 Post subject: How to edit an HDD firmware ?
PostPosted: January 24th, 2007, 19:31
I have a Seagate HDD firmware that I need to modify in order it to change behaviours to security commands
(When it receive any ATA SECURITY UNLOCK command, it must act as if the user password were the right one)
in order to repair some computers which require that their HDD are locked with the right code (which I haven't, and doesn't works with an unlocked device), their HDDs are out of order...
I just need to use the modified drive to boot the computer and dump motherboard bios (which contains lock code in order to lock another drive to work fine with the computer)
I have all I need except informations to edit firmware (I have the right flash utility and original firmware, and utility to dump MB bios and retrieve HDD lock code from it)
Where could I find any information about firmware file structure, decompilation or edition, and needed softwares ?
Thanks, and I appologize for my bad english skill.
PostPosted: January 25th, 2007, 13:55
Spildit wrote:
Try to clear the CMOS; try to flash a new version of the BIOS or Change the Bios chip itself.
Impossible, I would have already done it... They aren't real PC, but PC based computers...
Only way to do it is to modify HDD firmware or to solder a new chip, but some motherboards I have to repair are protected so much that I can't sold anything on it.
 Post subject: re:
PostPosted: January 26th, 2007, 23:24
This message has been erased by moderator. Beware: SalvationData are spammers!
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
 Post subject: Re: re:
PostPosted: January 27th, 2007, 7:33
salvationlaura wrote:
I am not HDD guru,but i know you should load the identical seagate HDD to save the firmware, then write into the defect one.Maybe the password problem caused by certain firmware module.I suggest you that you should use professional software if you will repair many HDDS.
I recommand you use our software,and you can [url]http://www.salvationdata.com/download.htm[url]download the demo version[/url][/url]
or add MSN :sales.laura@salvationdata.com
Thank you for your _ADVERT_, but here is _NOT_ any link between my problem and your message, I need to modify a firmware in order to repair a computer, not to repair HDDs...
I think I won't ever use a software made by people that can't read :evil:
I can maybe suggest you:
Learn the alphabet
or Reading Lessons
PostPosted: January 27th, 2007, 10:00
This is just that SalvationData spam member, don't care about it.
PostPosted: January 27th, 2007, 19:40
In case all these PC based stuff use the same PWD on their drives the most trivial thing U could do is to read out the user PWD from a bad drive (need to be working on some basic level to do this), and lock the new drive with that PWD.
U should FORGET modifying the FW itself unless U work for seagate and are a FW engineer :)
regards,
PostPosted: January 27th, 2007, 20:49
Lol, it would be too easy if all computer had the same pwd, no one has the same ! :?
I just have to do a really few changes in the firmware
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 118 guests
