 Post subject: revitalizing hd with smart reallocate table full
PostPosted: November 28th, 2006, 10:46
Hi!!
I have 4 old hd with the smart table reallocated full, and i was able
in recovering they with only using mhdd
these hd have weak(not bad) sector, so many time i experiment
slowdown, crc errors, etc....
Chkdsk /r /f alwys give me different result: sometime some sector are
marked as bad, sometime chkdsk recor them, btw the file access is
always unstable.
After use of the following procedure I was able in deep testing these
hd (24 ore test for every hd) with excellent result!!
1) run mhdd, perform a normal (do NOT enable relocation) scan, a log
file with all the warning/weak (red and brown) sector is generated,
print this file...
2) now on every weak sector (refer to the precedent log):
a) erase from 1^ weak sector to 1^ weak sector.... If you don't
perform this individual erase sometimes the successive makebad
function does fails, even a full erase of the entire disk will not be
able in assuring regoular work of the successive makebad command.
b) use makebad from 1^ weak sector to 1^ weak sector, this operation
will transform weak sector in UNC(uncorrectable bad sector).
c) repeat this procedure from a to b for every weak sector you have
got (refer to the log you just printed on point 1)); this may be a
very time consuming operation, btw it work 100%
Now under window re-partition hd, reformat it using full (NOT fast)
format.
d) now performing chkdsk on this hd will tell you that hd has many bad
sector, but from this moment OS no longer will access these sector and
your hd will operate 100% with no problems!!!
If some of you with a little C program experience wanna help me, we
may automatizate the procedure of manually erasing every single weak
sector: we only have to take the file log on point a) to generate a
batch file who may run under mhdd
A prayer for the MHDD auther:
Is not possible a little modification to make possible performing in
batch the "makebad" command?
Thanks to all!!!
 Post subject: re
PostPosted: November 28th, 2006, 17:46
Ilogic :D and very complicate, you can use PC3000 for reset Smart table , move G-list in P-list, repair broken modules, regenerate translator, selfscan and many other function for your hard.
PostPosted: December 4th, 2006, 19:17
Then again, where is the challenge in that?
dan, wish I had the experience you are looking for
Keep up the creativity
Applause to Maysoft
Storage Freak
Firn
PostPosted: December 5th, 2006, 6:04
Hi!!
I don't understand english very well, so I hope my answer will be pertinent....
You wanna know what I wanna to do?
Every people wanna repair bad sector, while I wanna create it...... ;-)
Well!!! Consider the follows:
-) I have NOT Pc3000 and never I'll be able in buying it, it's over my possibility, I may use only freeware utility.
-) I had 4 old hd (smart table indicate that no other relocate sector is possible...) with weak(not bad) sector, after manually marking as UNC these weak sectors, all hd now works 100%, I have try for every hd a full 24h exercize: using a batch file to copy data, fill hd, then delete and repeate..... HD!!! now works 100% with no problems.!!!
-) So now I wanna someone help me to write an utility able in making UNC sectors via command line, so I may automatizate may procedure....(the makebad command on MHDD is interactive: I have to answer yes every time, then manually insert the number of the sector I wanna mark as UNC, and does not permict batch processing)....
Theorically, I'm completelly wrong...... BTW pratically I have recoveder (till now) 4 hd......
BYE!!!
PostPosted: December 14th, 2006, 16:47
an utility to automatic performing this job is on the way, but I don't know where to post it, it will be ready for beta tester in a few days.
Does anyone wanna test it?
This utility in NOT for people who have got pc3000, really superb but expensive.........
PostPosted: December 15th, 2006, 10:21
i write many utilities like that but these are not work for all drive and models ..just some ones... :lol:
Users browsing this forum: Google [Bot] and 78 guests
