 Post subject: strange bad blocks
PostPosted: December 4th, 2006, 15:48
HI !
can somebody give a hint, what could be the problem if the drive has bad blocks at every 256 LBA sectors?
at first scan was at 0,256,512,768,1024
then after MHDD erase, no bad sectors, only many red and green blocks, spaced at multiple of 256 lba sectors ( ex: 8192, 8960, 9984 ... )
I hope you can understand my poor english.
thank you in advance
VL
 Post subject:
PostPosted: December 4th, 2006, 15:53
What sort of drive is it?
 Post subject:
PostPosted: December 4th, 2006, 16:35
hmmmm... i am thinking :idea:
MHDD reads 256 blocks, and if 1 of them is bad..., thats why i get the 256 granularity.
the drive is MAXTOR 4K040H2
it has many weak sectors, and i would like to do a SELFSCAN to get rid of them, but dont know how to start it. So, i am playing whit it untill .... i learn something, and the questions will dissapear :)
thank you for your help
VL
 Post subject:
PostPosted: December 4th, 2006, 17:03
Have you tried running HDD Regenerator?
Works pretty well on Maxtors, I find.
 Post subject:
PostPosted: December 6th, 2006, 16:38
I am a little skeptic in any hdd regenerator, but i will try it. The strange thing was that sequential reading was bad, but the butterfly reading was almost good ( sector access times ) . I am expecting more drives, then i can learn on them...
 Post subject:
PostPosted: December 8th, 2006, 10:27
hdd regenerator sucks MHDD much better use security erase in MHDD or use Write erasing in Victoria or try any Low level format tool . Can u give the hdd SMART here so i can give some more advices .
Users browsing this forum: Majestic-12 [Bot] and 115 guests
