 Post subject: MAXTOR 541DX MODEL 2B020H1
PostPosted: November 18th, 2005, 15:58
HDA 11B PCBA 06A UNIQUE 32A CODE WAH21PB0
MODEL MAXTOR ATHENA
FIRMWARE WAH21PBZ
MHDD SCAN !!!! IN 100%
It is a problem of firmware?
how to jumper for mode to save?
with the tool of salvation it decides this problem?
It can help me?
 Post subject: Original plate is bad
PostPosted: November 18th, 2005, 16:05
it is with another plate
 Post subject:
PostPosted: November 18th, 2005, 16:43
it seems like FW problem. I don't use Salvation, so I don't have opinion about it.
what does 'it is with another plate' mean?
PCB?
 Post subject: yes another one PCB!
PostPosted: November 19th, 2005, 7:11
PCB?
 Post subject:
PostPosted: November 19th, 2005, 10:11
If U are sure the donor PCB is from the same FW version as the patient drive, it may be a disk FW corruption also.
but first make sure that U found a matching board by the HDA, PCBA and UNIQUE codes.
 Post subject: ok!!!
PostPosted: November 19th, 2005, 16:28
 Post subject: It Worked for me
PostPosted: November 19th, 2005, 16:51
Salvation worked for me demo is good. tried on 2 disk 1 was recovered but 2second :(
go for demo
8)
 Post subject: Re: MAXTOR 541DX MODEL 2B020H1
PostPosted: November 25th, 2005, 17:42
The problem is the Fw....
Use PC3000 to record the fw (MODULE)..
Type safe your HDD jumper.
Before you record the fw, just see the firmware structure, check the : CSR in LDR.
just write the firmware and Module group (*.rpm and *.smb).
regards,
Along
HDD is a COMPUTER...
PostPosted: November 26th, 2005, 5:21
:) that's an easy way to kill a drive :)
 Post subject: right
PostPosted: November 26th, 2005, 5:52
Yes,
pepe is right !!
Write only the corrupted modules.
regards
PostPosted: November 26th, 2005, 9:50
regards,
Along
decided problem!
Thanks!!
 Post subject:
PostPosted: November 26th, 2005, 16:06
that's good, we are happy now! ;)
 Post subject:
PostPosted: January 20th, 2006, 4:28
please can you send me pc3000 in english or french please merci
maamar.guenfoud@club-internet.fr
 Post subject:
PostPosted: January 20th, 2006, 7:58
repairing HDD is not as easy as You Think.
First you must to understand How HDD work then you can repair it...
but The most important is Know what make the HDD become problem.
if it is problem is F/w Not just rewrite it will be OK..
A bad decision in writing the Module will make the drive become worst.. and difficult to repair it anymore....
 Post subject: Re: right
PostPosted: January 20th, 2006, 18:01
gurudev wrote:
Yes,
pepe is right !!
regards
Ah, even that can break the drive - better still ..
write only the necessary corrupted mods and even then...
maybe some screen says a mod is corrupted when it is in fact not.
so yes this is why it is not so easy - agreed...
Users browsing this forum: Bing [Bot] and 298 guests
