 Post subject: Your opinion on this please
PostPosted: November 16th, 2006, 22:15
What is your opinion on this item.
http://www.salvationdata.com/view/produ ... p?pn=00012
I was under the impression that only the pc3k re wrote firmware.
 Post subject:
PostPosted: November 17th, 2006, 8:47
Salvation data makes good things and they are also easy to use but very expensive and not much powerfull than Acelab products
I would suggest pc3k pci as a alrounder . as far as Salvatio data is concerned they sell different products for different HDD and Acelab products are all in one .
 Post subject:
PostPosted: November 17th, 2006, 13:19
I would much rather use PC3K PCI, and also salvation data works the same way as if you load a loader to a damaged disk, which offers no repair and will only work when common firmware modules are damaged such as GLIST but not when the disk has other damage.
Also disk will still be very unstable, maybe it will have hundreds of BAD sectors which will cause problems when recovering. (even to clone the disk will take a long time).
All in all rameez is right, pc3k is much better for the job,
 Post subject: Re: Your opinion on this please
PostPosted: November 17th, 2006, 16:00
Best programs are one you can write yourself.
pc3k still best "commercial" program but some experts write
that this program, for them at least, is like walking on crutches
 Post subject:
PostPosted: November 18th, 2006, 13:02
If the ones written by specialists are still no good, how could the one we write ourselves be any better?
 Post subject:
PostPosted: November 18th, 2006, 14:13
cause U know what U need U can code it exactly the way U need it.
And if anything comes up later, U can add functions to handle the new things.
I do write many things for myself.
Users browsing this forum: Majestic-12 [Bot] and 113 guests
