 Post subject: Seagate malfunction problem
PostPosted: October 2nd, 2006, 5:04
Hi. all need advice how to repair this seagate:
Selected family : barracuda 7200.7
selected Model : ST380011A
Model by ID : <HDD ID NOT READ>
Detection of HDD COM port baud rate : 9600
check in terminal :
Interface tesk reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 0000 - Switch to full int.
Spin Ready
3.06 10-21-03 15:53
(P) PATA Reset
Master
any suggestion what terminal code do I need to examine the problem ??
Best regards
Tony Heryanto
PostPosted: October 2nd, 2006, 5:57
So far terminal report looks good.
Try Scan in MHDD and report.
PostPosted: October 2nd, 2006, 6:04
Hi tonyht,
I do not see a problem here.
Drive must be OK
DataRecovery.bg
PostPosted: October 2nd, 2006, 6:20
Dear CoffeeBean & Samo,
here is the result checking on some software :
MHDD : don't see any harddrive (I put is as secondary master), ty to init drive : this message appear " This device does not support LBA mode, MHDD will not work with the device"..
Victoria : Not see any harddrive ( I run mhdd and victoria from CD), try to init : this message appear : " Drive not say DRSC, DRDY or not remove BUSY cannot working
HDAT2 : Software hang while trying to detect the drive..
so.. any advice ???
PostPosted: October 2nd, 2006, 6:33
Post reply for
Edit: you cannot work with ATA if before this you use terminal
DataRecovery.bg
PostPosted: October 2nd, 2006, 6:54
On terminal : " ' "
Cmd Cyl Hd Sct Cnt Stbuf Segl Ssct Sbuf Actv Ercd Rtry Flags
Rd 070FD 00 0007 7FFF 007F 07 020C 09B0 Y 00 9F75.2F.40 40
terminal : " . "
Pgm=00 Trk=108C4(10944).0(0).21F(15B) Zn=A Err=00 Erct=0000 Hlth=0018 Chlth=0000 Ready LBA=086951D
terminal : ";"
Age=50 Type=21 MxCyl=16358 MxHd=1 MxSct=44C BSz=0000 Tcode=0000
best regards
Tony heryanto
PostPosted: October 2nd, 2006, 7:30
Read vendor track - maybe some errors here.
PostPosted: October 3rd, 2006, 5:14
Dear coffeebean
any advice how to read vendor track ?
Tony heryanto
PostPosted: October 3rd, 2006, 6:06
...Drive not say DRSC, DRDY or not remove BUSY cannot working
It stay BUSY or ?
Try to examine the STUFF.
DataRecovery.bg
Users browsing this forum: No registered users and 76 guests
