 Post subject: Help Recover NTFS on External Laptop Drive with Linux
PostPosted: May 15th, 2015, 1:59
hi
can someone direct me to a guide for recovering an ntfs volume?
the drive can mount, and reports nearly full, but appears to be empty in file-manager.
it's an external usb ntfs-formatted 500 GB HD. Last time i checked, the disk had a couple hundred GB of files on it (but NOT almost full as now reporting).
now all the files are gone, and the drive reports "68 GB" free. the partition is visible, but it's empty.
really appreciate any help, these are my only backups of some important files.
at first, gparted info reported "cluster accounting failed".
then i tried the following:
# e2fsck -n /dev/sdb1
e2fsck 1.42.8 (20-Jun-2013)
ext2fs_open2: Bad magic number in super-block
e2fsck: Superblock invalid, trying backup blocks...
e2fsck: Bad magic number in super-block while trying to open /dev/sdb1
The superblock could not be read or does not describe a correct ext2
filesystem.  If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
# ntfsfix /dev/sdb1
Mounting volume... OK
Processing of $MFT and $MFTMirr completed successfully.
Checking the alternate boot sector... OK
NTFS volume version is 3.1.
NTFS partition /dev/sdb1 was processed successfully.
# fsck /dev/sdb1
fsck from util-linux 2.21.2
fsck: fsck.ntfs: not found
fsck: error 2 while executing fsck.ntfs for /dev/sdb1
# fsck /dev/sdb
fsck.ext2: Superblock invalid, trying backup blocks...
fsck.ext2: Bad magic number in super-block while trying to open /dev/sdb
# ntfsfix /dev/sdb
Mounting volume... NTFS signature is missing.
FAILED
Attempting to correct errors... NTFS signature is missing.
FAILED
Failed to startup volume: Invalid argument
Trying the alternate boot sector
Unrecoverable error
Volume is corrupt. You should run chkdsk.
after the above, and before mounting the drive, gparted displays an exclamation icon and says:
Unable to read the contents of this file system!
Because of this some operations may be unavailable.
The cause might be a missing software package.
The following list of software packages is required for ntfs file system support: ntfsprogs / ntfs-3g.
but, i can mount it. after mounting, gparted says:
thx!
Users browsing this forum: Google [Bot], michael chiklis and 270 guests
