 Post subject: MK4025GAS
PostPosted: February 20th, 2006, 1:54
this drive is an MK4025GAS. It clicks but not that regular clicking as if it had a bad head, but hits the limiter bumper really hard, like a hammer.
I changed the board from the same model, but another FW version (I didn't expect too much : ), now it has the regular clicking sound.
If I put the patient board onto the donor, the same symptoms arise, regular clicking sound.
does anybody had similar problem?
 Post subject:
PostPosted: February 20th, 2006, 5:33
PCBs on Toshiba drives are not interchangeable.
The firmware or the heads could be at fault or even the spindle (very common in these drives).
 Post subject:
PostPosted: February 20th, 2006, 7:27
thanx for the reply!
I know that, I exchanged the external flash rom of course.
But let's forget about board replacement, the main problem is the inregular hard knocking.
thanx for any help.
 Post subject:
PostPosted: February 20th, 2006, 8:32
If you are still getting knocking from the drive and there is no platter damage I would presume that a head change is in order.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 88 guests
