 Post subject: Why does smartmontools report this drive as PASSED?
PostPosted: November 20th, 2006, 11:44
I've noticed that smartmontools often shows a drive as healthy even though it has a ton of reallocated sectors and is having real world issues.
Any thoughts?
smartctl version 5.30 Copyright (C) 2002-4 Bruce Allen
Home page is http://smartmontools.sourceforge.net/
=== START OF INFORMATION SECTION ===
Device Model:     IC35L040AVER07-0
Serial Number:    SXPTXHZ1686
Firmware Version: ER4OA45A
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   5
ATA Standard is:  ATA/ATAPI-5 T13 1321D revision 1
Local Time is:    Mon Nov 20 09:27:15 2006 CST
==> WARNING: IBM Deskstar 60GXP drives may need upgraded SMART firmware.
Please see http://www.geocities.com/dtla_update/index.html#rel
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity was
                                        suspended by an interrupting command from host.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                 (1383) seconds.
capabilities:                    (0x1b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        No Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        No General Purpose Logging support.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (  23) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   060    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   136   136   050    Pre-fail  Offline      -       320
  3 Spin_Up_Time            0x0007   174   174   024    Pre-fail  Always       -       108 (Average 144)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       78
  5 Reallocated_Sector_Ct   0x0033   095   095   005    Pre-fail  Always       -       237
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   134   134   020    Pre-fail  Offline      -       32
  9 Power_On_Hours          0x0012   095   095   000    Old_age   Always       -       40898
10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       47
192 Power-Off_Retract_Count 0x0032   100   100   050    Old_age   Always       -       78
193 Load_Cycle_Count        0x0012   100   100   050    Old_age   Always       -       78
194 Temperature_Celsius     0x0002   177   177   000    Old_age   Always       -       31 (Lifetime Min/Max 15/56)
196 Reallocated_Event_Count 0x0032   095   095   000    Old_age   Always       -       263
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       14
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
ATA Error Count: 351 (device log contains only the most recent five errors)
        CR = Command Register [HEX]
        FR = Features Register [HEX]
        SC = Sector Count Register [HEX]
        SN = Sector Number Register [HEX]
        CL = Cylinder Low Register [HEX]
        CH = Cylinder High Register [HEX]
        DH = Device/Head Register [HEX]
        DC = Device Command Register [HEX]
        ER = Error register [HEX]
        ST = Status register [HEX]
Timestamp = decimal seconds since the previous disk power-on.
Note: timestamp "wraps" after 2^32 msec = 49.710 days.
Error 351 occurred at disk power-on lifetime: 16969 hours
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 ed fc 56 0b e2  Error: UNC 237 sectors at LBA = 0x020b56fc = 34297596
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Timestamp  Command/Feature_Name
  c8 00 f8 f1 56 0b e2 00 3594346.020  READ DMA
  c8 00 08 e9 56 0b e2 00 3594345.620  READ DMA
  c8 00 f8 f1 55 0b e2 00 3594345.320  READ DMA
  c8 00 08 e9 55 0b e2 00 3594345.120  READ DMA
  c8 00 f8 f1 54 0b e2 00 3594345.120  READ DMA
Error 350 occurred at disk power-on lifetime: 16812 hours
  40 51 0b 76 56 07 e2  Error: UNC 11 sectors at LBA = 0x02075676 = 34035318
  c8 00 e0 a1 55 07 e2 00 3030019.920  READ DMA
  c8 00 e8 99 55 07 e2 00 3030014.220  READ DMA
  c8 00 f0 91 55 07 e2 00 3030008.420  READ DMA
  c8 00 f8 89 55 07 e2 00 3030002.920  READ DMA
  c8 00 08 81 55 07 e2 00 3030002.720  READ DMA
Error 349 occurred at disk power-on lifetime: 16812 hours
  c8 00 f8 89 54 07 e2 00 3030002.720  READ DMA
Error 348 occurred at disk power-on lifetime: 16812 hours
  c8 00 08 81 54 07 e2 00 3030002.420  READ DMA
Error 347 occurred at disk power-on lifetime: 16812 hours
  40 51 0c 75 56 07 e2  Error: UNC 12 sectors at LBA = 0x02075675 = 34035317
  c8 00 f8 89 53 07 e2 00 3030002.420  READ DMA
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline    Completed without error       00%        27         -
# 2  Extended offline    Completed without error       00%        11         -
# 3  Extended offline    Completed without error       00%         3         -
PostPosted: November 25th, 2006, 14:08
chek the hddsmart in victoria or MHDD they will show the correct health of the drive .
Users browsing this forum: No registered users and 175 guests
