 Post subject: ST4000LM024 repair - power cap values?
PostPosted: November 1st, 2026, 17:31
I would like to repair my HDD to use. There's no important data on it
Got over current warning in dmesg when using a USB to SATA adapter
Opened it up, smelled like magic smoke, a capacitor has de-soldered itself? and is currently making electrical connection to some other components.
1. What's the chance i can salvage it by soldering in a new cap?
2. The TVS diode next to it allows current both ways, should i replace it as well?
3. How do i find values for suitable replacements?
ST4000LM024
PN: 2AN17V-566
Thanks in advance
 Post subject: Re: ST4000LM024 repair - power cap values?
PostPosted: November 1st, 2026, 17:57
Zero. It's a ferrite bead (inductor), not a capacitor. You could replace it with a 2A smt fuse.
https://skylots.org/images/n/2d/722d809c843da4c217a1c8bee72364e3.jpg
Yes. You could leave it out, and the drive will work without it, but you will no longer be protected from overvoltages.
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 76 guests
