 Post subject: how to eliminate sector with access time over 50ms?
PostPosted: March 1st, 2006, 18:34
i would like to find out a solution or tool that is able to select the first 20 million sectors where the access time is under 50ms. it has to be able to determine that the maximum capability to be used is 10gb.
thank you so much in advance.
i hope to hear some solutions really soon! :D
love,
Talita
eu gostaria de descobrir uma solução ou ferramente que seja capaz de selecionar os primeiros 20 milhões de setores onde o tempo de acesso seja menor que 50ms. ela tem que ser capaz de determinar que a capacidade máxima a ser usada é de 10gb.
muito obrigada, desde já.
espero ouvir algumas soluções em breve! :D
com amor,
Talita
 Post subject:
PostPosted: March 1st, 2006, 22:15
If you want to cut the drive, you may use MHDD (commands CONFIG or HPA).
Dmitry
 Post subject: more hints?
PostPosted: March 1st, 2006, 23:20
what about pc3k... does it have a way to do that?
 Post subject:
PostPosted: March 2nd, 2006, 16:33
yes of course.
do you have pc3000? :D
 Post subject: i do! but...
PostPosted: March 2nd, 2006, 16:41
the sectors are on the beggining of the disc... can pc3000 do something for me?
 Post subject: Hi
PostPosted: March 5th, 2006, 13:42
Hi Talyta which your address e-mail ?
Users browsing this forum: Bing [Bot] and 207 guests
