 Post subject: Samsung SV4012H
PostPosted: June 11th, 2006, 10:20
Hi.
I'm having a big problem with my hard disk, without any reason it spins down after a loud 'click' sound, then Windows freezes for a 10 seconds. Sometimes everything comes back to normal, but normally I get a BSOD with MACHINE_CHECK_EXCEPTION and error: 0x0000009C (0x00000004, 0x80545FF0, 0xB2000000, 0x00070F0F).
Here's log from MHDD:
11.06.2006  13:02:21
11.06.2006  13:02:21
11.06.2006  13:02:21    | MHDD 4.6 (c) Dmitry Postrigan | FREEWARE
11.06.2006  13:02:21   Changing mode to: IDE
11.06.2006  13:02:26   Changing mode to: IDE
11.06.2006  13:02:26   Device selected: 1
11.06.2006  13:02:29
11.06.2006  13:02:29   MHDD>HELP
11.06.2006  13:02:49
11.06.2006  13:02:49   MHDD>SCAN
11.06.2006  13:02:49   SAMSUNG SV4012H  LBA: 78,242,976
11.06.2006  13:02:49   SN: 0569J1DW411209  FW: RM100-08
11.06.2006  13:03:02   Scan started
11.06.2006  13:03:02   MODE: IDE
11.06.2006  13:03:02   Device: SAMSUNG SV4012H
11.06.2006  13:03:02   F/W: RM100-08
11.06.2006  13:03:02   SN: 0569J1DW411209
11.06.2006  13:03:02   -------------------------------
11.06.2006  13:03:02   Lap : 1
11.06.2006  13:03:02   LBA scan: 0 to 78242975
11.06.2006  13:27:45   Time spent: 00:24:41
11.06.2006  13:27:45    Blocks <   3ms = 2144
11.06.2006  13:27:45    Blocks <  10ms = 299895
11.06.2006  13:27:45    Blocks <  50ms = 4796
11.06.2006  13:27:45    Blocks < 150ms = 1
11.06.2006  13:27:45    Blocks < 500ms = 0
11.06.2006  13:27:45    Blocks > 500ms = 0
11.06.2006  13:27:45   No warnings, no errors
11.06.2006  13:27:45   Done
11.06.2006  15:57:06
11.06.2006  15:57:06   MHDD>SCREENSHOT
11.06.2006  15:57:11
11.06.2006  15:57:11   MHDD>HELP
11.06.2006  15:57:54
11.06.2006  15:57:54   MHDD>SMART ATT
11.06.2006  15:57:54   Getting SMART attributes...
11.06.2006  15:57:54   SMART READ ATTRIBUTES
11.06.2006  15:57:54   HDD: SAMSUNG SV4012H; FW: RM100-08; SN: 0569J1DW411209
11.06.2006  15:57:54   --------------------------------------------------------
11.06.2006  15:57:54   SMART attributes:
11.06.2006  15:57:54               Name                        Val Worst Raw
11.06.2006  15:57:54   Att #   1 : Read error rate           : 100  100  1
11.06.2006  15:57:54   Att #   4 : Number of spin-up times   :  98   98  2147
11.06.2006  15:57:54   Att #   5 : Reallocated sectors count :  98   98  6
11.06.2006  15:57:54   Att #   7 : Seek error rate           : 253  253  0
11.06.2006  15:57:54   Att #   8 : Seek time performance     : 253  253  0
11.06.2006  15:57:54   Att #   9 : Power-on time             :  98   98  1419719
11.06.2006  15:57:54   Att #  12 : Start/stop count          :  99   99  1356
11.06.2006  15:57:54   Att # 194 : HDA Temperature           : 169  127  23
11.06.2006  15:57:54   Att # 197 : Current pending sectors   : 253  253  0
11.06.2006  15:57:54   Att # 198 : Offline scan UNC sectors  : 253  253  0
11.06.2006  15:57:54   Att # 199 : Ultra ATA CRC Error Rate  : 100  100  0
11.06.2006  15:57:54   Att # 200 : Write error rate          : 100  100  0
11.06.2006  15:57:54   Att # 201 : Unknown                   : 100  100  0
11.06.2006  15:58:17
11.06.2006  15:58:17   MHDD>EXIT
11.06.2006  15:58:17   MHDD: Exit
and here's screenshot, You can see a pattern of '.' symbols. They are '<50ms' blocks.
[PRE]
50 ERR INDX CORR DREQ DRSC WRFT DRDY BUSY        AMNF T0NF ABRT IDNF UNCR BBK 00
[SAMSUNG SV4012H       ] [   78,242,976] [   78,242,975] [  EST:   **:**:**  ]
±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±  ACT [ 13361 kb/s]
±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± ° <3ms  : 2144
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±± ± <10ms : 299895
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±± ˛ <50ms : 4796
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±± Ű <150ms: 1
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±± Ű <500ms:
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±± Ű >500ms:
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±± ? TIME :
±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± x UNC  :
±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± ! ABRT :
±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± S IDNF :
±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± A AMNF :
±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0 T0NF :
±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± * BBK  :
±±±±±±±±±±±±±±±±±±±±±±±±±±˛±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± [100.0% ]  [100.0% ]
| Take a screenshot : <F10>                                         | 15:57:06
[/PRE]
Any suggestions, what's happening?
 Post subject:
PostPosted: June 11th, 2006, 14:10
I do not think its a HDD problem... HDD looks fine
 Post subject:
PostPosted: June 11th, 2006, 14:22
Ok, so I'll check cables, maybe there's something wrong with connectors...
 Post subject:
PostPosted: June 12th, 2006, 11:58
Cables are ok, everything seems to be ok, but disk is still freezing. It goes something like this: HD spins down, Windows freezes, loud click sound, platters spins down and then up again, another loud click, platters spinning down and up and so on till a BSOD appear.
Could it be serious? For now it is still possible to fully acces disk but for how long it will work...
 Post subject: change power supply
PostPosted: June 12th, 2006, 13:59
it seems to be power supply problem. remove power from hdd and refix it again else change smps
DF
 Post subject:
PostPosted: June 12th, 2006, 16:38
it might be that the power connector has bad contact, try to make the slots thinner in the connector (on the cable) with a small screwdriver.
_____
IooooI
regards,
 Post subject:
PostPosted: June 14th, 2006, 6:58
Thanks for replies! I'll try that.
BTW it's possible that it actually could be power supply problem. I've disconnected on of my CD-ROMs and now system is more stable...
Thanks again
Users browsing this forum: gps31, Mikippp and 89 guests
