 Post subject: Question to moderator
PostPosted: August 3rd, 2004, 10:23
Is it OK if somebody will discuss A-FF company services here ? If no , please delete this topic .
I just can't find a place to speak about this , but I think that many people have questions and answers :) .
If there is any a-ff customer , I would be glad to meet you !
PostPosted: August 3rd, 2004, 11:18
Not so quick, mister. First explain us what your login means . Optionally you can say where are you from.
format c:
PostPosted: August 3rd, 2004, 16:48
Hi . Are you the customer of aff ?
I can use aff service from any place so it is doesn't matter where I live :) .
Have you any success with aff?
On this moment we have tested toshiba and fuji 2.5" drives with aff and we have very good statistics .
But we have problems with WD drives recovery . So I want to discuss WD drive recovery using aff . Have you any success ?
 Post subject: AFF
PostPosted: August 15th, 2004, 18:48
The reason aff works well with Fujitsu drives is there are usually a couple of mods that go bad on any given family of drives. They have tried to employ the same principle with WD. However, WDs can have lots of bad mods and they all need to work. So, if it is just Mod 25 or whatever, they are programming as the usual failure there is no way they can have the same success with WD as Fujitsu. WD MODs vary in size, the amount etc... as much as the firmware does in WD drives.
Users browsing this forum: Google [Bot] and 131 guests
