The details of why the HD needs replacement can be found in my 1st thread
HERE.
I read an Article about a month ago that said that HGST HD's have been statistically proven to be the most reliable HDs made, and so when I found a
HGST Ultrastar 7K4000 HUS724040ALE640 (0F14683) 4TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Enterprise Hard Drive Bare Driveon sale at NewEgg for $133.00, I thought I found a cheap and easy solution, but the more I researched, and the more I learned, the less "optimal" this HD seemed to be. The label says it was made in June of 2012, and one of the reviews alleges that these HDs were subjected to hard use for years, and then were somehow "zeroed" to appear like they are brand new. They are being sold by NewEgg as brand new.
Prices vary wildly, and a lot of stuff and fluff about what the purpose of the HD is, etc... (I don't believe any of this. I think it's all marketing.)
And because I'm doing lots of research I have a lot of questions about technical characteristics and whether or not they are worth extra money, or not.
Example, for some reason 7,200 rpm seems "right", 5,400 rpm seems "wrong" and 10,000 seems not worth the extra expense, plus it also seems like they would be more prone to failure.
I don't think the write cache matters, since this new HD is going to be one of two in a RAID 1 (mirror) array and I don't care about write or read times since the only purpose it will service is data storage. Note: I will not be running and software from the RAID array, ever.
I care about warranty, and I'm pretty sure I want "NEW" and not refurbed, used or open box. I think SATA II for some reason (vs. SATA I or III), and I think $150 is a reasonable price, because I've seen what appears to be comparable HD's at twice that price.
HGST is supposedly out of business, but somehow was purchased by WD and are still the same old HGST quality despite the WD label (and I'm cynical about this).
Other than that, I have no sense of what brands to either like or dislike. Some of the "Dell" HD's are quite cheap, but no clue what quality they might be.
In terms of budget, I figure I can get a "good enough" replacement for $150.00, but if the technical spec is worth the additional cost, I can pay twice that.
Any help appreciated, and thanks in advance.
