 Post subject: ST3300831A PCB issue
PostPosted: September 24th, 2006, 15:05
I've got an issue with my Seagate HDD like some others also have.
When connecting the drive to the PC it hangs. Also if connecting to an
external power supply control LED of supply is flashing.
So it seems TVS is shortened. (I don't know anything, but read a couple
of times about it ,-) )
Before i found this website and forum i bought a new drive, because
i thought i could replace the PCB.
But when replacing it on defect drive with the new on, i only hear
clicking sounds.
But know i read so many about different pcb versions, also on
same model, and firmware versions.
Seems i need your help.
1) Does anybody have a schematic diagram for this model's pcb?
I want to ask a friend to help replacing the tvs.
(I'm not doing the welding. He's the expert)
2) Or: can i use the new PCB to try to get the HDD running to safe data?
and how?
Firmware versions:
defect HDD: 4.40
"new" HDD: 3.06
thanks in advance
jones :-)=
PostPosted: September 25th, 2006, 1:29
for barracuda hdd if u need to replace the PCB u need to have the same
model no and firmware no if the pcb is not the same the hdd starts clicking .
PostPosted: September 25th, 2006, 8:54
hi rameez,
thanks for your reply.
if you're talking about model no, do you mean model no of the hdd
or of the pcb?
The new disk i bought is the same model, but different origin country.
Any way to update the PCB with new Firmware version?
regards
jones .-)=
PostPosted: September 25th, 2006, 9:27
found a good link for seagate's pcb compare:
http://www.iswamp.com/library/Seagate-PCB.pdf
question about firmware change still open. ,-)
jones
PostPosted: September 25th, 2006, 10:26
Sorry
DataRecovery.bg
PostPosted: September 25th, 2006, 15:31
Banned User
or of the pcb?
regards
jones .-)=
he means the same model no. not pcb no.
u must have same PCB to apply on ur defective hdd with same model and fw..compare the defective hdd's PCB and new hdd's PCB physically..
PostPosted: September 26th, 2006, 10:19
u can update the fw but u need pci for that .
PostPosted: September 26th, 2006, 11:03
seems too complicated to me ,-)
i will try to get an identical pcb.
meanwhile i'll try to fix the defect one, replace tvs...
does anybody know a good source to look for pcbs?
germany preferred.
thx
jones .-)=
PostPosted: October 9th, 2006, 5:48
does anybody have a circuit diagram for this PCB?
regards
jones :-)=
Users browsing this forum: No registered users and 85 guests
