 Post subject: HELP ME RECOVER DATA Maxtor 4D040H2 (DAH017K0)
PostPosted: November 4th, 2006, 10:14
Hello Experts. I have a problem with Maxtor 4D040H2 hard disk (Want Data)
Problem : When i received the hard disk. it was not detecting normally. but can be viewed in MHDD. But when i try to clone the hard disk, it started giving bad sector error. so i plugged the disk on PC3000Pci. and it has detected it (delay).
What I did / found
I so I did "" Reading Modules "" found Modules 4F and 5A on head2 with error
I read "" Reading Modules on Head3 and found all the modules ok. I replaced the Head2 Modules 4F and 5A with Head3. and re stared the system with Hard disk on Mother board IDE. but problem remains the same.
What i did -2
I re pluged the disk on PC3000 and disk "" SERVICE STRUCTURE TEST" & here is the report found some error.
SA structure test
Selected family ........................... Romulus DSP
Model ..................................... Maxtor 4D040H2
Firmware .................................. DAH017K0
Serial .................................... D26J2ZBE
Min. cylinder ............................. 611
Max. cylinder ............................. 58189
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 2
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. D26J2ZBE
Max LBA ................................... 78125000
Head number ............................... 2
Head map .................................. 2 3
SA head map ............................... 2 3
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV6·
Checking User data adaptives
Header .................................... CR0T €
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 611: 4212: 896
2 : 4213: 7814: 871
3 : 7815: 11416: 851
4 : 11417: 15018: 821
5 : 15019: 18620: 806
6 : 18621: 22222: 784
7 : 22223: 25824: 756
8 : 25825: 29426: 728
9 : 29427: 33028: 696
10 : 33029: 36630: 672
11 : 36631: 40232: 640
12 : 40233: 43834: 610
13 : 43835: 47436: 572
14 : 47437: 51037: 532
15 : 51038: 54638: 497
16 : 54639: 58189: 448
17 : 58195: 58244: 336
Checking ROM Copy
Check sum Value ........................... 9DF6
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 7200
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... ....
OverlayId ................................. 0000
ROM CRC ................................... Error
Checking RZTbl
Checking P-List
Checking G-List
Checking RZTbl-PList
Difference ................................ not found
Checking RZTbl-HList
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 0
Block1
Block2
Block3
Block4
Block5
Block6
Block7
Block8
Block9
Block10
Checking security
Header .................................... SECU
User Password ............................. " "
Master Password ........................... "Maxtor "
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking FMTI
Id ........................................ 93
Header .................................... Ok
Checking [DISK/PW]
not found
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. Ok
Module 19 ................................. Ok
Module 1A ................................. Ok
Module 1B ................................. Ok
Module 1C ................................. Ok
Module 1D ................................. Ok
Module 1E ................................. Ok
Module 1F ................................. Ok
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 24 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. Ok
Module 30 ................................. Ok
Module 32 ................................. Ok
Module 33 ................................. Ok
Module 34 ................................. Ok
Module 37 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. Ok
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 6C ................................. Ok
Module 6D ................................. Ok
Module 6E ................................. Ok
Module 6F ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. Ok
Module 79 ................................. Ok
Module 7A ................................. Ok
Module 7B ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8C ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 90 ................................. Ok
Module 93 ................................. Ok
Module 99 ................................. Ok
Module 9A ................................. Ok
Module 9B ................................. Ok
Please advice me how to recover data
PostPosted: November 4th, 2006, 15:37
Hi darkfroce1,
The contents of 4F in head 2 & head 3 is not the same. Hope you have saved the 4F before rewrite.
:arrow: Checksum .................................. Error
DataRecovery.bg
 Post subject: i had backup from Head 2
PostPosted: November 4th, 2006, 15:50
Dear Samo
Thanks for your guidance I have backup from Head 2. all the modules including damage. How to get data
:roll:
PostPosted: November 6th, 2006, 12:13
It is important to know what kind of errors do U get when reading the surface and how regularly (IDNF, AMNF, UNC, ABRT).
do U get it throughout the entire data area, is it periodic?
regards,
Users browsing this forum: No registered users and 90 guests
