 Post subject: I need help whit WD800BB SABRE ROM MODEL
PostPosted: February 13th, 2006, 16:37
I have problems with this disk.
With PC3000 PCI it sends message to me "WD tecno key error", I have tried to change the PCB but I do not work. I do not have tools to open the disc or to make change of head.
They can give a solution me, thanks
 Post subject:
PostPosted: February 14th, 2006, 13:42
Now is it WD, or Maxtor?
Since Sabre is maxtor.
BTW why don't U ask at ACElab's forum if U have the tools?
 Post subject:
PostPosted: February 14th, 2006, 15:17
It's a WD Sabre - they make one 2.
 Post subject:
PostPosted: February 14th, 2006, 19:03
oops, maybe I am missing some info...?
 Post subject:
PostPosted: February 14th, 2006, 23:37
the disc is a Digital Western Caviar Model wd800BB-88jhc00. But the disc in the bios is recognized like "WD SABRE ROM MODEL" with 40GB capacity, when this it is of 80GB. Later is inaccessible, is very similar to the problem with the maxtor when the bios recognize them like calypso, ares, etc..
Please Help me...
 Post subject:
PostPosted: February 22nd, 2006, 2:26
hi ML,
do you check it with MHDD WHAT did it show ?
try use it DIRECT PORT ACCESS, bypass BIOS ..
MAY BE HPA SET TO 40GB......
IF HPA SET SHOW HPA IN MHDD ....
TRY NHPA COMMAND TO SET HDD ON FACTORY HPA SETTING.....
THANKS
 Post subject:
PostPosted: February 24th, 2006, 8:42
The drive cannot initialize fully and it reports only the drive model (information stored in ROM, not in Service Area). MHDD cannot help in this case.
 Post subject: re
PostPosted: March 8th, 2006, 18:30
i have a solution
contact me on pm for deatails
 Post subject: Re: I need help whit WD800BB SABRE ROM MODEL
PostPosted: March 11th, 2006, 4:49
"WD tecno key error"- SuperOn send error, possible You use utility not for this drive
You must use PC3000 PCI WD Marvell utility
"WD SABRE ROM MODEL" - SA initialize error, it`s not fully initialize mode or "safe" mode, like in Maxtor drives, however for these WD-drives loader not need
99% that PCB is good
 Post subject:
PostPosted: March 20th, 2006, 10:52
Zdarovje dla vsjoch, samije bolsije servismani. Ja iz Czechiji. Izvinites mena za etu specijalnuju formu ruskovo jazyka, ja ponimaju choroso po russki, no dla mena est ocen slozno pisat azbukoj.
U menja HDD WD800BB-55JKA0. BIOS ego detekujet kak WDC ROM MODEL--SABRE--.
Na etom HDD nikakije data, kotoryje dla mena vaznyje, no jest menja zalko etot HDD vygnat. Ja procital eti ssylki
http://forum.hddguru.com/viewtopic.php? ... ight=sabre
i celyj manual k MHDD, no resenije, kak možno etu probljemu resit, ja nikde nezískal.
U menja net PC3000, s kotorym, ja dumaju, mozno sdelat remont. No u menja jest jesco odin ten samyj disk WD800BB-55JKA0, kotoryj rabotaet choroso.
Jest možno sdelat remont? Naprimer s MHDD (kak pisetsa zdes)? Spasibo za pomosc.
MHDD vydaet sledujusceje:
19.03.2006 13:06:03 | MHDD 4.6 (c) Dmitry Postrigan | FREEWARE
19.03.2006 13:06:03 Changing mode to: IDE
19.03.2006 13:06:28 Changing mode to: IDE
19.03.2006 13:06:28 Device selected: 3
19.03.2006 13:06:38
19.03.2006 13:06:38 MHDD>I
19.03.2006 13:06:38 WDC ROM MODEL--SABRE-- LBA: 156,391,201
19.03.2006 13:06:38 SN: WDC-ROM SN# XYZ---- FW: 05.01C05
19.03.2006 13:06:46
19.03.2006 13:06:46 MHDD>EID
19.03.2006 13:06:46 WDC ROM MODEL--SABRE-- LBA: 156,391,201
19.03.2006 13:06:46 SN: WDC-ROM SN# XYZ---- FW: 05.01C05
19.03.2006 13:11:39
19.03.2006 13:11:39 MHDD>SMART ATT
19.03.2006 13:11:39 Getting SMART attributes...
19.03.2006 13:11:39 SMART READ ATTRIBUTES
19.03.2006 13:11:39 HDD: WDC ROM MODEL--SABRE--; FW: 05.01C05; SN: WDC-ROM SN# XYZ----
19.03.2006 13:11:39 --------------------------------------------------------
19.03.2006 13:11:39 SMART attributes:
19.03.2006 13:11:39 Name Val Worst Raw
19.03.2006 13:11:39 Att # 1 : Read error rate : 200 200 0
19.03.2006 13:11:39 Att # 3 : Spin up time : 170 163 2483
19.03.2006 13:11:39 Att # 4 : Number of spin-up times : 100 100 140
19.03.2006 13:11:39 Att # 5 : Reallocated sectors count : 200 200 0
19.03.2006 13:11:39 Att # 7 : Seek error rate : 100 253 0
19.03.2006 13:11:39 Att # 9 : Power-on time : 95 95 4344
19.03.2006 13:11:39 Att # 10 : Spin-up retries : 100 100 0
19.03.2006 13:11:39 Att # 11 : Calibration retries : 100 100 0
19.03.2006 13:11:39 Att # 12 : Start/stop count : 100 100 141
19.03.2006 13:11:39 Att # 194 : HDA Temperature : 116 89 27
19.03.2006 13:11:39 Att # 196 : Reallocate event count : 200 200 0
19.03.2006 13:11:39 Att # 197 : Current pending sectors : 200 200 0
19.03.2006 13:11:39 Att # 198 : Offline scan UNC sectors : 200 200 0
19.03.2006 13:11:39 Att # 199 : Ultra ATA CRC Error Rate : 200 200 0
19.03.2006 13:11:39 Att # 200 : Write error rate : 200 200 0
19.03.2006 13:50:07
19.03.2006 13:50:07 MHDD>EID
19.03.2006 13:50:07 WDC ROM MODEL--SABRE-- LBA: 156,391,201
19.03.2006 13:50:07 SN: WDC-ROM SN# XYZ---- FW: 05.01C05
19.03.2006 13:51:45
19.03.2006 13:51:45 MHDD>EXIT
19.03.2006 13:51:45 MHDD: Exit
 Post subject:
PostPosted: October 23rd, 2006, 7:37
helpdisc
OK, please send solution a mrl@adinet.com.uy
Sorry my english
Users browsing this forum: mima85 and 116 guests
