 Post subject: Secondary Master Busy, when using recovery tools
PostPosted: December 20th, 2006, 10:54
Hello Guys,
When ever I try to use tools such as PCHDD, WD_Checl (WD-SA) or
HDD Repair 1.1, I always get a Busy signal from the Secondary Master.
Doesn't matter what for a drive, System or OS I am using.
Tried this under Win 98Se, Win XP, Free Dos,
this is happening with WD drives. Also tried them In Safe mode, but this didn't make a difference.
Note: I tried this with both, defective and good drives.
Any suggestions would be great.
PostPosted: December 20th, 2006, 13:10
I think problem with your ide cable or may be your motherboard's secondary ide port is bad . Check it
PostPosted: December 20th, 2006, 13:35
Thanks for your reply rameez. :D
I tried this on 2 different systems with different Motherboards and cables.
The port seams to function for normal operations.
I can connect a drive to the secondary master and work with it in windows or dos without a problem.
I can also use tools like MHDD and Victory without a problem.
But when I try to use tool with some SA function, then the drives are showing the Busy register. This only happens with non comercial tools. First I thought It was a bad tool, but now I tried several tools and they all show the secondary as busy.
PostPosted: December 21st, 2006, 4:47
Even in victoria the same thing happens . Try connecting the hdd in working mode when victoria is on connect the hdd . the state registor will goto to DRDY and DSC and error registor will goto AMNF that means the hdd is detect . if this doesnot happen then problem with the hardware .
PostPosted: December 22nd, 2006, 14:59
rameez,
this worked. Thank you :lol:
PostPosted: December 22nd, 2006, 16:40
Welcome anytime .
Users browsing this forum: Google [Bot], ora and 107 guests
