 Post subject: Seagate baracuda ST3160012a
PostPosted: January 25th, 2006, 15:44
I am having a problem this Hard drive, when I format it and transfer My files using seagate wizard I get missing NTLDR errors this also happens when I format and put a fresh copy of XP
Any ideas
Checks out OK with Seagates tools for hardware but fails critical errors Metadata file records
Des
 Post subject:
PostPosted: January 26th, 2006, 16:11
put here log from disk terminal
Interface task reset
1024k x 16 buffer detected
PUMA - 1_Disk    0.07  09-28-04 16:58
Head Mask FFFF - Switch to full int.
              Spin Ready
3.00  09-28-04 17:00
(P)SATA Reset
SATA core D1 Yuma 6192 No LED Native mode
T>
T>/1
1>H2
Command Inactive - No VALID Cert Code Detected
1> VALID Cert Disk Code Detected - Revision # .082
:oops:
Users browsing this forum: WebClaw and 268 guests
