 Post subject: Running scan with all XXXXXXXX.
PostPosted: January 19th, 2007, 13:50
Running scan on IBM ESXS SCSI drives and some are coming up with all XXXX's. Any ideas???
Thanks again everyone. :)
 Post subject:
PostPosted: January 21st, 2007, 0:04
You can try erasing the drive with "erase" command. If that won't fix the problem, then it is trash...
 Post subject:
PostPosted: January 21st, 2007, 5:29
I think it is the pcb problem , is the name displayed correctly .
