 Post subject: MAXTOR ATHENA WAK21R90 541DX B1HS1KFE POKER C.6
PostPosted: April 15th, 2006, 23:09
Would like to know if somebody have the same problems with Maxtor Athena, WAK21R90, 541 DX, Poker C.6.
The bios detects the drive, but can't load the system; also it should not be recognised as Athena but something else as before the problem.
I got a software ware that doesn't (http://www.salvationdata.com/download.htm) work in this specific chip (poker c.6) and another soft here http://pchdd.narod.ru/index_e.htm that should load the new firmware WAK23J8Z but I'm confusing about how to do it, if somebody would tell me maybe could rescue this wonder drive.
PLEASE :horse: :horse: :horse: HELP ME OBIIWAN YOU ARE THE ONLY...
EKKE
 Post subject: Maxtor Athena, WAK21R90
PostPosted: April 25th, 2006, 9:06
this is the Factory Alias for this model of drive.
This situation is caused by a corrupted G-List in the firmware at the negative track in the hard disk.
This failure can be rectified with the re-writting of the G-List.
Email to me and I will mail you the relevant software to flash and the G-List repacemant.
PostPosted: April 25th, 2006, 10:48
John Looi
Same situation too. Please queue me too on your action- :!: Thanks!!
BTW, email me to: vsc.at.repairman.com
tank you again
PostPosted: April 25th, 2006, 13:23
I think that MHDD will be able to help you realise the real problem, if it is correctly recognised by the BIOS. ( I hope I understood you and it is recognised correctly and not as an Athena).
 Post subject: rMaxtor Athena, WAK21R90, 541 DX, Poker C.6.
PostPosted: April 26th, 2006, 18:45
No is not, actually the Drive IS regognaised as his alias MAXTOR ATHENA, sorry Niddo.
PostPosted: April 26th, 2006, 18:51
Hi VSC:
I hope that there would be a solution diferent to use the "Salvation Software", that in intended NOT for the "poker c.6" chip in the pbc.
I tried that software and didn´t work.
PostPosted: April 26th, 2006, 22:39
Hi John Looi: :o
I would like very much to find out how to use your revelant Software, for flashing Firmware.
My e-mail ekklesiadefe@yahoo.com
PostPosted: May 1st, 2006, 4:12
The number on the big Ic is:
Poker C.6
040108200
4370J2
0228S
1972725
PostPosted: May 31st, 2006, 10:08
John Looi
Let me remind you of this forum, would you be so gentle to give me a hand, please. May be you don't have the answer that you expext.
"this is the Factory Alias for this model of drive.
Email to me and I will mail you the relevant software to flash and the G-List repacemant."
Thanks John Looi
 Post subject: At last found the software to Load the firmware HDDRepair
PostPosted: October 16th, 2006, 3:52
Hi Guys:
I found the software to load the firmware for the maxtor Athena in here: _http://arfaizy13.sitesled.com/hddrepair.zip,
You have to follow the instructions given by Borys, in this forum: _http://forum.rpc1.org/viewtopic.php?t=25359&postdays=0&postorder=asc&&start=0&sid=9d826410f7a3b3e41e0139fc9ae1d3ec , found all the instances of Borys, and do it exactly as he says .
But you will find the firmware ( Loader and ram/bin files plus modules)in here: _http://pchdd.narod.ru/maxtor.html
Glory! Enjoy !
PostPosted: October 16th, 2006, 21:15
Banned User
The correct Link is
PostPosted: October 17th, 2006, 2:24
arfaizy13 wrote:
be carefull, Link contains Trojan/malware!!
PostPosted: October 17th, 2006, 9:33
Hi:
The software is call selfscan.exe v 1.1 and unfornutately it contains a trojan, I' would like to know were to download a good one, without the malaware, if somebody knows other link, I would be thankful.
PostPosted: October 18th, 2006, 13:59
Banned User
download from here..i also downloaded from this link..but u must first register to this forum for downloading file
http://www.hddfirmware.net/bbs/index.ph ... wtopic=141
 Post subject: Re: Maxtor Athena, WAK21R90
PostPosted: October 20th, 2006, 10:17
Hi John Looi, I need the relevant software to flas dan G-list replacement. Please e-mail me : qunzil@yahoo.com
Thanks for sharing
PostPosted: October 20th, 2006, 10:26
Use Pc3k isa to repair this kind of drive
PostPosted: October 26th, 2006, 16:36
Hello, this is a link to download Hddrepair containing selfscan, without trojan in it, is ok http://rapidshare.com/files/800382/HDD_ ... 1.rar.html . This software needs the ldr, ram_and_bin, and modules; these :shock: are here http://maxtor-hdd.narod.ru/ and here http://maxtor-hdd.narod.ru/mx_ldr.zip . Have a good time.
PostPosted: October 26th, 2006, 18:38
For a quikly download of Loaders, this link will help http://rapidshare.com/files/808678/mx_ldr.zip.html
PostPosted: November 4th, 2006, 8:04
Anyone have information about HDD Repair V1.1 usage?
Here, trying to repair a G-List of a DiamondMax 8 20 Gb (6E020L0) without success.
Any information would be very appreciated!
Thanks!
PostPosted: November 9th, 2006, 17:01
The ATHENA drives suffer with a common failure, which is firmware damage, and is common in ALL slimline maxtors (ARESC64, N40P, ATHENA) most common reason for failure is the GLIST but the firmware is made of many critical modules any of which can be responsible.
Regardless of any software and firmware fixes available on the internet the only real way to repair this drive is to use PC3000. If you do not have PC3000 or the knowledge behind using it then you need to send your drive to a specialist.
If you intend on repairing the disk, be warned that you will very likely have many bad sectors after repair and is recommended NEVER to use disk for storage again!!
Users browsing this forum: melvin and 47 guests
