 Post subject: Problem with seagate ST3250823A.
PostPosted: March 3rd, 2006, 13:50
I have this drive, a 250GB seagate. Just today, while I was testing the speed of my drives, I noticed this one was behaving strangly. The smart counters changes every time I inquire them... Another thing: when is in slave mode and I do identification the drive does well the first time, but the others return garbage, and the smart returns nothing. :shock: :shock:
So to see if you can help me with this I saved the log and edited for easier reading.
I'm clueless... Should I be worried? This have never happened to me before with any disk, and this one is mine and contains my information.
Please help me understand this. Thank you.
28:15    | MHDD 4.6 (c) Dmitry Postrigan | FREEWARE
28:15   Changing mode to: IDE
28:28   Changing mode to: IDE
28:28   Device selected: 3
28:39   MHDD>SMART ATT
28:39   Getting SMART attributes...
28:39   SMART READ ATTRIBUTES
28:39   HDD: ST3250823A; FW: 3.02; SN: 3ND0K49X
28:39   --------------------------------------------------------
28:39   SMART attributes:
28:39               Name                        Val Worst Raw
28:39   Att #   1 : Read error rate           :  54   48  130372897
28:39   Att #   3 : Spin up time              :  98   98  0
28:39   Att #   4 : Number of spin-up times   : 100  100  146
28:39   Att #   5 : Reallocated sectors count : 100  100  0
28:39   Att #   7 : Seek error rate           :  81   60  145752404
28:39   Att #   9 : Power-on time             :  96   96  4375
28:39   Att #  10 : Spin-up retries           : 100  100  0
28:39   Att #  12 : Start/stop count          : 100  100  162
28:39   Att # 194 : HDA Temperature           :  32   47  32
28:39   Att # 195 : Hardware ECC recovered    :  54   48  130372897
28:39   Att # 197 : Current pending sectors   : 100  100  0
28:39   Att # 198 : Offline scan UNC sectors  : 100  100  0
28:39   Att # 199 : Ultra ATA CRC Error Rate  : 200  192  34
28:39   Att # 200 : Write error rate          : 100  253  0
28:39   Att # 202 : Unknown                   : 100  253  0
28:40   Att #   1 : Read error rate           :  54   48  130372899
28:40   Att #   7 : Seek error rate           :  81   60  145752409
28:40   Att # 195 : Hardware ECC recovered    :  54   48  130372899
28:41   Att #   1 : Read error rate           :  54   48  130372901
28:41   Att #   7 : Seek error rate           :  81   60  145752414
28:41   Att # 195 : Hardware ECC recovered    :  54   48  130372901
29:02   Att #   1 : Read error rate           :  54   48  130372903
29:02   Att #   7 : Seek error rate           :  81   60  145752419
29:02   Att # 195 : Hardware ECC recovered    :  54   48  130372903
29:02   Att #   1 : Read error rate           :  54   48  130372905
29:02   Att #   7 : Seek error rate           :  81   60  145752424
29:02   Att # 195 : Hardware ECC recovered    :  54   48  130372905
29:03   Att #   1 : Read error rate           :  54   48  130372907
29:03   Att #   7 : Seek error rate           :  81   60  145752429
29:03   Att # 195 : Hardware ECC recovered    :  54   48  130372907
29:04   Att #   1 : Read error rate           :  54   48  130372909
29:04   Att #   7 : Seek error rate           :  81   60  145752434
29:04   Att # 195 : Hardware ECC recovered    :  54   48  130372909
29:04   Att #   1 : Read error rate           :  54   48  130372911
29:04   Att #   7 : Seek error rate           :  81   60  145752439
29:04   Att # 195 : Hardware ECC recovered    :  54   48  130372911
29:05   Att #   1 : Read error rate           :  54   48  130372913
29:05   Att #   7 : Seek error rate           :  81   60  145752444
29:05   Att # 195 : Hardware ECC recovered    :  54   48  130372913
29:05   Att #   1 : Read error rate           :  54   48  130372915
29:05   Att #   7 : Seek error rate           :  81   60  145752449
29:05   Att # 195 : Hardware ECC recovered    :  54   48  130372915
29:06   Att #   1 : Read error rate           :  54   48  130372917
29:06   Att #   7 : Seek error rate           :  81   60  145752454
29:06   Att # 195 : Hardware ECC recovered    :  54   48  130372917
29:07   Att #   1 : Read error rate           :  54   48  130372919
29:07   Att #   7 : Seek error rate           :  81   60  145752459
29:07   Att # 195 : Hardware ECC recovered    :  54   48  130372919
29:07   Att #   1 : Read error rate           :  54   48  130372921
29:07   Att #   7 : Seek error rate           :  81   60  145752464
29:07   Att # 195 : Hardware ECC recovered    :  54   48  130372921
29:15   Att #   1 : Read error rate           :  54   48  130372923
29:15   Att #   7 : Seek error rate           :  81   60  145752469
29:15   Att # 195 : Hardware ECC recovered    :  54   48  130372923
29:16   Att #   1 : Read error rate           :  54   48  130372925
29:16   Att #   7 : Seek error rate           :  81   60  145752474
29:16   Att # 195 : Hardware ECC recovered    :  54   48  130372925
29:18   Att #   1 : Read error rate           :  54   48  130372927
29:18   Att #   7 : Seek error rate           :  81   60  145752479
29:18   Att # 195 : Hardware ECC recovered    :  54   48  130372927
29:19   Att #   1 : Read error rate           :  54   48  130372929
29:19   Att #   7 : Seek error rate           :  81   60  145752484
29:19   Att # 195 : Hardware ECC recovered    :  54   48  130372929
29:20   Att #   1 : Read error rate           :  54   48  130372931
29:20   Att #   7 : Seek error rate           :  81   60  145752489
29:20   Att # 195 : Hardware ECC recovered    :  54   48  130372931
29:40   -------------------------------
29:40   Lap : 1
29:40   LBA scan: 0 to 488397167
30:57   þ LBA Timeout: 10084230
30:57   Last scanned LBA: 10084484
30:57    Blocks <   3ms = 39226
30:57    Blocks <  10ms = 135
30:57    Blocks <  50ms = 185
30:57    Blocks < 150ms = 0
30:57    Blocks < 500ms = 0
30:57    Blocks > 500ms = 0
30:57   No warnings, no errors
30:57   Done
When doing Id changes the size every time and only the first inquire is right, the other ones contains garbage
21:43   MHDD>I
21:43   ST3250823A  LBA: 488,397,168
21:43   SN: 3ND0K49X  FW: 3.02
21:45   MHDD>I
21:45    T 25082 @  LBA: 488,397,168
21:45   SN:            3N  K4 X  FW: 3.02
21:46   MHDD>I
21:46    T 050820@  LBA: 268,173,311
21:46   SN:            3N  K4 X  FW: 3.02
21:49   MHDD>I
21:49    T325082 @  LBA: 268,042,239
21:49   SN:            3N  K4 X  FW: 3.02
21:49   MHDD>I
21:50    T 0 082 @  LBA: 268,042,239
21:50   SN:            3N  K4 X  FW: 3.02
21:50   MHDD>I
21:50    T 25082 @  LBA: 488,380,784
21:51   MHDD>I
21:51    T 25082 @  LBA: 488,118,640
21:51   SN:            3N  K4 X  FW: 3.02
21:51   MHDD>I
21:51    T 0 082 @  LBA: 421,009,776
21:52   MHDD>I
21:52    T 25082 @  LBA: 268,173,311
21:52   SN:            3N  K4 X  FW: 3.02
21:52   MHDD>I
21:53   MHDD>I
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 118 guests
