 Post subject: how to repair samsung m/c error
PostPosted: February 21st, 2006, 5:19
hi friends,
Did any body knows , how to add m/c bad sector of samsung drive to m/c defect table?
hutil show error AJ48
does any body face this problem?
also tell
does any body solve this problem?
please help
thanks
PostPosted: February 23rd, 2006, 4:20
hi
i think nobody faces or solved THIS PROBLEM OF SAMSUNG HDD
FOUND SOMETHING ON IT...
TRY WORK WITH ME, SHARE PROBLEM &SOLUTION ON IT.I THINK WE WILL SOLVE IT .
I FOUND SOME THING I AM SHARING IT .....
MAINTENCE CYLINDER-(READ FAILURE)
1)ERROR IS OCCURRED IN READING MAINTENANCE/CYLINDER OR NO ERROR IS OCCURRED IN WRITING & FORMATTING M/C.PROGERSS PRE-TEST AGAIN OR DOWN LOAD THEN EXECUTE BURN-IN.
2)IF FAILUREIS OCCURRED IN ENTIRE HEAD DURING WRTING OR FORMATTING.CHECK OUT AFTER REPLACING PCBA.
3)IF DEFECT IS OCCURRED .CATCH HOLD OF FAILURE SYMPTOM AND FAILURE DEGREE THEN PROGRESS OPERTAION ,EXECUTE SERVO WRITE CHANGE DISK .(PROCESS IN HEAD OFFICE.)
ALL THIS IS FROM VANGO SERIVCE MANUAL..
THANKS
Users browsing this forum: Majestic-12 [Bot] and 133 guests
