 Post subject: Corrupt Firmware WD200EB 75CPFO
PostPosted: February 23rd, 2007, 16:47
This 20GB disc has a corrupt firmware. Where can I get a copy of this firmware and how do I write it to the disc.
Any help would be gratedully recieved.
 Post subject: Solution is Pc3000
PostPosted: February 24th, 2007, 2:24
how can you be so assure that the disk has firmware problem you have not described the fault of hard disk. and you just cant copy paste the firmware you need special tools like PC3000 from ACE labs.
Please describe your problem of hard disk
DF
 Post subject:
PostPosted: February 25th, 2007, 4:23
First check ur hdd in mhdd if it gives SSSSSSSSSSSS or !!!!!!!!!!!! then it is firmware problem .
