 Post subject: Help with Maxtor Detected as ROMULUS
PostPosted: July 9th, 2005, 22:25
One Maxtor 4D080H4 240633 NMCB C2FDA show in BIOS detected as ROMULUS code, so i load in safe mode, and run Load LDR , and select the ldr ,and select Load ROM and Firmware Modules and show me sucefull loading, then i select Standard mode , and no problem, then i select Disk FIrmware Zone and Select Work With Memory buffer and select Memory buffer Writting and no have Proble, Modules was loaded sucefull, then i select check firmware zone and no have problems, but when i set jumper in Master Mode, and Select Standard Mode in no safe mode, show me roadmap error, so im think im making somthing wrong, does any one have an idea.. Thanks for all
 Post subject: Im forgot
PostPosted: July 9th, 2005, 22:29
This is the Status at Check firmware Structure in Safe mode after load the loader ROM and Modules
Selected model : PROXIMA
Identification
Model : Maxtor ROMULUS
FW version: DAH017K0
Min. Cylinder : 611
Max. Cylinder : 58189
_UIL , Configuration module
UBA: 0000, Size: 0001 (RD:û, ID:-, ChkSum:û)
Head amount : 0
USER head map :
SA head map :
Model :
Serial number :
Zone table loaded
# Start Cyl End Cyl SPT
1 611 4212 896
2 4213 7814 871
3 7815 11416 851
4 11417 15018 821
5 15019 18620 806
6 18621 22222 784
7 22223 25824 756
8 25825 29426 728
9 29427 33028 696
10 33029 36630 672
11 36631 40232 640
12 40233 43834 610
13 43835 47436 572
14 47437 51037 532
15 51038 54638 497
16 54639 58189 448
17 58195 58244 336
Modules table loaded
Data modules
# PN UBA Size Rd ChkSum Id Comment
1 00 3194 0002 û -
2 01 3196 0002 û û * Tbl_55AA
3 03 3198 0001 û û * Tbl_55AA
4 04 319A 0074 û -
5 05 321A 0001 û -
6 08 321B 0001 û û * Tbl_55AA
7 09 321D 0001 û -
8 0A 321E 0001 û -
9 0B 321F 0001 û -
10 0C 3220 0001 û -
11 0D 212C 0003 û û * Tbl_55AA MX_ST_CFG3
12 0E 212F 0008 û û * Tbl_55AA MX_ST_SCRIPT
13 0F 2137 0001 û û * Tbl_55AA
14 10 2138 0002 û -
15 11 213B 0001 û û * Tbl_55AA MX_ST_CFG1
16 12 2255 01FD û û * Tbl_55AA
17 13 213D 0008 û û * Tbl_55AA
18 14 2202 000A û - * Tbl_55AA STRS
19 16 222A 0010 û û * Tbl_55AA
20 18 000C 000A û û AT_PDL - P-List
21 19 016F 0001 û -
22 1A 0170 0001 û û SECU - security table
23 1B 01E3 000A û û AT_POL - G-List
24 1C 0184 0002 û -
25 1D 01E1 0002 û û DMCS - cacheing table
26 1E 016D 0001 û û SRV - calibration adaptives
27 1F 0004 0001 û - DISK - disk ID module
28 20 01ED 0002 û -
29 21 0145 000A û û RCT - data surface adaptives
30 22 0182 0001 û û Settings flasgs
31 2A 3221 0001 û -
32 2B 3222 0001 û -
33 2D 3223 000A û -
34 2F 0171 0001 û - SMART Thresholds
35 30 0172 0001 û - SMART Attributes
36 32 0183 0001 û -
37 33 09B8 1774 û - HUTIL & HUSR - complex defect table
38 37 0000 0001 û û - _UIL U_LIST - SA translator
41 41 0174 0002 û -
42 42 224B 0006 û - * Tbl_55AA
43 43 213A 0001 û û * Tbl_55AA MX_ST_CFG2
44 44 016E 0001 û -
45 45 0176 000C û -
46 46 220C 000A û - * Tbl_55AA OPTI - SelfScan settings
47 47 2216 000A û - * Tbl_55AA STRS
48 48 01E0 0001 û û HDD components information copy
49 49 21F5 000A û û * Tbl_55AA
