 Post subject: 6Y120LO
PostPosted: June 4th, 2006, 16:42
6Y120LO
N,M,B,D
YAR41BWO
M6FYA
Does anybody have *.rpm files for this drive?
Thanks.
 Post subject: Re: 6Y120LO
PostPosted: June 5th, 2006, 3:25
trubarevacki wrote:
6Y120LO
N,M,B,D
YAR41BWO
M6FYA
Thanks.
Not enough information .
6Y120LO051021 Like. Ser number as well.
PostPosted: June 5th, 2006, 9:56
http://files.hddguru.com/index_en.html
http://www.sluzhebka.com
PostPosted: June 5th, 2006, 16:38
6Y120LO032611
N,M,B,D
YAR41BWO
M6FYA
Y356RKYE
Thanks.
PostPosted: June 6th, 2006, 2:32
Why and serial?
 Post subject: To Samo
PostPosted: June 6th, 2006, 3:48
Second character of the ser. number shows the number of heads. There are 2-head and 3-head drives of this model.
 Post subject: Re: To Samo
PostPosted: June 6th, 2006, 3:54
True, but also there are and other place where you may understand this.
Also i think you are a bit wrong. 6Y0800L0 have 2 and 3 heads model
6Y120L0 have 3 and 4 heads models.
PostPosted: June 10th, 2006, 16:01
do you have modules for my drive?
PostPosted: June 12th, 2006, 4:21
Maybe you don't need any...
Try first to find out which module is damaged. Maybe the second copy is good...
PostPosted: June 12th, 2006, 16:19
After succesful loading of M6FYA.ldr: :arrow:
Checking of disc FM structure:
Can not read anything..., :cry:
and then:
SA surface checking:
DATA, copy1 ; UBA = $0008 ; size = $05dc
kolicestvo defektov : 1 :evil:
UBA 8 Err : 00h
OVL, copy1 ; UBA = $05e4 ; size = $1140
kolicestvo defectov : 0
SELFSCAN ; UBA = $1f56 ; size = $12c0
SWAP1 ; UBA = $3216 ; size = $0a28
SWAP2 ; UBA = $3c3e ; size = $0190
DEFECT LOG ; UBA = $1724 ; size = $0832
kolicestvo defectov = 0
DATA, copy2 ; UBA = $3e40 ; size = 05dc
kolicestvo defectov = 0 :!:
OVL, copy2 ; UBA = $441c ; size = 1140
ULIST, copy1 ; UBA = $0000 ; size = 0008
ULIST, copy2 ; UBA = $af68 ; size = $0008
What do you think?
Thanks.
PostPosted: June 12th, 2006, 17:50
Bad disk module.
DataRecovery.bg
PostPosted: June 13th, 2006, 5:00
Module 00080001.rpm is damaged - Disk passport. Copy 2 is OK so you can read 3e4005dc.smb , cut the first 512 bytes and put them in file named 00080001.rpm (it should start with DISK). Write the module to the SA of the drive. Turn off / turn on. Voila.
PostPosted: June 15th, 2006, 16:53
Thank you very much.
Users browsing this forum: Google [Bot] and 281 guests
