't know of credible data recovery companies where you live. This forum is more for data recovery than drive refurbishment.
PostPosted: October 9th, 2026, 15:29
Thank you anyway
Where I live service costs are too high comparing to the disk value..
At my level I can still try to see if something is obviously wrong comparing the ROM dump with the healthy one
If ROM seems ok I can imagine swapping with the healthy pcb
Just to be sure pcb is not the issue
One last question, if rom turns out to be corrupted, is it possible to rebuild it in my situation ?
PostPosted: October 9th, 2026, 16:13
you have 2 drives, one healthy, one faulty, so you have everything you need to perform the basic tests you mentioned (rom compare, pcb swap with rom swap).
You cannot really differentiate between a rom corruption and a firmware issue (most of the firmware is on the platters). It is very unlikely that the drive would spin with a corrupted rom, moreover, there are usually two rom chips with identical content, plus ECC code appended to all rom modules. So it is really not likely to be rom issue.
on the other hand it is more probably a firmware/head/surface problem, which is pretty hard to diagnose without proper tools.
I guess you could check it under linux, looking at kernel logs, or maybe try niagara, but if it doesn't show up in BIOS, i don't expect these to get you anywhere...
Users browsing this forum: Google [Bot], melvin and 83 guests