50 4A 2200 0002 û û * Tbl_55AA
51 4B 30C4 0001 û û * Tbl_55AA
52 4C 213C 0001 û û * Tbl_55AA
53 4D 3199 0001 û û * Tbl_55AA
54 4E 321C 0001 û û * Tbl_55AA
56 54 30C5 0004 û - * Tbl_55AA
57 55 30CD 0002 û û * Tbl_55AA
58 57 30D3 000C û - * Tbl_55AA
59 58 223A 0011 û û * Tbl_55AA
60 5A 320E 0008 û -
61 5B 3216 0002 û -
62 5C 3218 0002 û -
63 5D 322D 0003 û -
64 5F 3230 0001 û û * Tbl_55AA
65 60 30CF 0004 û -
66 61 2667 0001 û û * Tbl_55AA
67 62 2668 0001 û -
68 63 0173 0001 û - SMART attributes copy
69 64 01F0 0001 û - MAXATG
70 65 01F1 0009 û -
71 66 01FA 0009 û -
72 67 0203 0005 û -
73 68 212E 0001 û û * Tbl_55AA
74 69 21E5 0010 û û * Tbl_55AA
75 6A 21FF 0001 û û * Tbl_55AA
76 6B 2220 000A û û * Tbl_55AA
77 70 0288 0001 û - SMART Summary Log
78 71 0289 0001 û - SMART Self-Test Log
79 72 028A 0020 û - SMART Host Vendor Log
80 73 02AA 0008 û -
81 74 3231 0001 û -
82 75 3232 0001 û -
83 76 3233 0001 û -
84 78 0005 0007 û û RZTBL - zone table
85 79 3234 0001 û -
86 7A 418B 0001 û û U_LIST - SA translator copy
87 82 3235 0002 û - * Tbl_55AA
88 83 3239 0004 û - HDD components information
89 84 323D 0001 û -
90 85 323E 0001 û -
91 86 323F 000A û -
92 87 3249 0001 û -
93 88 324A 0001 û -
94 89 324B 0005 û -
95 8A 3250 0002 û -
96 8B 3252 0002 û -
97 8C 266A 0052 û - * Tbl_55AA
98 8E 3254 0001 û -
99 8F 3255 0004 û -
100 90 26C0 00A0 û - * Tbl_55AA
101 93 02BA 0080 û û
102 9B 2760 0004 û - * Tbl_55AA
Loadable ROM
ROM image readed, chk. sum. correct (6FFC)
UBA : 0518; Version : AD0H71ZK; ID : HOSTDISKROM
Overlays
# UBA Rd Id ChkSum
03 0618 û û û
04 0638 û û û
05 0658 û û û
06 0678 û û û
07 0698 û û û
08 06B8 û û û
09 06D8 û û û
0A 06F8 û û û
0B 0718 û û û
0C 0738 û û û
0D 0758 û û û
0E 0778 û û û
0F 0798 û û û
10 07B8 û û û
11 07D8 û û û
12 07F8 û û û
13 0818 û û û
14 0838 û û û
15 0858 û û û
16 0878 û û û
17 0898 û û û
U_LIST : SA defects not found
Security system information
 Post subject: Re: Im forgot
PostPosted: July 10th, 2005, 23:40
Identification
What F/W version is written on the label?
PostPosted: July 11th, 2005, 0:14
The FW version in label its DAH017K0 , its a i have make test for check SA surface errors and no have errors,
Thanks for u help and time
PostPosted: July 11th, 2005, 0:50
Module 1F is damaged. You can write this module from another Maxtor drive of the same model.
Just don't forget to make a backup of this module first.
PostPosted: July 11th, 2005, 6:48
Before you do this - check your family selection.
Romulus or Proxima as you seem to have selected ?
 Post subject: Thanks all !!
PostPosted: July 11th, 2005, 9:37
Hy guys
Its working now like fujimax says i has select familty incorrect this family its Romulus so , i make all procedure selecting Romulus And now the hard disk alive !!!
Thanks for all :o
Sinceraly
Alberto
 Post subject: Re: Help with Maxtor Detected as ROMULUS
PostPosted: May 6th, 2006, 16:45
[BIOS detected as ROMULUS code, so i load in safe mode, and run Load LDR, what program to load it..? plz help me... i get maxtor romulus to, thank's
Users browsing this forum: Google [Bot], Rendersmith and 122 guests
