 Post subject: WD1600JB fried
PostPosted: January 19th, 2007, 9:11
A new issue :
WD1600JB
The user managed somehow to plug the power upside down :shock:
So this mean 12 v in the place of 5 v. Am I right?
The result is in the picture
Basicaly I know what I have to do but unfortunately I dont have a good board for this serries. I know this a common serries but ...I dont have...
I have only a board from WD2500JD.
Do you think that is possible to swap the boards and the firmware chip?
Did someone succeded to swap a ATA board with SATA for WD?
I know that this works for some Maxtor.
 Post subject:
PostPosted: January 19th, 2007, 9:57
You also need new heads stack assembly
 Post subject: ~
PostPosted: January 19th, 2007, 14:33
you can swap a ATA board with SATA for WD.
and you must swap the rom chip too.
i thing the 2060-001267-001 board can fix you HDD
 Post subject:
PostPosted: January 20th, 2007, 4:48
OK . Meanwhile I found one WD1200JB.I will try to swap on Monday.
 Post subject: ....
PostPosted: January 21st, 2007, 18:11
1st...check that both boards have the same code:
2060-001265-003
2nd...you must swap U12 - serial prom chip !!!!!
without this step no chances that hdd will start to work....
 Post subject:
PostPosted: January 22nd, 2007, 7:36
:evil: The Board from WD1200 is
2060-701265-001
 Post subject:
PostPosted: January 24th, 2007, 17:08
hello if u whant to repair WD hdd u need first Repair PCB
when Replace PCB it is hard to fix
 Post subject:
PostPosted: January 28th, 2007, 1:24
Ok. I found identical board, resolder ROM , but I think something is wrong with preamp or heads becouse the drive is still clicking. I give up with this one. Thank you everyone!
 Post subject:
PostPosted: January 28th, 2007, 19:08
2060-701265-001
What number of board from WD1600?
Exactly same ( 2060-701265-001 )
or not?
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 119 guests
