 Post subject: WD 800UE SCORPIO
PostPosted: July 27th, 2006, 21:22
Hi guys, i have troubles with
WD800UE-00HCT0
DATE: 21 MAY 2005
DCM: HYNTJBNH
LBA 156301488
80.0 GB
the problem is the hdd dont work , in the bios say
WD ROM MODEL-SCORPIO--
20.0GB
how to fix this error ?
i have run the MHDD, and in the detected info this:
WDC ROM MODEL-SCORPIO-- LBA: 39,070,081
SN: WDC-ROM SN# XYZ---- FW: 09.07D09 CACHE:2048KB Size = 19077MB
Init drive: [recal]
! ERROR: Drive not responding or operation canceled
Any have idea how to fix this hdd?
how to rebuild the ID for correct this error?
or link to read how to
thanks guys.
 Post subject:
PostPosted: August 5th, 2006, 17:02
Same Drive I got but 60 GB
Same Problem I face.
Can anybody know the solution ?
 Post subject:
PostPosted: August 6th, 2006, 6:54
Use Pcek isa to chk modules and repair them . or check the SA for err
 Post subject:
PostPosted: August 8th, 2006, 2:27
Don't have pc3000. Is there any OEM Firmware for this Drive.... ?
 Post subject:
PostPosted: August 8th, 2006, 8:58
If drive not clicking, then drive has bad System Area
This is new WD drive with Marvell MCU, PC3000 for ISA cannot do it
only PC3000 for Windows can do
If you have not PC3000 for Windows - drop drive into garbage
Users browsing this forum: No registered users and 369 guests
