 Post subject: wd800jb spin problem
PostPosted: May 9th, 2006, 6:05
hello to all gurus
i have wd800jb hdd with a problem. When u power the disk it make sound and then motor stops again motor start with sound and again stop. This contineus . what could be the possibility to make it detect and how.
data is not so important. but i cant open the disk.
thanks
DF
PostPosted: May 9th, 2006, 6:11
maybe your firmware is out of order
 Post subject: what to do
PostPosted: May 9th, 2006, 7:35
what could be done to reoair Service area
PostPosted: May 9th, 2006, 15:40
I have similar problem with WD800BB
I heart he's turning on and off few times at the beggining (until OS loaded), I've reinstaled OS - nothing
If I turn on computer and stop them for example in bios for few minutes after that he's working fine (because getting worm?) and after that he's working fine even I reboot system
So the problem occurs when he's turning on first time after some break
I checked power supply and hard drive tape (in both cases plug another ones)
I checked different hard drive, he's working good
S.M.A.R.T parameters are looking OK
what else can I check and how ?
Users browsing this forum: Google [Bot] and 49 guests
