 Post subject: maxtor sata write cache disabled
PostPosted: January 22nd, 2007, 18:31
Anyone know how to enable write caching on my drive? (please see attached picture for info)
Thank you in advance.
 Post subject:
PostPosted: January 23rd, 2007, 14:47
What is the purpose of enabling the write cache option ?
 Post subject:
PostPosted: January 23rd, 2007, 22:21
Try going into the drive properties within the device manager, not the controller card.
 Post subject:
PostPosted: January 24th, 2007, 2:48
rameez Write caching will enable my hard disk to use its 8MB cache which is currently disabled.
I have a Seagate drive on the same computer with its cache enabled and run ATTO drive benchmark.
Maxtor is unusable (~10MB/s max write)
bsnyder that works for ATA drives not SATA take a look below:
Write cache disabled is not a windows issue as when I boot with Hitachi Ftool it reports the Maxtor as Write Cache: Disabled. I can enable the cache exit the program re-enter the program and it still reads enabled. As soon as I restart it is disabled again. The same goes for Read Ahead although that is Enabled on my drive.
Ftool had some use though, I could enable AAM for the maxtor which made it whisper quiet but seek time went through the roof, from 13ms to 19ms, according to HDTach Benchmark so I disabled AAM.
 Post subject:
PostPosted: January 24th, 2007, 8:38
It does work for SATA drives but not, if they are handled through a proprietary driver that interprets SATA drives as SCSI (as in your case).
weaker
Users browsing this forum: DRUG and 244 guests
