 Post subject: A troublesome MPG3409AT
PostPosted: May 16th, 2004, 19:42
On arrival this fuji rustled and could not address with some utilities.
In HDDL found HS : 48 53 02 02 00 01 FF FF
and corrected to ram & hdd with : 48 53 04 04 00 01 02 03.
After switch off the drive was seen and scanned correctly in MHDD and all modules checked out fine. Proceeded with the data extraction in dos copy and all went fine to about 5% when drive just stopped.
So back to HDDL and found HS : 48 53 02 02 00 01 FF FF ... mmmm.
Repeated HS correction in HDDL - but this time drive will not accept
correct HS to HDD surface.
will report on any success if it occurs.
Users browsing this forum: No registered users and 102 guests
