 Post subject: Pasword on hdd ,what can I do?
PostPosted: April 5th, 2006, 17:39
HI,
I have laptop dell C610 and I bought hdd Fujitsu MHR2020AT, but this hdd is locked, my screen show; HDD IS PROTECTED BY A PASSWORD AUTHENTICATION SYSTEM YOU CANNOT ACCESS DATA ON THIS HARD DRIVE WITHOUT THE CORRECT PASSWORD.I Want delete all disk and I want using this hdd, but I can't.Mhdd not recognize this hdd.What can I do?
BEST REGARDS,HENI
PostPosted: April 6th, 2006, 10:55
maybe you could try making an inductor around the whole harddrive...
but you will need many many turns...
PostPosted: April 6th, 2006, 11:43
 Post subject: Re: Pasword on hdd ,what can I do?
PostPosted: April 7th, 2006, 1:27
heni wrote:
HI,
BEST REGARDS,HENI
do u need ur data ?? where r u live??
PostPosted: April 7th, 2006, 3:59
from Poland
PostPosted: April 7th, 2006, 4:33
Hi heni,
Friend, as you said ....
If hdd is password protected ...mhdd recognize it ...
and it show PWD ON also..
you need to checK it properly..
PostPosted: April 7th, 2006, 12:22
I check it, and I even change mhdd.cfg and nothing. it's same.Mhdd send always ''drive is not ready''.I don't know what I doing wrong!!.
PostPosted: April 7th, 2006, 12:35
first try a good drive to make sure U are connecting things correctly.
make sure the drive is jumpered as master.
If the patient drive is indeed locked and doesn't have other defect, it should be identified OK, and U should see a 'HPA lamp' on the top of the screen.
As I saw the master PWD is set to 32 spaces, so if the security level is high, U should be able to do security erase if the master PWD hasn't been changed.
regards,
PostPosted: April 7th, 2006, 13:17
I have similar hdd, but MHN2200AT good drive, same capacity, I put to laptop all is ok.MHDD recognaize propely.Maybe another tools I must use.
I'm newby on this forum and I work on MHDD about 2 hours.
PostPosted: April 7th, 2006, 14:16
Did you try reading MHDD manual?
Dmitry
PostPosted: April 7th, 2006, 15:24
I read manual second time and undestand now.
THANKS FOR ALL
BEST REGARDS.HENI
PostPosted: April 11th, 2006, 4:57
hi,
- search allegro.pl for man ( agnieszka) who unlock this drive, cost is 10EU.
:oops:
 Post subject: Hi Heni...
PostPosted: April 19th, 2006, 6:51
Hi Heni...
Hi Poland...
I'm sorry to hear that...
I thing your notebook hdd was lock at ATA PASSWORD, use VICTORIA software to unlock your password hdd.
It's freeware software, You can download it from http://www.hdd911.com, created by : Sergei Kazansky from Russian.
If u are from southeast asia, i can help to solve your problem directly, coz i live in southeast asia (Indonesia).
Think over about your valuable data, If you have more money, just purchace the hardware tools to directly unlock your drive. Do you want learn more about the hardware tools, just searh the home page at http://www.kk-yec.com. The hardware name is "HDD ROCK"
If u have confuse about my explanation, just PM me at : hddprof@yahoo.com
I wanna try to solve your problem as soon as possible.
Best regards,
Along.
HDD is a COMPUTER...
PostPosted: April 27th, 2006, 2:04
need to know master password or use hot swap to unlock.
PostPosted: May 18th, 2006, 9:03
Hi wawalab,
I understand that a master password should allow to unlock HDD, without any data lost (if security level is "high"), but I don't understand what does "hot swap" mean?
Could you give more information or simply specify a link where I could find it?
thanks
Users browsing this forum: Google [Bot] and 75 guests
