 Post subject: Another head stack (fujitsu) compatibility?
PostPosted: November 28th, 2006, 19:20
BAD=MODEL: MHV2060AH ID: YTTN P/N: CA06531-B20200DL
COMPATIBLE?=MODEL MHV2060AH ID: NOTHING P/N: CA06531-B026
Would it work?
PostPosted: November 29th, 2006, 22:59
Bump. Anyone comment?
PostPosted: November 30th, 2006, 1:24
HI,
For Fujitsu drive head stack, you must make sure you have a same model and same ROM firmware ( can be seen from HDA label ).
Its show like 12XX-XXXX ( you need to match the XX-XXXX code )
Tony Heryanto
PostPosted: November 30th, 2006, 12:34
tonyht wrote:
HI,
Tony Heryanto
So bad drive is CA21332-B42X
Donor is CA21332-B44X
Are those the right #'s for ROM firmware?
Users browsing this forum: No registered users and 176 guests
