 Post subject: I have a problem!
PostPosted: June 13th, 2005, 12:44
my disk is locked by ata password and I forgot the password!
I want to unlock the disk,but I failed.
I do it as below:
I use "unlock" command,and choose 0,then, entered the password "111".MHDD display: "Fail".
I use "EID" command,and it display:
IC25N040ATMR04-0 LBA:78,140,160
SN:MRG259KBJ82U5H FW:M020AD4A CACHE:1740KB
Supports: LBA48 HPA AAM LBA MS16 DMA(UDMA5,MWDMA2)
SMART:Enable SelfTest:Supported EoorLog:Supported
Security:MAX, ON. Size = 38254 MB
Warning:this drive is locked by ata password
I used the ThinkPad of IBM operation the disk.what can I do?
my email:stoneclever_1982@yahoo.com.cn
thank you!
 Post subject: Re: I have a problem!
PostPosted: June 14th, 2005, 11:38
opsss thats a big thing to forget :wink: Better to put it back in your laptop and try to remeber some key words you may have used. Other than that you can make it into a nice coaster for your tea/coffe cup :o
I do it as below:
thank you!
 Post subject:
PostPosted: June 14th, 2005, 12:06
I remember the password,and I confirm that it is "qqqqqq".
I ever access the disk by the password.
but one day, I installed the disk to another computer, entered the password and could not access the disk,and then I reintall the disk to my notebook by which I set the ATA password.but, I also can't access the disk by the password.
So I want to remove the password.Can you tell me What can I do?
 Post subject:
PostPosted: July 24th, 2005, 13:32
do not forget that passwords are 32 symbols ALL THE TIME
if you entered "qqq" it will probably be replaced by "qqq+29 spaces" or something
Users browsing this forum: No registered users and 195 guests
