 Post subject: Toshiba MK6022GAX problem
PostPosted: April 22nd, 2006, 0:19
Toshiba MK6022GAX:
Hdd starts up and calibrating but not successful, head park in parking zone for 1 minute and starts recalibrating again but unsuccessful. (sounds like bad sector head moving back and forth but not clicking).
Using MHDD the drive does not come "Ready".
Do you think it is the R/W head problem?
or one possible problem is the firmware is actually corrupted.
Thank's guys.
 Post subject: Re: Toshiba MK6022GAX problem
PostPosted: April 23rd, 2006, 9:10
Yes, most likely.
PostPosted: April 24th, 2006, 3:20
No... unfortunately its not the R/W head or preamp.
Head Exchange successfully done but the problem persists.
f/w chip removed and placed to a new board won't work neither.
I suspect the service area is faulty.
Any suggestions guys?
PostPosted: May 9th, 2006, 18:28
I've got same problem.
Overall drive test reported - it's ok, but that's false.
Additionally, i'vefound,that my drive requires some 'heat' actions.. such as scandisk running after startup... after 5-10 minutes of 'overclocking' usage, it starts normal work, not 100%, but 70%...
I'd like to get new one HDD.... but wanna to know what's wrong with this one.
I suppose, that some heads are dead.
OR
Cache chips became corrupted
OR
i've installed wrong drivers (i used only ones supplied with my notebook)
Any other suggestions?
Leo wrote:
Yes, most likely.
do you have any program or method to make me sure in this?
thanx
PostPosted: May 10th, 2006, 6:32
Got it working finally, reprogrammed ROM, and replaced the bad RAM.
PostPosted: May 10th, 2006, 7:26
couuld you please describe how have you maked it
and list programs, please!!
thanx
PostPosted: September 9th, 2006, 1:40
Hello
I have some sever problems with the same HD. I have some data in to recover and I would be interested to get the desciption on how you fixed the problem.
